Question about Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm
I disconnected the hose to my inground Pentair Pool cleaner from the wall and now I cant reaattach it back to the wall. I have a Perry in ground pool.
  • 640 Answers
Here is a copy of the users manual for these pool cleaners. They have a detailed illustration of how to connect the hose to the in ground pool. You will find that much more helpful that me trying to tell you when i can't see your connections.
Posted on May 11, 2011
Jet vac will not move around the pool
Does pump work?
if not, then it's a pump problem.
If yes, then possibly plugged with debris either in the booster pump impeller or at the finger screen?
It's located at the wall adaptor.
Or... The internal gear assembly is the problem?
Sometimes the get stuck, broken tooth on an individual gear, or foreign debris clogging it.
Feb 11, 2014 | Pentair Jet - Vac Pressure Side Inground...
Kreepy Krauly has very little suction thru head but plenty thru hose
most all pool cleaners generate there motion with a thing called a venturi ! thats inside it usually moves a small propeller from the action of water being sucked hard thru the hose , on most the path to this "propeller" is different than that of pool debris , i suspect this alt path is part ways blocked , a simple way to clear is to connect garden hose to suction port of cleaner and force water Back in other direction other than that sometimes dissasembly is need to lube and clean hidden ports inside
Jan 04, 2014 | Pentair Kreepy Krauly Inground Automatic...
Connecting Electrical to Pentair SuperFlo Pump
if 220 volt ok from factory hot to L1 2nd hot to L2 green to ground or case if 120 volt see side of motor for wires to be moved for low voltage
Jun 26, 2012 | Pentair Wf 6 1.5hp Whisperflo Inground...
Kreepy kraully not cleaning complete pool
If the pool hose has been connected to the Kreepy Krauly in the one position for a long time, the pool hose gets set is a position so the kreepy Krauly travels ith same path all the time. Try rotating the pool hose 90 degrees and or change the angle of the hose connector in the skimmer box.
Mar 07, 2012 | Pentair Kreepy Krauly Inground Automatic...
TYPE OF POOL WALL CONNECTOR FROM HOSE TO THE POOL WALL FOR PENTAIR GRAY LEGEND PLATINUM POOL CLEANER?
There are a couple fittings used between the wall and pipe,
Start with these:
Wall Fitting, Gray - Part Number LLW22PM
Wall Fitting, Complete - EW22
Quick Disconnect Adapter, Gray - LL23PM
If these aren't what you need let me know.
Feb 27, 2012 | Pentair White/Gray Legend Inground...
Do other brand name pumps work with a polaris 380 or do i need to use the polaris pump?
The Hayward booster pump would work but being in the same price range the Polaris is engineered for its cleaner
Jun 30, 2009 | Zodiac POLARIS 380 HEAD/HOSE INGROUND POOL...
Wondering if a robo-kleen robotic pool cleaner can be used in an inground pool?
You will find it won't climb walls, but should clean just fine on the bottom area.
S. Christian dansker01@msn.com
Jun 05, 2009 | Smartpool Dolphin Robo - Kleen Above...
Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm Logo
69 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
