Question about Maytag MAH6700AWW Neptune Front-Load Washer
Maytag 4000 series error code F28 door lock. - Maytag MAH6700AWW Neptune Front-Load Washer
  • valady1262
    valady1262 Jun 01, 2012
    My Maytag 4000 series washer displayed error code F28 and it would not function. I unplugged the washer from the electrical wall outlet for approximately two minutes,which allowed the machine to reset itself. I plugged the machine back into the electrical outlet and it returned to operating properly.
  • Full Name May 05, 2013
    Thank you! The same solution worked for Maytag 5000 series washer - it had error code F28 displayed and door lock indicator flashing.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please post a comment with the model no# for your Maytag 4000 series washer so that I can assist you further.
Thanks
Rylee
Posted on Jun 01, 2010
  • 2 more comments
  • jimswiderski Jun 01, 2010
    Model #MHWE400WW01 - MAYTAG Automatic washer
  • Rylee Smith
    Rylee Smith Jun 01, 2010
    Error F28
    means that either Motor control unit(MCU) and/or machine control
    unit(CCU) are bad and needs to be replaced. Please see this repair manual for
    your washer that will assist you on how to replace the parts.
    Please
    do accept the solution if the issue is resolved or post a comment for further
    assistance.
    Thanks
    Rylee
  • Chio Saechao
    Chio Saechao Dec 20, 2012
    The Model# MHWE400WW01 is Maytag 4000 series 4.5 cu. ft. I'm very thankful if u can help me out here.
  • Chio Saechao
    I have the diagnostic guide for service tech and I did the diagnostic test and is say F 29(door unlock error).
I have a Maytag 9000. It gave me a F28 error code. How do I get the door open? What is wrong with this machine?
That's an error caused by the ccu (central computer unit) and the mau (motor control unit) not communicating properly. To get the machine open there should be some screws that hold the bottom panel. Remove those screws and reach up inside the machine (usually to the right) and feel for the door lock unit. There should be a small plastic tab you can pull and that will release the door. In my experience the f28 code can be caused by a clogged or malfunctioning pump. There is a strainer that can be unscrewed and there is usually a blockage in the strainer. If there's no blockage you need to make sure that the impeller of the pump is clear of anything. If the pump is ok you would need to replace the mcu
Sep 15, 2017 | Maytag Washing Machines
What is f28 error code on may tag 4000 washer.
Google Maytag error codes .or contact maytag or go see a dealer of maytag Durable Kitchen Laundry Appliances Maytag
Dec 05, 2016 | Washing Machines
My maytag has error f 28
F28 is a communications fault between control boards. Before throwing money at it, check all wire harness connections. Make sure they are clean and tight. Check for oxidation on the gold terminals. Remove the connectors and put them back on 4-5 times to clean the terminals. Recheck the machine operation.
Jun 13, 2016 | Maytag Epic Z and Performance Series 2000...
Help! How to fix F28 error on Maytag 4000 series Model MHWE400WW01?
I went through this some time ago with my whirlpool duet washer. I had the service man come out after I replaced the mcu and still did not work. He told me that he had no way to check for sure that it was the ccu but said he thinks that I should replace it so I did and it solved the problem.. I still don't understand why he could not tell me for sure that the ccu was the problem because it cost a lot to order it.
May 03, 2014 | Maytag MHWE400WW Front Load Washer
Error Code F24 Maytag 4000 Series Front Load Washer
This video will show you how to open your Maytag 4000 series washing machine door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 04, 2013 | Washing Machines
Maytag 4000 series error code F 29(door unlock error).
Thank you
Jeff Rockwell for trying to help me out.
I did all the step and I replaced it with the new switch/lock that i got for Ebay but still the same problem. I diagnostics using the tech.sheet and still say F 29. Not sure the new switch/lock is bad. How can u test if the new switch/lock is bad?
Dec 20, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Whirlpool f28 error code and door lock light
For the F28 error code:
First, check the wiring harness connections to the MCU, the Motor, and the CCU. Make sure all the connections are tight and there are no ground wires off. Then check the connections of the CCU board within the housing.
If the wiring connections are fine then It would be a good idea to order both, as both components have been problematic for the error code F28.
Here is a link to the CCU.
Here is a link to the MCU.
Oct 13, 2012 | Whirlpool WFW8300SW
I have a maytag 4000 series and im getting a code F28 and i dont have a manual ?? can you help
I'm cheating a bit here because I do not have the decode for 'F28' but-
How to obtain a manual-
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Apr 20, 2011 | Maytag Washing Machines
Whirlpoo; wfw9200 F22, F28, A17 A27 error codes
f22 is a door lock error and f28 is a commication error you still have warranty thorugh whirpool. you're going to need pro. help
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
3,632 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
