Question about Mitsubishi WS-55511 55" Rear Projection Television
The green light in front panel is blinking constantly. It will not power up. I recently moved the television to another room, but the television was handled with extreme care.
  • Shahid Electronics
    Shahid Electronics Jul 09, 2010
    toolkits, do you have any thing else to answer tv question? always 9 capacitors in power supply board? you know nothing about tv.
    President:
  • 1,099 Answers
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage. If otherwise you can Try websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this helps
Posted on Jun 01, 2010
Mitsubishi hdtv 1080 what are the blinking green light codes
ost models have a self-diagnosis feature to help determine shutdown problems.
To enable this feature do the following....
1) Turn the tv on and then let it shutdown
2) Press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds
3) After 5 seconds the power LED on the front panel will blink a two digit sequence.
This will commonly be one set of blinks followed by a short pause then another set of blinks.
This will repeat around five times.
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short detected - commonly caused by convergence failure - to repair this check out site for a convergence kit)
2 - 3 = Deflection protect
2 - 4 = Vertical protect
Note: A constant blink on certain models will typically be caused by a fault in the DM model. To repair this check out site a "blinking green light kit"
Aug 05, 2014 | Mitsubishi WS-55513 55" Rear Projection...
Tv is coming on for brief period and shutting down also constant flashing of green led light on front of tv
I have a plasma that does the same thing. I don't know but have been told it is probably the power supply.
Jan 11, 2013 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Hello, I have an 56' Mitsubishi 1080I television. Model #55859. We moved the TV across the room last night and now we cannot get it to turn on. All we can get is a flashing green timer light on the front,...
Hi rteague2566,
The flashing light indicates something is wrong. Have you tried pushing AV reset button on the front panel of the TV. You may even try the little pin hole reset by the power button too. I think you may have bumped or, vibrate it to hard in the move and, caused the lamp or lead wires to become lose or, unseated. You may have even damaged it. Did you move this TV when it was still warm? Is the light blinking fast and, can you hear anything going on inside. Usually the DM board fails or, a few capacitors need replaced with this model.
If you still can't get the TV to turn on after the reset buttons have been pushed. Can you read the blink code. It should blink, blink, pause, blink, blink, blink. That would be a blink code of 23. Count the blinks in between the pauses. Let me know what code you get. If it just blinks real fast it is probably the DM. I kind of think you may just need to re-solder the leads. A DM cost about $250 with labor. When you plug back in and turn the TV on, let it blink for a few minutes, it might come back on. I'll wait for your response to give further instructions.
Jan 26, 2011 | Televison & Video
Unplugged my Ws-55711 TV to move it to another room so the carpet could be cleaned. When I moved it back and plugged it in, the green light kept blinking for more than 60 seconds. I unplugged the TV for...
Open up the front, look under the right side picture tube. Look for puddle of oil on signal board. If you see this, it has bad picture tube & signal board. Not a good repair.
Jan 17, 2011 | Mitsubishi WS-55711 55" Rear Projection...
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Apex Digital 19" LCD wont turn on green light blinks
you can have a electronics repair done on this unit call 719 687 6997
Jan 14, 2009 | Apex Digital AVL2076 20 in. EDTV-Ready LCD...
Blinking Green Light on Mitsubishi DLP 52525
check the pico fuses on the reverse side of the DM , Just check them in circuit for continuity. let me know how you make out, and if you need any more advice lert me know
Mar 18, 2008 | Mitsubishi WS-48513 48" Rear Projection...
Mitsubishi WS55513 tv
capacitor problem.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
Dec 14, 2007 | Televison & Video
Ws 55513
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Sep 22, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
149 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
