Loud bang then dark screen, no picture, no sound.
We've had a Dynex 32", LCD TV for about 18 months. While viewing the TV we heard a loud bang and the TV screen went dark, no picture and no sound. We smelled a slight burning smell. I removed the large back cover plus one small one under that, to expose some circuit boards. I saw no evidence of anything having exploded or burned.
    President:
  • 1,099 Answers
Assuming there are no other symptoms:
If this appears after extended operation - an hour or more - it may just be a build up of dust, dirt, and grime over the years. After understanding the safety info, some careful vacuuming inside may help. Just don't be tempted to turn any screws or adjustments!
Dust is attracted to the high voltage section in particular - even the front faceplate of the CRT collects a lot and should be wiped with a damp cloth from time to time.
If the symptoms develop quickly - in a few minutes or less, then there could still be a dust problem - a power resistor may be heating a wad of it but other possibilities need to be considered.
If not dust, then probably in the power supply but realize that TVs don't have a nice metal case labeled 'power supply'. It is just a bunch of stuff scattered around the main board. Without identifying the part that is heating, a diagnosis is tough especially if the set really does work fine otherwise. However, if a series regulator were faulty and putting out too much voltage, the set could appear to work properly but in fact have excessive power dissipation in certain components. If cleaning the dust does not solve the problem, you will probably need a schematic to identify the correct voltages.
Also, A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Posted on Jun 01, 2010
Dynex 32" tv picture goes black
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing. The Voltages should be written next to the sockets & plugs on the Power Board.
Jun 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Ringing sound when TV is off
Change the power supply board. What you are hearing is the switching power supply. They work at high frequency and sometimes produce lower ferquency harmonics that can be heard by people.
Apr 30, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Heard a loud pop during turn on, not picture but
Ur LCD inverter board it dead.Replaced this board u will get ur picture back.Tries websites like shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long shape board.
Apr 26, 2010 | Toshiba 32HL66 32 in. LCD HDTV
No Power - Viewsonic N3252w LCD TV
you go to a service centre near your area who repear it
Sep 08, 2009 | ViewSonic N3252w 32 in. LCD Television
Front panel blocked or locked
RCA Entertainment Series 32" Plus Gold, GEMSTAR, xbox ready has been in the shop twice so far. Transformer replaced and 6 months later the picture suddenly had horizontal white lines that gradually spaced apart more from top to bottom and it had a gray hue and fuzzy, but I still watched it for 3 months that way. Today I turned it on and about a minute later I heard a loud crackling sound coming from the back and the picture disappeared, screen went black. Is it worth fixing again? Please contact me at ninalashua@yahoo.com
Jul 09, 2009 | RCA 32F531T 32" TV
Loud popping noise
The 23" CRT set may have a high voltage breakdown in the flyback transformer or focus divider. Take the back off and operate the set in a dark room. Look for anything that has a blue glow around it or sparks flying when the pop occurs. I won't guarantee this will find your problem, but it is definitive if you see these!
I once had a set with these symptoms. I stopped the blue glow and arcing by covering the focus divider with epoxy. It worked for a couple of months before the divider literally broke apart.
Mar 02, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Plasma TV, loud bang, dead screen
I have a Sony KE-32TS2 set. We heard a very loud bang, and the screen is dead. We still have audio and the ability to change channels. One electrician friend suggested a blown capacitor in the powersupply. I'm pretty handy with electronic repair. Can I do this myself?
Jan 02, 2009 | Sony WEGA KE-32TS2 32 in. HD-Ready Plasma...
NO PICTURE NO SOUND
Hello, there is a possibility that the power supply is broken. Part number: 146872116 Best regards, Arpi
Mar 22, 2007 | Sony WEGA KZ-32TS1 32 in. Television
Televison & Video Logo
360 people viewed this question
Top Televison & Video Experts
Electro Med Services...
