Question about Kenmore 44932 Front Load Washer
Door lock is stuck and won't release. the door got opened and the lock was on. Now the door won't close and the lock won't release
  • ladybug803 Jun 01, 2010
    Thanks so much for your quick response to my questions.
    President:
  • 1,554 Answers
There is a manual unlocking tab located at the bottom of the door lock and switch assembly. Disconnect power to the washer before accessing it.
Remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access the screws more easily.
Reach up along the inside of the front panel and locate the bottom of the door lock and switch assembly on the right side. Locate the tear-drop shaped tab then gently pull it down until a click is heard.
The door lock and switch assembly needs to be replaced if the problem persists. Indicate the exact if you need further advice.
Posted on Jun 01, 2010
    I got the panel off and found the tab you indicated. But when I pull on it, the lock isn't releasing.
  • Jahn27
    Jahn27 Jun 01, 2010
    The only option now is to replace the door lock and switch assembly. Remove the door gasket retaining hoop by stretching apart the retaining
    spring at the bottom of the door opening.
    Gently peel the part of
    the door gasket near the door lock and switch assembly off the lip of the
    right side of the door opening. Remove enough of the door gasket to
    access the door lock and switch assembly behind the front panel.
    Remove
    the three screws securing the door lock and switch assembly to the front
    panel and slightly lift it then pull it back off the front panel. Pull
    the door lock and switch assembly out of the washer and disconnect the
    wiring harness.
    Connect the wiring harness to the new door lock and switch assembly and secure it in place behind the front panel then put the eased part of the door gasket
    back into position over the lip of the door opening.
    Check that
    the door gasket is properly seated before putting back the
    retaining hoop around the lip of the door opening and securing the door gasket.
I have a 95 saturn 2 door, the passenger door is stuck closed. The power lock triggers but still wont open from inside or out. Please help!!!
This usually works.
Take a rubber hammer,roll down the window,then manually unlock the door using the inside unlock button (not the power lock button) while you give the door a good whack about half way down where the door lock assembly holds the door closed to the car body.It may take a few whacks and a few lock/unlock cycles but this usually allows the lock to release and you can open the door.NOW.....take off the door panel and lube that lock assembly and don't close the door unless the lock can be locked and UNLOCKED.
Apr 20, 2017 | Saturn Cars & Trucks
My 2000 olds bravada glove box door is stuck open the latch won't let me close it. Even though there is no way to lock it it seems locked! Do I need new latch or can I fix this one?
Your latch might be in the closed position before you even close the door, try using a small screwdriver on the latch while pressing the release button, if it's stuck closed then this will open it to the right position so it will lock closed when you close the door. If this does not work, sometimes the problem is in the striker (the little tab that the lock hits when the door is closed, this usually has 2 small screws holding it in place, you should be able to loosen both screws & adjust the striker forward or backward so the latch will make better contact with it.
Jan 06, 2015 | Cars & Trucks
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
Film camera back door won't close
Does it not close or does it not lock? If it does not lock it may be the light seals are obstructing the door. If it will close but not lock open the camera, pull up the rewind knob, see if the release slider is operating.
Jun 28, 2012 | Pentax K1000 35mm SLR Camera
Popped the lid open to change vacuum cleaner bag...now lid won't close. It's stuck at 90 degree angle. Is a button to release it?
Hi bndennis,
Please check the spring on your lid, it may be keeping the door open. Miele vacuum cleaners mainly use a spring concept for keeping lids open - merely pushing it down will lock it at the bottom.
Kind Regards :-)
JEDEMEYER1
* If this solution helped you, please rate it
Jul 23, 2011 | Miele S4210 Antares Bagged Canister Vacuum
Driver's door won't open inside or out. Power locks work but inside and outside handles dont release latch. Can I get door panel off in the closed position, otherwise any way to open door
Hey, You need to remove the panel otherwise u can't reattach the metal sticks that move the locks, but i think it's hard to remove it in a closed posision when u don't brake it
May 16, 2011 | Saturn Vue Cars & Trucks
The locking mechanism in my door is stuck in the closed position. that little "c" hook isnt moving at all, and my door will not fully close. is there a release latch somewhere?
Open the car door and pull on the release latch that you use to open the car door from the inside to get out. At the same time use a screwdriver to push up the latch on the side of the door. Sometimes the seatbelt gets caught on the door when you close it causing the latch on the side to close prematurely.
Jan 27, 2011 | 2001 Chevrolet Blazer
Hatch back will not open
With key in hand,hit power door lock switch to lock. Raise release handle & lower. Hit power door lock unlock raise & lower handle. May take a couple times is stuck in limbo between lock & unlock mode.
Jun 07, 2010 | 2001 Volvo V70
Whirlpool duet washer door is open. I can't close it because the latch is stuck in the "locked" position.
The first thing to try is to hold the cancel button for 15 seconds. The more labor intensive solution is this: Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism.
May 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stuck battery door on dsc p93a
There is usually a lock on the inside of the door. Sometimes you can move that while the door is open, else play with the release switch. Once you get it in the open position it should close
Jun 06, 2008 | Canon PowerShot SX100 IS Digital Camera
Kenmore 44932 Front Load Washer Logo
Sal DeAngelo
fordexpert
Mike Carew
