Question about Hayward SAND FILTER, PRO SERIES
Pressure doesn't last & seems to blow out cloudy, dingy water
The pressure doesn't last more than an hour, even right after back flushing and rinsing. And when I look at the water shooting into the pool, it looks very cloudy. Also, even when pump is running, it doesn't seem to be filtering well, as there are still bugs and a film on top of the water. I've had the pool 3 years and have never changed the sand in the filter. Could that be the problem?
  • 8,404 Answers
Please open your filter and remove the top six inches of sand and replace with fresh filter media sand. You should be able to use the balance of the sand ... however, if it too is nasty, sand is relatively cheap and you rely on it a lot.
What is the pressure when you are running? What is your "start up pressure"? (the pressure when the filter is clean). Lets say it is 20 PSI start ... you should back wash when the pressure goes to 30 and the pressure should go back to 20 or 21 as a normal course of events after back wash
Is your water properly balanced? metal is out of the water? Proper TA and pH? TA should be about 100, pH about 7.4 ... CL 2 or 3 ppm. Do you use cynauric acid? should be about 35. Is your pool plaster ... MAKE SURE YOU GET RID OF METAL BEFORE YOU DO ANYTHING. Metal out works best with high pH and no CL. For a plaster pool CA shold be around 300
I hope this helps you ... thanks for your interest in FixYa.com
Posted on Jun 01, 2010
  • 819 Answers
If you are on city treated water, sand will last aprox. 7 years, if on well water typically 3 - 5 years. so yes, could be a sand issue. also, double check that the there is no water trickling out the backwash / drain outlet of the filter, this could indicate that the diverter valve gasket (spider gasket) could be worn and cause sand from the filter to flow to the pool. this is a common problem if you move the position selector often with the pump still running - the pump should always be off when moving the handle. good luck!
Not filtering
too many chemicals will cloud contact the company website or did you maybe its the water change the water
Feb 28, 2017 | Pentair Tagelus TA 60D Filter
Pump is blowing cloudy water back into pool
Cloudy water is the bane of sand filters!. I suggest letting filter run day and night. Do not backwash until the pressure rises 8 - 10 pounds above clean starting pressure. Do not try to vacuum or stir up the sediment. when water clears, vacuum to waste. Keep the hose running while vacuuming. A dirty filter is a better filter (up to a point). At a higher pressure the filter will trap more of the fine particles that are clouding your water.
May 28, 2013 | Pentair Meteor Above-ground 22" Sand...
Coolant not getting to the radiator & top hose has a leak so taped it up but now blows out of the coolant tap sparaying and steaming and coolant level dropping under half
Thanks but coolant/radiator fans are not coming on at all wonder if this is why coolant sensor letting out all the coolant & water when the enginee gets pressurised. Not sure why they are not coming on and also not when the car came back from a 3 hour trip last night. We changed the water aux pump which seemed to help a bit but water still ls leaking but not as badlyy
Feb 08, 2013 | 1995 Audi S6
Cloudy water from refrigerator
YAP.keep flushing.change filter.check water supply.(clear or not).hope this helps.Ali
Jun 26, 2012 | KitchenAid KSRS25IL Side by Side...
What is the best time of day to run the Salt Water System...Morning, Afternoon or Evening?.....and how long? Manual says run for about three hours but that doesn't seem enough...we have been having...
I have an 18 X 33 oval and temparatures here range from 80 to 102 in the summer. I run my cycles at 10 to 12 hrs pump with 8 to 10 hrs chlorinator. Water stays crystal clear, no cloudy.. Now...if you don't keep the electrolytic cell clean and maintain the proper salt levels, you will struggle with making free chlorine...
Hope I helped??? AND... I HAVE NOT ADDED ANY CHEMICALS TO MY POOL IN THE 2 YEARS I'VE HAD MY INTEX SYSTEM...
Jul 18, 2011 | Intex Automatic Salt Water System for ...
We have a hayward sand filter for our 24ft round above ground pool. We changed the sand this season and replaced the 8 fingers @ the bottom of the filter tube. After doing so and turning the pump on it...
its more likley to be too much sand in it and its just cloged up,,,take the sand out and run the pump out of the pool in a big tub of water to flush it out and also to back flush it,,,if its working ok after that fill it up with the right type of sand but only a little at a time,,,,
i dont think the phosphates are a problem its not being filterd thats the problem this needs sorting out fast or the pool will fill up with algy and green slim
Jun 20, 2010 | Hayward SAND FILTER, PRO SERIES
Pressure on the EC65 is always high
Certainly sounds like a filter problem. Here's a couple of things to try.#1. i don't know how you cleaned the filters but clean them again with a good filter cleaner/degreaser.#2. After a good cleaning, get a bucket large enough to hold the filter fingers in and give them an acid bath. They recommend a 20 to 1 ratio of water to acid (muriatic) but I personally don' think thats strong enough. Use a good amount of acid and let the fingers soak for a good ten or fifteen minutes. (always add acid to water, not water to acid) Rinse and reassemble filter. If that does'nt solve problem, I think it's time to replace filter.
Jun 17, 2010 | Hayward EC65 Extended Cycle DE In Ground...
Hotpoint WT761 washing machine - Error code F-10 The machine is filling with water, then signalling F-10, then pumping the water out. So the fill solenoid and the pump are working OK. If I set the machine...
Thats strange, F10 means no cold fill.
Ok back to basics, you can check the pressure switch by taking off the tube and gently blowing into it and I mean gently, you should hear a click if its ok - make sure the other end is'nt blocked, blow it out with a cycle pump near the drum end
Sep 19, 2009 | Washing Machines
Replaced pump and presssure vessel, water outside
If your like me your house has a pressure regulator to keep the pumps high cut out pressure from blowing your lines. Also a lot of domestic wells have a filter at the house to keep sediment out.
Sep 06, 2009 | Plumbing
No back flush pressure
increase the tank water level half inch at a time till you have the back flush pressure.
seems like the water in the bowl is too low to create any wirlpool.
Oct 30, 2008 | Eljer Aqua-Saver 12" Two-Piece...
Hayward SAND FILTER, PRO SERIES Logo
344 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
