Question about Concept Slot Load Half-Din DVD Player Car Video Player
The remote control no longer works so we are not able to start any movies. How do I order a new remote control?
Unionaire wall mounted a/c/heater only works manually.Remote control no longer works even with new batteries.Should I order a new remote control or is the transmission problem from the wall unit?
check the remote operation with your cell phone
put new batteries in the remote , turn on the cell phone to camera and point the remote at the lens of the phone
press any button/s on the remote and a white dot will appear on the cell phone screen
that is the infrared of the remote transmitting
that would then mean that the receiver in the wall unit is not working
Aug 26, 2016 | Heating & Cooling
Access menu without remote on Toshiba 27AF44
You can follow the option of searching the internet for any of several suppliers of OEM replacement remotes. The problem with universal remotes is that not all functions of the OEM remote are replicated.
Dec 19, 2013 | Toshiba 27AF44 27" TV
I think I need a new remote control I ordered a new remote that I was told this was an alternate the original was no longer available I order a PLT 3250 remote should I have order a PLT 32 instead the
Have the first remote tested--most shops have a tester--point remote at it and press buttons and it reacts with a flash (the tester) and if remote tests good the problem could be with the remote receiver in the set
Oct 29, 2012 | Protron PLTV-32C LCD TV
Our projector no longer recognises the remote. We changed the batteries thinking they had died but the remote still doesn't work even with the new ones.
Just to confirm if the remote is working you can do a simple test. Take the remote very close to a working AM radio tuned halfway ( 800 - 1000kHz ) make sure there are no active radio station on that tuning, turn the volume up high. Press any button on the remote and one should hear some bleepling sound as if in an alien movie. If so the remote is transmitting OK. If not replace the remote. Did the previous battery leak and damage the inside ??
Mar 08, 2011 | BenQ Projector Remote (PB6110 PB6210)...
My toshiba CT-847 remote no longer works, how can i fix this or order a new one?
you can order a new one by phoning manifacturer with product make it will cost between ten and twenty pounds please give thumbs up if this helps thanks
Feb 13, 2011 | Toshiba CT-847 Remote Control
My remote won't start my 2005 Buick LaCross. I
Both my remotes no longer work. I will be ordering new ones off Ebay and having my dealer program them. New ones from Buick are very pricey.
Oct 14, 2009 | 2005 Buick LaCrosse
Where do I order a new remote control. The phone # in instruction book is no longer for the Lenoxx Electronics Corp in Edison N.J.
Hi...
If you want to order your remote control you need to visit the ebay site
www.ebay.com order your remote control
Good luck !!!
Regards
PCmania
Jul 07, 2009 | Durabrand HT-3915 System
Dvd stopped playing in the middle of a movie...
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Unfortunately, if the player will no longer read any commercial dvd that you attempt to play, the unit is defective and needs to be replaced. Hopefully, since it's brand new, you still have the receipt and can return it to the retailer for an exchange or refund. The unit has a 90 day warranty from the date of purchase. You would need the receipt in order to receive a warranty exchange.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Dec 28, 2008 | Coby DVD-224 DVD Player
Remote not working
your problem could be in tv- if your remote senser is bad.inside tv your hand unit will not work tv -the television is not receving the signal from remote control.
Jan 26, 2008 | Toshiba MW20FM1 20 in. Combo
Concept Slot Load Half-Din DVD Player Car Video Player Logo
37 people viewed this question
Top Concept Car Audio & Video Experts
Robert Rankin
Tom Chichester
Alberto Atencio
Level 1 Expert
Are you a Concept Car Audio and Video Expert? Answer questions, earn points and help others
