Question about NEC Electra Professional ETW-16DC-2
Voice Mail Just bought the NEC Electra Professional. How do I program it so theat the Voice Mail will work?
  • Anonymous May 02, 2008
    I don't know if it's just me... but trying to activate the automated greeting attendant, whatever you want to call it is a pain in the ****... How do you access the menu in order to change the main greeting, what callers hear when calling the main line. I have tried accessing the box from the main line number and that doesn't work.
Return the NEC unit as it is not fit for a consumer. It is unreasonable for NEC to not include a troubleshooting guide with simple solutions (i.e., user friendly).
Posted on Jun 05, 2008
SOURCE:
How do change the outgoing "Night Mode" message in the Voice Mail System on NEC Electra Elite DTU 32D-1?
If you are using an Active Voice product (typical w/ NEC) you need to change the hours of operation on the voice mail system. "Night Mode" only changes the ringing characteristics of the phone system and where calls ring, not the greetings that play on the voice mail. The voice mail plays a particular greeting (Day/Night/Holiday) based on the time of day specified in the schedule. The system administrator for the voice mail would have to make this change.
Jan 24, 2012 | NEC Electra Elite 32D-1 Corded Phone
Need to reset nec phone
Easiest way to reset the phone is to unplug it then plug it back in. If you are talking about resetting the voicemail associated with the phone extension, that's a little more involved.If you need the voice mail reset, you need to have the voice mail administrator (typically the receptionist) go into his/her voice mail and choose the MGR option if using the display "softkeys" and follow the prompts to reset the users security code or voice mail acct. If softkeys aren't available, follow the voice prompts to "system manager" and either delete the security code or reset the extensions voice mail entirely.
Jan 19, 2012 | NEC Electra Elite DTU 16D-2 Corded Phone
I want to replace this phone. What is compatible for NEC Electra
It doesn't exactly work that way, but I'm guessing that you have 8 button terminals. You can replace them with phones like this: http://www.pcliquidations.com/item.asp?id=1678
There may be some programming required to make them work.
Carl
May 04, 2010 | NEC Electra Professional ETW-16DC-2
NEC DTU-16 D phone voice mail locked up
Cleared voicmail on all other extensions and waited, it eventually (3hrs later) cleared itself
Jun 22, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Need more rings
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
Oct 16, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Voicemail
Log into the voice mail server and you can reset the Voice mail for each account like it was a new account or you can delete the pass word on the account and then setup form the hand set. You do need to know the password to get into the voicemail server program. I believe as default it is NEC.
Sep 12, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Delete old voice mail - program new voice mail
You can usually access the system voice mail setup from any extension.
Press Speaker
Dial ext 200.
When asked for security code, dial *,2,# (dial it twice if there is no code).
When main greeting begins, dial 632.
Using the soft keys under the display, press MORE, then MGR, then CHBX or, follow voice prompts if non-display phone.
Follow voice prompts. Remember, 1=Yes, 2=No.
Mar 10, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
How to put my extension back into to system at greeting time
If you change recordings on a voice mail box that does not change the settings for the mail box location. There will be a section to enter the name of the mail box owner (not a recording) and that is used for the directory.
I am not familiar with NEC voice mail systems but typically you can have different voice mails and different versions of phone system that all program differently. You should have an "administrator" guide for your voice mail so someone can make changes like this. I have no way of helping you find this and it will depend on your voice mail NOT the model number of your phone which can be used with different systems and voice mails that all program differently.
Jan 22, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Will Not go to voice mail
Jennifer209, if you press FEATURE + the button VM is pre-programmed on what does it display? It should show the extension number pilot to VM. If you call it directly, what happens? If you get no answer calling it directly, your VM may be down.
Kaait, is it getting into the VM that's the problem, or doing things inside the mailbox that is the problem?
Nov 21, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
NEC Electra Professional ETW-16DC-2 Logo
244 people viewed this question
Top NEC Lands Phones Experts
Steve Allison
Steve Allison
Ekse
Norman Al-Anbar
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
