Question about Bose (321GS) System
The CD/DVD media center will not eject. How can I fix this?
    President:
  • 1,099 Answers
the problem could be from the rubber attached to the motor of the mechanism of the player, check if the rubber is slack or cut , If found any replace with a new one of the same size. If otherwise replace the whole of the mechanism for better effectiveness.
Thanks and take care....
Posted on Jun 01, 2010
2 Suggested Answers
  • 4 Answers
SOURCE: We have a dvd stuck
See original post below for help.
http://www.fixya.com/support/t329722-bose_321_dvd_stuck_open
Cheers
Posted on Oct 31, 2009
2008 cadillac 6 disk dolby dvd/cd sound system will not play or eject disk
Alien is right, pull the Radio Fuse, then put it back in and eject the CD/DVD. Happens to me sometimes with burned DVDs, seems like the player is picky on the CD/DVD media. Rebooting the device (by pulling the fuse) is the only way to eject it.
Dixit
Dec 02, 2012 | Televison & Video
My dvd player doesnt do any thing. it doesnt eject or read any cd or dvd, although I have reinstalled the operating system, i.e. xp, by another dvd writer. Still it doesnt eject or readout discs.I thi
Have you gone through the add/remove hardware? Do you have a compatability wizard, or tried the setup wizard? Check out WINDOWS "Fix it center". I know they have a program that analyzes your hardware, and tries to help you fix any problems. GOOD LUCK
Jul 02, 2012 | LG Computers & Internet
I can't open my DVD-Rom drive and it doesn't read the information in my CD drive? It's an HP Media Center PCm7334m, computer.
  1. Software can lock the CD drive preventing you from ejecting. If this is the problem, turn off the machine, turn on, when the DELL screen flashes, push the eject button several times and the CD will eject.
  2. If that doesn't work, look for a small hole the size of a paper clip and gently push a paper clip into it. When you meet resistance, the drawer will start to open. You can then pull it open carefully. The computer can be off when you try this.
  3. If neither work, then you might have a jammed CD, i.e. incorrectly inserted. You can try to force the drawer open with your fingers but don't use so much force you strip the plastic gears.
Aug 14, 2010 | HP Pavilion Media Center TV m7330n...
Eject does not open
Most hard-drives do *NOT* have an EJECT button.
Most diskette-drives *DO* have an EJECT buttton.
Most CD/DVD-drives *DO* have an EJECT button.
Turn your computer off. Straighten one end of a Norwegian paper-clip, and insert it into the small hole in the front-plate of the CD/DVD drive, until you feel "resistance". Then, push it another 1/4 inch, and the drive-tray should "unlock" and open slightly. Then, gently pull the tray fully-open. Remove any CD/DVD media. Then, replace the CD/DVD drive.
Jan 29, 2010 | Computers & Internet
My dvd drive wont eject since i ripped cd's on windows media player it froze and then wouldnt eject te cd
well on the CD drive u will find a pin hole which is used to eject the drive tray manually so use a pin and try to eject the CD.
good luck
Jan 05, 2010 | Acer (KV.16X04.007) DVD Drive
I have a laptop that doesn't have eject button for slot cd player
go to Dektop / My Computer
right click
u will c all the drives....i mean..... c: d: etc
locate ur CD/DVD rom drive,..letter...d: or e: etc..
select ur CD/DVD rom drive
right click and chose option Eject...
u r set...
Dec 20, 2009 | Toshiba Sattelite A105-S2051 Notebook
When i try to burn a cd in windows media player it ejects the cd
You are asking for help with a DVD but you say CD in the body of your question ... are you have the correct media in what ever device you are using?
Not all DVD burners can burn onto a CD. Some DVD are only capable of writing to specific types of DVD media as well ....
I hope this helps you.
a
Oct 04, 2009 | Samsung (SH-S162L/BEBN) DVD RW Burner
DVD/CD door stuck on Bose 3 2 1
On the 321 systems turn off the power and unplug the power cord from the bass module. Wait 5 minutes and plug it back in. Then, simply hit the "stop/eject" button on the media center itself (do not turn it on first)..this should release the tray unless there is a mechanical failure inside the tray mechanism itself.
Thanks to Matthew O;Neil for the the tip,...Italo
On a Lifestyle system with a tray that won't open, try this: Turn off the power to the system and unplug the power cord to the back of the media center itself. Wait 5 minutes and plug it back in. Then, simply hit the "open/close" button on the media center itself (do not turn it on first)..this should release the tray unless there is a mechanical failure inside the tray mechanism itself.
If this does not work, then call Bose when you are home with the system at 800-367-4008.
Nov 05, 2008 | Bose (321GS) System
DVD DRIVE WORKS, BUT CD DRIVE DEAD
Try using the manual eject that is as small as a pinhole just below or beside the CD drive. Once you find out that you can manually eject you may be able to insert a cleaning cd to clean the device.
If that doesn't work check device manager to see if it has the proper driver or if it's recognized that it's installed in the system.
Jul 16, 2008 | HP Desktop Computers - Hewlett-Packard...
Disc won't eject
Hi, to open thje the disc tray , look for a tooth pick , insert small hole in front panel push and back until disc tray out. , motor belt need to replace.
Jan 19, 2008 | Teac (DW-224E) DVD Drive
Bose (321GS) System Logo
583 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
