ZENITH XBS341 WILL NOT EJECT, ''WHIRRING SOUND?''
    President:
  • 1,099 Answers
the problem could be from the rubber attached to the motor of the mechanism, check if it is slack or cut. Replace if found any to same size.If otherwise you need to change the mechanism of the DVD player for better effectiveness.
Thanks and Good luck...
Posted on Jun 01, 2010
I have five discs in there. The drawer won't open. I can hear whirring noise.
You can try unplugging the unit and waiting a few minutes and then replug and reboot the player. If it still does not work you might want to check the eject mechanism for operation. Maybe a blet slipped off a pulley?
Apr 06, 2015 | Audio Players & Recorders
The tape won't eject. press any button and nothing happens makes a whirring sound
I would take the top cover off the machine and see what is happening inside. It's clearly trying to get the tape out from the noise.
Aug 23, 2014 | Mitsubishi HS-U410 VHS VCR
MY DVDROM STUCK I AM UNABLE TO EJECT IT
You can try a manual eject by taking an unfurled paper clip, and sticking the end into the tiny hole on the faceplate of the optical disk drive.
Apr 22, 2010 | Zenith Data Systems Zenith (OP-260-74501)...
The dvd will not eject just makes a whirring
There is always a small hole in the front of the tray. Insert a pin through it and press gently when it encounters resistance. The tray will open.
Jan 18, 2010 | Televison & Video
3 discs are in machine. Played one disc and then wouldnt play others. cannot eject any discs. Hear a whirring sound but doesnt pick up disc
The dvd mech is out of aligment.This is a common problem with this model.you will have to take out dvd mech and remove disc manually,
Aug 02, 2009 | Sony DAV-C770 System
CD won't eject. I have tried the button on the drive and clicking the eject through the software. The light lights up and there is a whirring sound, but then nothing.
your cd rom tray is stuck inside may be due to a hardware error please take a paper clip and make it straight now insert this clip in a small hole located at the front panel of your cd rom drive..apply some pressure and the tray will be ejected/..
Thnx and i hope this helps
Please rate this solution
Jul 16, 2009 | Dell (0F146) Internal DVD Drive
TV DVD VCR combo eats tapes and now won't eject DVD's
Its shot, time to get a new one. dvd players are now only $20
do you have a newer lcd tv. Id say look into getting an upconverter,itll play your dvds at 1080 :) better picture.
Feb 27, 2009 | Philips Magnavox MWD200G DVD Player
VM9511TS wont eject
Does it make noises like it's trying to eject? Like whirring motors?
Sep 10, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Problem with system
I have two of these units and have identical problems. Noticed that the cooling fans do not come on so suspect the amplifer is overheating and there may be a thermal sensor that shuts the unit down.
Dec 05, 2006 | Zenith XBS341 System
Loss of Speaker Test, Progressive Scan option, FF/RW Scanning, and DTS Sound
First thing to try, would be to unplug all your equipment overnight to see if the microprocessors reset. If your still having problems , then you have a firmware problem and you should contact the manufacturer to see if its downloadable and upgradeable. Good Luck
Aug 12, 2006 | Zenith XBS341 System
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
