Question about Samsung CLP 300 Laser Printer
Will not print
Error message dev.home
  • 328 Answers
Change cartridge chips or all.
Posted on Jun 01, 2010
Samsung CLP-300 'dev. home error'
Dev. Home error can be fixed by stretching out a solenoid spring on the power cord side of the printer. The solenoid acts as a clutch to stop the spinning developer actuator at the right spot.
The problem is that the spring gets weak over time / the cogs round out over time and the solenoid finger is overcome by the spinning cogs, and resulting in selecting the wrong developer.
Open up the right side (power cord side) of the printer (take off top cover, then take off side cover). Then, find a solenoid (little metal square) that touches the white plastic vertical spur gear. Take the spring off the solenoid. Now, put the spring back on - only this time you will attach one anchor point to the middle of the spring as to pre-stretch the spring for more tension.
More pictures of the solenoid on Facebook:
http://www.facebook.com/#!/photo.php?pid=55779771&id=2257206&fbid=10100154259704133
Dec 26, 2009 | Samsung CLP 300 Laser Printer
Samsung clx-3160 fn not printing flases DEVE HOME SENSOR ERROR
if the printer is flashing developer home then the developer unit is not situated correctly or the contacts are dirty causing the printer to not recognize the dev unit clean the contacts with denatured alcohol on the dev unit and where it makes contact within the printer and power back up.
failing that the dev unit may have expired requiring a new one to be installed.
if this answers your query and fixed the issue please rate me accordingly.
thanks
Sep 14, 2009 | Samsung CLX 3160fn All-In-One Printer
Deve home sensor error
You could try replacing the Image Unit (but these are quite expensive). This error actually refers to an optical sensor located in the gearbox (RHS of machine). The sensor controls the drive to the individual dev units, hence the "dev home error" if it malfunctions.
Probably a job for an engineer.....
Jun 19, 2009 | Samsung CLX 3160fn All-In-One Printer
I have a clp-350n samsung colour printer. Prints B+W images fine. When a colour image is sent to the printer the printer runs and runs and runs but never prints anything. It's as if the imaging belt can't...
There is an "opto coupler" in the main drive gear unit (right ride of machine) which controls the drive to the toner/dev units. If this (or part of the drive) is faulty it will give this error.
Jun 17, 2009 | Samsung CLP-315W Laser Color Printer
Brand New printer status led RED, Smart Panel error "dev home"
Samsung CLP-315 Dev Home error
It appears that the Dev. Home error is very common for Samsung printers. It obviously has different reasons. In my case I solved it by stabilizing the deviation clutch. It was too unsteady and the dev. sensor recognized a fault.
The dev. clutch is situated under the right cover, which is the power supply side of the printer. To remove this cover you need to firstly remove the top cover, which is held by two screws on the front. Then uncover the right side by unscrewing one screw on the back, near the power supply inlet and unclip a couple clips on the top side of the cover. After removing it you have to find the deviation electrical clutch. Check if it is too unsteady. If it easily moves, you need to somehow stabilize it, in my case by a couple of leather straps under it, so that they press it up and make it steady: 5_19_2012_1_08_58_pm.jpg
After that simply check if you have stabilized it properly. If you have the green light must turn on after switching the device on.
NB! Be extremely careful when power is ON, because there is high voltage running. I'd suggest that you would stabilize the thing with non metallic item to keep safe. Good luck!
Apr 13, 2009 | Samsung CLP 315 Laser Printer
Im getting a DEV. HOME ERROR MESSAGE! PLEASE HELP?
The Image Transfer Belt (ITB) is not correctly installed or defect.
Pull out the Drum Unit (open front door and take out the hole assambly) Than you can look on the ITB, you can pull it out, it's a bit ricky to get it in position again.
Mar 19, 2009 | Samsung CLP 300 Laser Printer
Home dev. error
reinstall the affected dev assy, or try to removed and put back again
Oct 25, 2008 | Samsung CLP 300 Laser Printer
SamSung CLP-300 laser color printer does not print. Status red light is on all the time. When check with service center they said it is Dev.home error and take it to service center. What is the problem...
I had the same problem and look it up in service manual,
there the say Home of development is not checked or checked at a abnormal time. solution Clutch of development or mainbord must be checked.
when i opened the right side cover i vind out that the development clutch moved two parts do it was suppose to move one part, when i tightened the spring on the solenoid the problem was over and the clutch stopped at the right place. its easy to do.
Aug 03, 2008 | Office Equipment & Supplies
Error Messages
The false Jam at MP E is a common error caused a manufacturing error/problem. You can download a solution to this problem HERE.
The K dev unit error can only be removed by replacing the dev and completing the service mode adjustments. A service manual will help you with this issue. Get one HERE.
Jun 06, 2008 | Epson Aculaser C1100 Printer
Samsung CLP 300 Laser Printer Logo
386 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
