Question about Mastercool 67680 Evaporative Cooler Air Conditioner
Why does there have to be a 'bleeder' line from the drain pan of a Master Cooler? Shouldn't the float keep the optimum amount of water in the unit?
  • 3 Answers
The previous answer is wrong. He describes an overflow line not a bleeder line. An overflow line is not optional for the reason previous answer describes except that if you go away for vacation or other reason the water to the cooler should be shut off.
On the other hand a bleeder line is optional but highly suggested.
The purpose of a bleeder line in any application like brake systems and evpaorative coolers is to get rid of some unwanted elements. In brake lines air is the unwanted element. In evaporative coolers it is particles, scale and mineral build up. This happens because the constant evaporation ( the whole principle of water coolers) leaves behind particles, scale and mineral. without a bleeder line these things build up in the water reservoir. You flush your system manualy with a bleeder line or with the right control box and a separate pump it can be done automatically. If you do it manually, let it run long enuff to discharge at least as much water as your reservoir holds. direct this flow to plants so a not to waste the water.
Posted on Jun 09, 2010
    President:
  • 3,433 Answers
Floats shut off the water at the proper level and alows filling when level is inadequate. Let's say that for some reason,a roof or wall unit is exposed to inclement weather without proper covering. The matting will cuse what ever liquid that hits it to drain into the pan, or sump. The plumbed supply will shut off if the float or valve doesn't malfunction. If you were away when such failure occured, The water would motr than likely find places to go which you eould prefer it not. Summary: It's a backup flood avoidance necessity. :-)
Posted on Jun 01, 2010
Water draining from underneath the unit on and down the window on the outside. This is running down the wood of the sill. There is also a great amount of it collecting in the pan, almost to over spill...
most window units use the water in pan and throw it upon condenser which evaporates it. need to check if its level side to side with a slight tilt to the back in window.
Aug 12, 2014 | Friedrich QuietMaster Deluxe RS12L10 Air...
Dishwasher keeps making suction sound though cleaning cycle is done
You made have a leak causing the drain pump to keep running, if you never worked on this unit before I would suggest you call a professional. If you have worked on this before then look for water in drain pan to unit, the reason is water has entered drain pan and caused the float to turn on pump, could be from the drain hose, leak in a hose, or the diverter. all this part are located unit unit in access area (small panel under large door).
Good Luck, I hope this helps...
Jul 21, 2011 | Viking 24 in. Professional Series VUD040...
My coleman rv ac unit is dripping condensation inside the camper, what is causing that?
It is possible that the drain hole on condensate pan is plugged and causing water to over flow pan. Remove cover from unit and check drain line.Clean coils andpan as best you can and clear drain hole. Add a small amount of bleach to water in drain pan.This will kill any algea or bacteria that may be growing in condensate water and plugging the drain. Thank you
Jun 20, 2011 | Coleman Mach III Air Conditioner
My 97dodge intrepid is leaking oil and i want to know where is the oil pan?
Hi. You might need to Replace the oil pan gasket is the oil is leaking. Here's the procedure on how to Replace the oil pan gasket.
1. Jack up the front end of the car and slide a jack stand under the vehicle. Make sure the jack stand is securely in place, and then put blocks in front of the rear wheels to keep them from rolling.
2. Slide under the car and put a drain pan under the drain plug of the oil pan. Loosen the drain plug with a socket wrench and allow all of the old oil to drain into the pan. Remove the old oil filter.
3. Disconnect the negative battery cable and remove the dipstick and its housing. Remove the collar on the rear of the oil pan. If the vehicle is equipped with engine oil cooler lines that lead to the oil pan, remove them as well, along with transmission oil cooler clips.
4. Remove the bolts holding the oil pan, and carefully remove the oil pan. Remove the old gasket. Scrape it with a putty knife if necessary, but be very careful not to scratch the surface.
5. Wipe out the oil pan with a clean cloth or paper towel, and wipe the joining surface of the oil pan with cleaning fluid or solvent. Apply a thin bead of automotive sealer and install the new gasket.
6. Replace the oil pan, tightening the bolts securely. Replace the transmission oil cooler clips, engine oil cooler lines, oil pan collar, dipstick housing and dipstick, and reconnect the negative battery cable. Install a new oil filter.
7. Take the car off the jack stand and fill the engine with the appropriate amount of SAE 10W-30 or SAE 5W-30.
All the best!
Nov 09, 2010 | 1997 Dodge Intrepid
Our Bryant air conditioner that we bought a year ago started leaking water yesterday but was still working. It isn't working at all today even though the thermostat says "on". Is there a way to reset it?
These symptoms usually indicate a problem with the drain. If the drain for the evaporator is restricted it may leak, if it leaks enough it will activate a float switch that turns off the air cooling unit.
The first thing you need to do is locate the evaporator, depending on where you live and what type of home you have it will be in the basement or the attic most likely. There will be a pan under the cooling coils, if in that pan there is water then your drain for the cooling coils is plugged. Look above that pan for another drain line that is the one you need to clean out.
In the pan that has the water you will find some type of float or water switch that is keeping the A/C from coming on.
Send me a message here if you have questions.
May 29, 2010 | Bryant Heating & Cooling
Nor-Lake walk-in cooler water leak
The evaporator drains into pan with a coil from the discharge line. The design is intented to sub-cool the liquid refrigertant as well as evaporate the condensation from the coil. Unfortunately the engineer started as career a shipping clerk and never received any further training.  There isn't enough heat or running time to evaporate the condensation from the coil.
The solution is fairly simple
A plastic tube  drains water out of the evaporator in the pan. You can extend the tube and add a defrost pan handled by your refrigeration wholesaler. Wire it so it is on whenever there is power to the unit.  This should get rid of the excess water. These pans are also used on some self contained coolers and freezers. They come in either 120 volts or 220 volts. kasgirls@tds.net
Jul 12, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Do not know how to work/maintain swamp cooler
Make sure you have water to the unit, the water pump is on and the fan is working. No water=no cooling.
Apr 21, 2009 | Mastercool 67471 Evaporative Cooler Air...
Drain pan fills daily
does drain pan have copper lines it
Feb 12, 2008 | Viking VCSB483 Side by Side Refrigerator
Hotpoint MAC-130 air conditioner dripping water
You need to blow out the drain line where it hooks up to the pan and clean out the drip pan. It doesn't matter how clean you keep the filter, that's just to keep the evaporator coils clean, which is important in itself. But algae will grow in the drip pan if it is not tilted to drain correctly and will clog up the drain line. If you put a level on the top of the unit, the bubble should JUST BARELY break the line on the OPPOSITE side from the drain outlet on the pan. Hope this helps.
Jan 25, 2008 | Heating & Cooling
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
732 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
