Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
HRS appears on the top of the refrigerator and both sides are not running but there is light, water and ice does not dispense also
    Problem Solver:
  • 14 Answers
The light and the compressor are on different circuits. Where the power goes into the unit, there is a sepperation from the compressor and the other electronics. It sounds like one of the main fusses have blown. Be sure to unplug before checking. A good volt-ohm meter will find your problem.
Posted on Jun 01, 2010
How do i access the ice dispencer door in the door? The door is stuck open and freezes up the dispencer.
1. Disconnect the unit from the electrical
supply and wait for 3 to 4 hrs to get ice melted.
2. Pull out and unclip the drip tray on the ice
and water dispenser compartment.
3. Remove the screws from the ice and water
dispenser compartment front panel and
turn it over. The selector switch pack and
dispenser switches are now accessible for
testing.
Jan 29, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice and water dispenser not working but light on constantly
We had the same problem. When we removed the ice receptical the mechanism that turned the ice make was broken and it stopped the ice from being dispensed. I hope it is that simple for you!
Aug 15, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
The motor that runs the ice dispenser is not running.
Check the ice bin, if it is full, emty it. Then run warm water through it. dry it and put it back. Wait A while(24 hrs.) to see if it is makeing ice again. then try your dispenser.
Jul 08, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice/Water Dispenser in Freezer door not working when you press the lever. Also the light dims when lever is pressed. Icemaker working fine.
Sounds like a frozen waterline. I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Nov 28, 2007 | GE GSS20IEP Side by Side Refrigerator
GE GSH25JFRWW
Water line is frozen in freezer door. I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Nov 27, 2007 | GE GSH25JFPWW / GSH25JFPCC Side by Side...
Ice/Water Dispenser Not Working...
suspect you didnt connect plug and socket wiring at top of door properly
Mar 19, 2007 | Whirlpool GS6SHAXMQ Side by Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
66 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
