Question about Abit A17 Guru Motherboard
Abit Guru Ai7 Hard Drive Problem
All righty.....
So I looked at the other boards on what the cause of the pc not booting past the first windows loading screen....but is there a way I can format my pre-existing hard drive without a complete back up/reinstall/and then reload?
    President:
  • 2,351 Answers
Simply....... no. Once formatted it's reinstall time.
You can load you're windows cd into the cdrom drive & try to get windows to load. If you do get the cdrom to load - (Press any key to load from cd...... ) & press any key. Once in windows setup ( DO NOT format the drive) but do reinstall windows, if windows see's another windows on your drive, great install over it. If windows does re-install it's self you should have enough time to install burner software & back up your personal data to CD or DVD before your partition looses it's cookies & shuts you down.
You can also leave it alone & install another drive & setup windows complete & slave it back into you're system for IDE.
SATA's are all master drives. Than copy your data back to you're new drive. In these cases I always suggest the user go to the web site of the hard drive & download the Mfg's bootable software tool's/setup utilities. Windows is not perfact at formatting.
Luck!
Mike
Posted on Apr 09, 2008
SOURCE:
Motherboard won't boot past cmos
you are pretty much right it may be a corrupt bios, however before we come to a conclusion try isolating both Seagate Barracuda 7200 rpm 80gig ide hard drive and optical drive only and then see if it at least goes past the bios screen, if yes then the bios is ok and just needs to be resetted to defaults. dont expect it to load windows even if it goes past bios check as hard disk which helps to boot to windows would be removed. also in case if you are using 2 ram slots try connecting only 1 ram chip in 1 slot and then see if it goes past the bios test screen. do reply with results. Good luck.
Feb 08, 2012 | Abit Computers & Internet
Have an Abit A17 motherboard that stops booting with a check sum error. Code on the digital readout is either IA or 1A, neither of which is in the manual. Any idea about this?
Press delete as the system boots up and go into BIOS Setup.
Change boot sequence so that your machine starts with the CD/DVD ROM disk.
Boot from the CD/DVD and do a clean installation.
Jul 15, 2011 | Abit AI7 Motherboard
System powers up for a second then cuts off, led reads 01 (press power) 83 F 3 powers off
One bad lead will cause your computer to shut down or continue in a cycle
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to your hard drive
hope this helps
Oct 26, 2010 | Abit AI7 Motherboard
I cant find drivers for the mother board
If you open the link provided you'll find all the drivers for your AI7 socket 478 motherboard listed;
http://www.abit.com.tw/page/en/download/download_driver_detail.php?pFILE_TYPE=Driver&fSEARCHTEXT=AI7
Thank you for using Fixya!
Cheers
Mike
Aug 13, 2009 | Abit AI7 Motherboard
No audio device
First check if your motherboard has audio output. If yes, then install audio drivers from the CD provided with motherboard or download from net. This should solve the problem
Mar 14, 2009 | Abit A17 Guru Motherboard
Two tone Siren from MoBo/over heating CPU
at first go to the bios. then default the bios setting. then check the system monitor. if the cpu is too hot you can see it. or you can change the processor. never over clock the processor.
Jan 20, 2009 | Abit AI7 Motherboard
A17 wont boot
ok what board is it
#then check the manual for error post code error af
if not try another card liek a pci one
or agp one
Jun 06, 2008 | Abit AI7 Motherboard
Abit Guru AI7 Windows Freezing
Hi Tinker_McGee, after installing you're virus protection did you run a full system scan? To make sure there is no virus being held in memory, please shut down the PC. Unplug the power cord. Remove you're memory for about 15 seconds & than firmely reseat. Reconnect the power cord & load windows. Shut off windows system restore. (Right click on My computer once & left click Properties. Click System Restore tab. Leave off until you run a full scan.
What is the name of you're hard drive? (If you say Maxtor), that can be you're problem. I personnaly know alot of people whi have had nothing but weird problems with their Maxtor hard drives.
I gather from you're last post everything went well for a little while during set-up of you're drive.
So, if it's not you're hard drive it can be any other device causing lock-ups. Let's try this. Boot the PC into you're bios.(Press the delete key every two seconds till you're at the main menu of you're bios). You want to go to, PC Health Status. Here you should be able to monitor the CPU's temperature & the mother board's temperature along with voltage & the CPU fan speed.
Stay here in the bios for awhile. Just walk away for about 10 minutes. We want to make sure the PC is not overheating or that the CPU's fan speed has dropped too far. Next, lets test you're memory. This might be hard to do if you're system keeps freezing because it involves downloading from the internet. Goto this link. http://www.memtest.org/
Scroll down the page till you see, -= Screenshots =-
Just below the three pictures is,
** Memtest86+ V2.01 (21/02/2008) ** Typed in red. Pick the file of you're choosing. Since windows is giving you a hard time, I suggest you download the bootable floppy disk software.
Download - Pre-Compiled package for Floppy (DOS - Win)
You can download the bootable CD software if you wish.
Once done, test you're memory. The only removable device is you're video card & I do not think it is that. Unless it is overheating. Over all everything you are doing is installations.
Installations primary device is you're hard drive. Last 2 questions. Did you connect a small internal speaker on you're board? When you boot the PC do you hear POST a single beep?
Keep me informed when trying the above.
Again Good Luck!
Mike
By the way, you do not need to keep posting in a new window when replying to the same problem. All you need to do is this.
How to vote you're expert.
Also how to repost more questions for same problem..
Enter FixYa.com site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
Under the solution given by the expert, choose.
Apr 15, 2008 | Abit A17 Guru Motherboard
Hard drive
u can use any hard drive seagate or samsung but u need to configure the hard drive
Oct 16, 2007 | Abit A17 Guru Motherboard
Abit A17 Guru Motherboard Logo
99 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Ekse
Bart Fonteyne
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
