Question about Asko W6222 Top Load Washer
Can,t get trap out to clean and check pump
Cover comes off trap wont come out how do you remove trap appears struck
  • harperswaste Jun 01, 2010
    the cover comes off but the trap stays there cant move it how do I get it out
  • Asko Master
  • 12,061 Answers
194.14.129.136/brandsite/DocumentOpen.aspx?did=7070&mid=25...
http://www.repairclinic.com/Washing-Machine-Repair-Help
Open drain trap door with flat head screwdriver, open drain cap CCW, Use a tool if stiff.
Posted on Jun 01, 2010
    Brigadier General:
  • 3,513 Answers
Thanks for contacting Fixya.com
Try sliding a putty knife between the door and frame and see if you can unlock it. try emptying the water tank and then if it still won't open then there should be a little orange plastic tab with a screw in it in a little compartment near the floor (where you can drain more and check to see if the lint/hair/coin trap is full...btw have towels and a pan ready if you're draining).
Let us know if you have something more to know else please accept the suggestion.
Thank You.
    President:
  • 1,554 Answers
The trap can be removed by unscrewing it counterclockwise and pulling it off. Most likely there is something trapped in the trap that blocks it from unscrewing. Remove the trap assembly for you to be able to dodge it and release the debris that might be blocking the trap from unscrewing. Indicate the exact model number should you need further advice.
  • Jahn27
    Jahn27 Jun 01, 2010
    It is more preferable to provide the requested information if the issue is not addressed by the first solution or advice given instead of requesting additional feedback from other expert without providing additional information as the troubleshooting start again from the beginning. The advice provided is based on first hand experience and on the
    information provided. Good luck to your quest.
  • Jahn27
    Jahn27 Jun 01, 2010
    You don't have to accept or rate the solution in order to post comments or additional information.
  • 8,197 Answers
May I get the make and model # to help you more.
How to clean the drin filter
If there is enough room put a large adjustable or water pump pliers on the cover,i used the adjustable and put a screwdriver through the hole in the end and very gently applied pressure until in moved, I sprayed a little lube in the space between the cover and housing and it came off much easier then. There was so much debris in the trap and it stinks really bad, a large dish is needed under the cover as a lot of water will come out. Clean out the trap and reassemble using vaseline or grease to help the o ring seal.
May 23, 2014 | Maytag MHWE200XW Washer
How to clean the pump
Remove the bottom front panel. Perpare for water coming out, so have plenty of towels, place them in and around the pump. Remove the trap slowly, once the water is all out you can remove the trap completely. check in the trap housing as well as in the port to the pump. If you require further help I am here.
Feb 13, 2014 | Whirlpool Washing Machines
I have an F09 code, why??
check your drain pump it is at the bottom of unit and can gain access by removing front cover there are 3 screws near floor and panel will come off. have towels ready and clean out your drain pump waste trap...try again
good luck to you
Dec 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer wont agitate or spin
kind of a vague description, but likley cause is a bad or clogged drain pump, not allowin water out to spin, removing bottom cover will gain oyou acess to "button trap" portion of pump housing..
uunscrewing "button trap" willallow you to clean oout debris, but be warned that any wate in tub however little or lot there isin machine will also be coming out as well.i genreally grab a black plastic garbage bag and surround the opening prior to unscrewing the trap cover to catch the deluge of immenent water!!!!
usually determine this as well, if by turning off water supply, then select the "drain spin" cycle. Start the machineand in a bout10 secs or so youll usually hear teh pupmp activate, but instead of mvoving/drain water it simply sits ther HUMMING..
May 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Runs through the wash wont drain properly
Two issues must be checked out.
First of all the drain pump must be checked for voltage to it, if present then the pump is struck and must be cleaned of dirt. remove and clean filter and reset.
if there is no voltage on the pump then the failure of the driver section in the controller is possible.
Dec 16, 2010 | Dishwashers
I start the machine, it runs till it would appear that it is full of water and ready to start to wash, then shuts off, displaying a message saying "Unable to fill - check water supply" IF you then push the...
disconnect machine from mains electric supply. remove top cover of machine then check the back of the control panel for a small black pipe, it should be attached to a small nipple in the panel rear if it is not you will get the fault you describe. if the pipe is connected remove it and blow down pipe with your mouth or a foot pump to remove any blockage then reconnect it and try the machine again. check also that the pipe is not trapped or kinked too i hope this helps you
Oct 14, 2010 | Dyson Memory CRO1 Front Load Washer
Inop.
Below is for Whirlpool/Kenmore, u might find it helpful. Some machines have a small trap door on left front bottom, coin trap.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
Pl rate me nice for the free help, thnks
Jun 04, 2010 | Frigidaire GLTF2940ES Front Load Washer
Display show f21 and it wont drain
the f21 code actually is a no drain code....the machine has an electric pump behind the cover on the bottom with a lint trap in it....just unscrew the lint filter from the pump(there will be alot of water coming out when you take this out) and clean the trap and that should take care of your problem
Oct 01, 2009 | Kenmore Washing Machines
How do i remove the pump off my bosch dishwasher,as bottom 1 unit, any tips wont empty water cleaned all traps. is the a pump solenoid?
inside the dw remove all filters and in the sump there is a cover over the impellor with 1 self tapping screw remove and there could be a object stopping pump.
Sep 14, 2009 | Bosch Dishwashers
E20 message I get on my washer machine
Apr 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Open Questions:
See all Asko W6222 Top Load Washer Questions
Asko W6222 Top Load Washer Logo
142 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
