Question about Whirlpool ACQ244XL Air Conditioner
Wiring diagram for whirlpool ACQ244XPO
I want to know how the wires connect to the switch and capacitor. thanks
    President:
  • 949 Answers
Here is a link to the wiring diagram
ACQ244XP
Posted on Jun 01, 2010
Replacing motor on my ruud furance
you should have a wiring diagram on the top of the motor to tell you what each wire does. compare both motors and see where the wiring goes.
Nov 08, 2014 | Heating & Cooling
Motor wiring diagram
A suppression capacitor has 2 wires and can be have red and black wire pair, and a motor have 2 wires from the electric field to the carbonbrushes and 2 other wires from the magnetfield goes to the switch and on the same wires can be connected a parallell suppresion capacitor connected bud in most cases its not needed in practice.
The other 2 wires have to come from the powercable on the switch the most grinders to find in shops are class 2 angle grinders with double insulation, But If this is an bench grinder there must be a class 1 cable used with 3 wires to earthing a metal point on the housing. look always for the 2 square symbol its class 2 and cable has 2 wires otherwise 3 .
Aug 14, 2014 | Grinders
Looking far data sheet or equivalent circuit/connection diagram for a 97F9834 capacitor
You can find a datasheet located here. Page 14 contains your capacitor's information. As for a connection diagram, it's fairly simple. The dual capacitor (three prong) has a connection for fan, compressor, and common. Common (typically white) goes in the middle, compressor goes to herm, fan goes to fan. You should see the labels etched into the metal either on the side, top, or bottom. As for the colors of the fan and compressor, the brown wire should be for the fan, and the compressor's wire should be yellow. Of course, your system should contain a wiring diagram, which is usually attached to the door. Consult this diagram before assuming any wire colors I tell you are correct. Also, you should have some form of cutoff switch. Ensure this switch is OFF before doing ANY electrical work on your system. 220v in AC units WILL KILL YOU, especially coming off the capacitor. Best of luck!
Tj
Aug 18, 2011 | GE Heating & Cooling
Ceiling fan capacitor hook up problem. I have a 3 speed fan. 4 switch. A 3 wire capacitor - CBB61. Kids lost wiring diagram. Any which way I try to wire it up only one of the speeds works. Any wiring...
The reverse switch on my Hampton Bay ceiling fan didn't work. I cut the 6 wires; 1 white, 1 gray, 2 pink, 2 yellow. Here's what I did. Removed reverse switch. Had 6 wires white, gray, 2 yellow, 2 pink. Connected gray to yellow, connected white to pink and fan runs fine. Is this OK? I do not need to reverse fan. It's been running for 1 hour now with no problems. Don S.
May 15, 2010 | Dryers
I'm looking to replace the fan switch for a hampton bay ceiling fan, but I don't know where the wires go. The colors of the wires are black, yellow, purple, and orange, and the slots on the switch are L,...
This is fairly simple.
Assuming you have a black brick capacitor, and assuming you have the correct switch, for capacitor speed control.... (if you don't you will not blow anything up)
On your capacitor, there should be a set of two wires which are the same color. Black goes to L The two wires which are the same color, one will go to position 1. The other two wires, will go to 2 and 3. On the capacitor it should have some numbers and crude diagram with the color of wire on it. The wire with the highest value (say it's 6) will go to position 2 and the lower value will go to position three.
If you only have one small capacitor in the switch housing, (usually a red and white wire one) then you have a winding taps speed control. If you have a capacitor type switch, you can burn out your motor, as on the second position of that switch it activates both 2 and 3 (or medium and low) Be sure you have a switch which operates as such L+1 L+2 L+3. If you have the proper switch, then all you need to do is connect the black wire to L and then randomly place the other three wires into the switch and test it. Most likely the speeds won't be right (it might go medium, low, high) if it does, then just move the wires around until it goes high medium low.
Mar 31, 2010 | Oasis Hunter 54' Ceiling Fan
Wiring up a pump with capacitor and pressure switch
This is a confusing explination of your problem. Elect is dangerous and should be left to profectional's
Jul 02, 2009 | Pool & Spa
I replaced the on/off switch in my QEP 60020 tile saw and I need to connect it to the right starting capacitor and run capcitor. I need a wiring diagram or schematic so that I can get it right. Can you...
hi jloyyd,
the wiring diagram is not available online but through the service manual for the unit only. If you can show us a picture of the connection port of the saw and the capacitor to be installed, we can tell you how to install it the right way.
should i find a service manual online, i will let you know right away
regards,
voodoo
Jun 12, 2009 | Garden
Older sears bench grinder wont run 1/3 hp model 397 19581
Hi again, OK, Well since I don't have a wiring diagram and the colors don't help. I am also going to assume it is 110VAC. The larger wires are probably the run or primary, it you remember which ones were connected it will help with polarizing. ( getting it to run in the right direction as well as the start and primary working together). You can use the two terminal switch but you should use a three wire cord. Use the switch to break the neutral and ground the case. The connections should be as follows: Connection 1, would have one of the primaries and one of the starts to neutral. Connection 2, the other start to the relay. Connection 3, the coil side of the relay to the remaining primary. ( if the relay has two connections on one end and one on the other it would be the single) Connection 4, the 3rd position on the relay to hot. That is how a split phase is wired. You may find a simple wiring diagram on the net if you type split phase motor wiring diagram. Good Luck to you, this should Fixya!
Mar 04, 2009 | Grinders
WIRING OF 3-WAY SPEED SWITCH FOR HAMPTON FAN
1 - Red/Pink
2 - Purple
3 - Yellow
L - Black
Mar 11, 2008 | Oasis Hunter 54' Ceiling Fan
Whirlpool ACQ244XL Air Conditioner Logo
545 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
