Question about Danby (DAR604BLS) Refrigerator
I have a danby propane refrigerator model
I have a danby propane refrigerator model DPR-2260-2cd. The rubber gasket that is in the main propane hook up is gone and danby said they dont sell parts for this model anymore. Anyone know where i can get this gasket or the full unit. its the unit that controls the propane that enters from the tank. when i took the unit apart it was the gasket that under the ball bearing on a small shaft
5 Suggested Answers
SOURCE: Our Danby propane refrigerator has
Having a simular problem; try changing your regulator on your propane tank. I'm try to find a new thermostat myself. Good Luck!
Posted on Aug 03, 2008
  • 744 Answers
SOURCE: Danby Ignis Refrigerator light isn't working
See this link and scroll down to see information about parts for a Danby refrigerator:
http://www.rekitchen.com/refrigerator/brands/danby.html
Posted on Mar 22, 2009
  • 10865 Answers
SOURCE: Broken freezer door hinge on Danby Model # D9600WY
hello. here is the link to Danby customer service. They can assist you.
http://www.danby.com/customer_service
Posted on Aug 14, 2009
  • 110 Answers
SOURCE: I have a Danby small refrigerator model DCR412BLS.
You need to check the Condenser coils, these are copper coils of tubing usually located on the back of the unit. They need to be free of all dust and grease to work at maximumefficiencyand it is recommended to clean them every 6 to 10 months. If those coils are already clean, the next thing to do is check the evaporator fan(The fan inside the unit). See if it's running. If it's not, check the coils behind it. If the coils are frozen up then you probably have to change out the fan motor.If they aren't frozen up then there may be a refrigerant leak or a bad compressor*. In order to legally reclaim, recharge, or test refrigerants you need a special certification2_bing.gif from the EPA. If you need to do so I recommend you call in a certified technician.
*To replace the compressor you need to reclaim and recharge the refrigerants from the system.
Posted on Apr 01, 2010
What is the price for drain pump washer for a danby washer
It all depends on if your talking about danby's dishwasher or a washing machine by Danby.
there are also two different types of washers metal and rubber. these are different from gaskets which go between two parts.
As for the rubber washer danby has a list of authorized retailers and service depots that sell their products. These retailers will list replacement parts specific to your type of washer rubber gaskets are typically 50 cents up to fifteen dollars but the rubber washers i found on www.apwagner.com was around 2.50 cents depending on the model.
Also if your looking for gaskets the same list applies to replacement parts but they are more specific and are pricer costing upwards of 10 to fifteen dollars or more.
Nov 25, 2012 | Washing Machines
Danby DPR2262W propane refrigerator stopped cooling
OK-to make this short-you either have a boiler tube blockage or Hydrogen diffusion.If your cooling unit quit suddenly,you more than likely have a boiler tube blockage due to precipitation of Sodium Chromate.If your cooling unit gradually quit working it's Hydrogen diffusion.This process is not easy to understand,and I won't bother you with the details as to why.By the way,burping is a myth,it dosen't work.If there is a blockage in your cooling unit turning your refrigerator upside down won't dislodge it.Danby dosen't make stand alone Propane refrigerators anymore,and since the cooling unit is foamed into the box,it's a throw away refrigerator.You will have to get a Servel RGE 400 made by Dometic.It's the same size as the Danby and I have those for a very good price.Go to: www.marvinspropanerefrigerators.com
Aug 20, 2012 | Danby DPR2262 Top Freezer Refrigerator
Replace door gasket on danby dcr412 compact refrigerator
Hi There,
I'm not sure what you are asking here, however if you are looking to purchase a replacement gasket for this model you can contact the Danby parts department at 1- 800-496-6049
Thanks!
Aug 01, 2012 | Danby DCR412 Compact Refrigerator
How to bypass CO detector in Danby Propane refrigerator
fix or replace co unit fixya doesnt assist in disconnecting - bypassing or removal of safety devises that if tampered with can cause serious injury or *****
Jul 05, 2012 | Danby Refrigerators
Danby propane fridge model # dpr2262w-6. the freezer still works great but fridge portion does not . the fridge has a bad smell. the fridge is at a cabin and no service
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 24, 2010 | Danby DPR2262 Top Freezer Refrigerator
Danby propane frig model DPR2260-2 owner's manual
I have the same refrigerator and am looking for the manual as well. Did you ever find one? If so, where?
Thanks,
Ari
Renata BC
hi_ari@yahoo.com
Oct 06, 2008 | Refrigerators
Our Danby propane refrigerator has given us sterling service for about five years, but it has suddenly stopped cooling in the refrigerator box-the freezer still works. Any clues?
Apr 17, 2008 | Danby Refrigerators
Propane refrigerator is too cold
You have a defective thermostat. Change it.
Nov 18, 2007 | Danby DPAC10061 Air Conditioner
Danby (DAR604BLS) Refrigerator Logo
44 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
