Cant get any of the video inputs to work - Televison & Video
  • 1 more comment
  • mrfro410 Jul 07, 2008
    i just received a used Mitsubishi WS-48515 48" rear projection HDtelevision.
    i have my 5DVD surround sound player hooked up to Input 1, all corresponding to the right jacks. and i have an old samsung VHS player hooked up into Input 2... again everything in the right order
    when going into the device menu, i see options for DVD and VHS, but when i select them, i don't recieve the input off of either device.
    is there something else i have to select? where should i look to switch my input to those devices? this is very frustrating, and i hope someone could help me
  • mhollis01 Aug 30, 2008
    will not change input and no screen at all.
  • golfnts Dec 31, 2008
    I have a KP-51HW40 TV and I can't get the RBG that's with Video5 and Video6. Can someone help me.
KP-51ws500
Posted on Jun 26, 2008
  • 8,617 Answers
What is the model number of your set? I may be able to help you out but will need the model number in order to do so.
Posted on Apr 09, 2008
My proscan tv is on and only getting static, I have cable hooked to it but cant get any picture, how do I reset
See if the set works with an exterior video input - if so then the problem lies with the cable box output.
OR if you are using video inputs with your cable box try another one to see if the input you are using is bad. Also try feeding your set via the rf input on channel 3 or 4.
Oct 20, 2016 | Proscan Televison & Video
Jvc hd56g786 channels stuck on digital cant get them changed to analog
Using the television's remote control, enter the user's menu. Search for video input and change from cable to antenna. If still experiencing difficulty, visit the JVC website and download the owner's manual to learn the procedure of changing the video input type and deactivate the television's digital decoder.
Dec 22, 2013 | JVC Televison & Video
To play videogames on an old tv PLEASE HELP
You'll need to switch the TV into Video mode. Most TV sets will have a button on the front panel labelled "input" or "tv/video," and pressing this button will cycle through the various inputs your TV has.
Alternatively, this button may be located on your remote control.
Rarely, no button exists, and video input is selected by changing the channel below channel 2; as if you were trying to select channel 1. This will select the video input on sets without a separate input selector button.
Dec 20, 2012 | Televison & Video
I cant get my ps3 to work on my trinitron tv
YOU MIGHT NEED THE REMOTE FOR THE TV. YOU HAVE TO CHANGE THE INPUT FROM CABLE TO VIDEO OR ANTENNA TO VIDEO. SOME TV'S HAVE MORE INPUT OPTIONS.
Feb 23, 2010 | Video Game Consoles & Games
Hi, i have the Denon AVR-2802 reciver. My issue is when i plug my xbox into the dvd compontent inputs, i cant get any audio or video. I was working a few days ago, i had to disconnect the amp, when i...
Component inputs are for video only, and when connected through a receiver then the television also must have a video input coming to it from the video out from the receiver. If you want audio that will be a separate connection from the xbox to the receiver either by digital coaxial cable or optical cable, or composite.
Dec 15, 2009 | Denon AVR-2802
Hooked up cables cant get video or audio
Make sure that your pluged into the proper inputs on the rear of the television. Double check them... (I've done this before too).
If you are sure the inputs are ok then make sure that your television is set to the proper input. Toggle the button on your television remote (input - source - device) for your input. Everyone is labled a bit differently.
This should bring up your dvd player when you reach the correct input.
Jan 23, 2009 | Samsung DVD-R130 DVD Recorder
Denon 3600 osd
So I presume you haven't done ANY setup as the OSD is necessary for all of it.
Somwehere in the manual it probably says to run a single RCA video connection from MONITOR to a suitable Video input on the TV. How your TV works is anyone's guess. Select the appropriate input.
The manual probably discusses SETUP and how to initiate it.
Jan 11, 2009 | Bose 901 VI Main / Stereo Speaker
Dvd wont work.
First, is the DVD player output (Video out, audio out) connected to the TV input? Have you used the Yellow cable from  DVD video out to the TV video in? Mixing the audio and video cables will result in no signal. Have you selected the proper input with your TV remote control. Most plasmas accept a variety of input signals; you must select the right one. I deal with a number of these issues. Usually the connections are made improperly or the correct input source is not selected with the TV remote. Put a DVD in the player and press play. Be sure you have made the proper connection from DVD player video/audio out into an auxiliary or video input on the TV. These could be labeled Line 1 or Line 2.  With the DVD playing, run through the input options on your remote control. The button might be marked source, video or input. The screen should display your choices i.e. video 1, video 2, etc. When you see your DVD program, you've got the right combination.
Dec 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Cant connect video input
It happens sometime when we use any problematis DVD unit.Check the Main board in which the input of Video is going. Change the dameged SMD components if found faulty.
Viren
May 26, 2007 | Hitachi PJTX100 Multimedia Projector
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
