Error 32 appeared on my passbook printer? - Office Equipment & Supplies
    Scholar:
  • 75 Answers
Removing the Accumulator cleaning blade clutch assembly to service the clutch for error 32 messages.
This process takes 2-3 hours first time, under an hour when your experienced.
1) Remove the fuser and imaging unit (cover it up, it's light sensitive)
2)Remove the back cover, the main engine board EMI shield and interconnecting wiring shield
3)Remove the main engine board and cleaning board
4)Remove the accumulator cleaning blade clutch assembly
5)Disassemble clutch, service and re-assemble, it goes back one way, take note of white dots
6)Reassemble all.
Removing the top lid allows you to maneuver the engine board and base bracket out without unclipping all the wires.
Some pics at:
http://www.triplej.com.au/error32.pdf
Posted on Jun 01, 2010
How do I get Tally T5040 passbook Printer driver?
Check the manufacturers website (dascom.com):
http://www.dascomamericas.com/Support/Default.aspx?type_id=3&info_id=5&itemid=23&name=T5040&act=4
Jan 07, 2015 | TallyGenicom Tally 5040 Passbook Matrix...
How to use pr2e passbook printer
Try searching "YouTube", www.youtube.com, put "pr2e passbook printer" in the search area. Also try from the Yahoo web site, search on "How to use a pr2e passbook printer"
Apr 21, 2014 | Office Equipment & Supplies
I Have A Epson PLQ-20 passbook Printer and it is connected through USB cable. after successful setup when i give print command to the printer it is not responding and nothing happened.
Sep 20, 2011 | Epson Passbook PLQ-20 Matrix Printer
Epson PLQ20 Passbook printer Problem:"comunication Error"
Hi, Check your cable connection. Check for updates from Epson. Restart your computer . Good luck.
Jun 24, 2011 | Epson Passbook PLQ-20 Matrix Printer
A PLQ20 passbook printer is not accepting passbook or another paper
Hi, here are two possible solution, kindly follow me and resolve your problem.
You mean that you load paper into the printer tray, but it doesn't pull it into the print, though it's acting like it should, and you get an error on the printer, then most likely your paper pickup/feed from rollers, it may possible that the problem is dusting or worn out. You can try to clean them with a cloth and water or alcohol, otherwise they may need to be replaced.
If your printer just doesn't see that it has paper and gives you a paper out error, then you may have a sensor problem in the printer, or the printer is expecting a different paper size or paper from a different input than what is loaded (depends on the printer), then you may have a programming issue.
I assure you that your problem will resolve easily.
Good Luck
Feb 24, 2011 | Epson Passbook PLQ-20 Matrix Printer
How to calibrate epson plq20 passbook printer
pls help how to calibarate plq20 passbook printer
Apr 15, 2010 | Epson Passbook PLQ-20 Matrix Printer
How to calibrate epson PLQ 20 PASSbook Printer
how to calibarate epson calibarate epson plq-20 passbook printer
Feb 18, 2010 | Epson Passbook PLQ-20 Matrix Printer
How to calibrate epson PLQ 20 PASSbook PrHow to calibrate epson PLQ 20 PASSbook Printerinter
Jan 25, 2010 | Epson Passbook PLQ-20 Matrix Printer
56 people viewed this question
k24674
jasbo
jasbo
