Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
12500 gal pool began by adding 8 \ 40# bags of
12500 gal pool began by adding 8 40# bags of salt the pool was green we were told to put in shock and algeacide then the reading showed no chlorine so was told to add 5 more / 40# bags of salt now the reading on pump shows high salt we have let out aot of water and added fresh the reading on the pump still show high salt what should we do? The pool is still green and the chlorinator will not stay on long with out beeping high salt.
  • Intex Master
  • 8,404 Answers
You have too much salt in the pool ...dump some water.
You have too much CL in the pool ... turn off your cell ... add some chlorine killer if necessary. The sun will eat new CL pretty fast.
You have metal in the water ... the CL aggrivates the metal, turns the water green ... If your pool were plaster, you would be in danger of serious staining.
You may have some alg. but I doubt it with all the stuff you have inthe pool
Check the source of your information.
Here is what you should consider ...
Fill the pool ... get rid of the metal ... 3 oz per 1000 gallons is the recommended dose ... NO CL for two days. Metal out works best when there is no CL in the water.
Get the TA under control and the pH. With the TA at 100 and pH at 7.4, bring the CL up to 2 or 3 ppm. You don't need CA ... but you might want to add some for comfort purposes. You might want to add cynauric acid to about 35 ppm to protect the CL. CA and cynauric acid are not consumable ... if you have a lot and want to get rid of it ... the only way is to add fresh water.
If you have more questions ... please post to this question.
Thanks for your interest in FixYa.com
Posted on Jun 01, 2010
  • A Miller Jun 01, 2010
    Good answer Clay 58 ... you must be in the pool business ...
    Thanks for the 4 thumbs up, Tammy, and good lyck with your pool this summer.
  • 2,841 Answers
Drain this pool, give it a good cleaning and start over. Clean the electrolytic cell. Your 24" x 52" size pool holds 12,481 gallons of water and requires 310 pounds of salt at initial startup. You should set the timer to run 11 hours per day. If the low salt light comes on add 85 pounds. You need an owner's manual. You can download one here. http://pr-rp.pmra-arla.gc.ca/PR_SOL/pr_web.ve1?p_ukid=5143
I added salt and am running just the pump for 24 hrs per instructions but when I turn the thing at top of pump to release no water comes out. Is this normal??
i am not completely familliar with this system but i am pretty sure that opening the relief valve should allow water to exit providing all the valves are open. as for green pool, if the water is not moving, you will not be able to clear the water.
Jun 26, 2015 | Intex Automatic Salt Water System for ...
Two weekends ago I came back from a 4 day trip to a green stincky pool. Low flow, we cleaned the filter and scrubbed the algae, by morning a beautiful sight. Yesterday after not look at the pool over the...
You should definitely shock however the best solution for solving an algae problem, which is what you have, is using a product called
Algimycin 2000
this will clear up your pool in about 24 hours
US Parts Center
Aug 18, 2011 | Intex Automatic Salt Water System for ...
We have a 18x48 ultra frame intex pool. It at first gave us a lot of problems saying low salt so we cleaned the cell with vinegar and it began working no probs for the past 3 weeks. On the weekend I went...
I can't explain all of this but to get the rid of the green and reduce the salt level you need to drain half the water and refill. At this you need to shock it so the chlorine is up to about 10 ppm. You need some way of testing to tell this. If your chlorinator is ok then when you start the pump and chlorinator it should continue cleaning it out. The dead algae will be filtered out with the filter. If the flow slows down you will need to clean the filter with a water sprayer on a hose. I hope this helps.
Aug 09, 2011 | Intex Automatic Salt Water System for ...
Problem is test strips indicate high copper ion (pink) and total alkalinity is low (light tan) Free chlorine is ok (between 0.5 and 1) and ph is good. We have this greenish silt like stuff on the bottom...
1st.. Clean the green (algae) stuff out..
2nd. Clean the filter...
3rd.. Repeat step 1 and 2 until most all the algae is removed..
4rd.. Brush you pool with a pool brush to remove the remaning algae...
5th.. Seems like you have the right chlorine level but not running your filter long enough??? After all steps are completed, run you filter at 8 hrs and your chlorinator between 3 to 6 hrs until your pool clears up.. After that, vacuum again and clean your filter... During the summer months, 4hrs is not enough circulation.. Hope this works for you and good luck.. Please take the time to write a comment if this works for you...Thanks..
Aug 07, 2011 | Intex Automatic Salt Water System for ...
I have an Intex Krystal Clear Saltwater System, model CS8111. My problem is green water. I had been out of town for a few days and when I came home the pool was green. Also the low salt light was on. I...
If your salt is at the correct levels required for your pool and your still getting the "91" code on your LCD screen do not add more salt you need to clean the plates on the chlorinator. Look at your manual and it gives you instructions on how to remove, clean, and replace the chlorinator section on the pump. Reminder, if your PH and/or alkalinity levels are off you'll be cleaning the plates often because of the scale build up. I personally run my pump 4 hrs daily and I have never had a problem with green water however, once it did become cloudy (white) I began treating with algaecide and changing filter every 3 hrs. It cleared it right up. I love the Krystal Clear System.
Jun 26, 2011 | Intex Automatic Salt Water System for ...
I have a 13X42 inch Metal Frame Pool and we have added over 55 lbs of salt to our pool and its still green and saying low salt.... what should we do and how much salt does out pool actually need??
You need to get water tested then add the right amount of shock + others and check in a few days to see where the water is at. The salt system only keeps pool right when in balance.
May 29, 2011 | Intex Automatic Salt Water System for ...
We have an Intex above ground pool that takes salt and converts to chlorine. We filled it about a month ago and all was fine for a few weeks, then in the past week the water began turning green. We have...
Intex chlorine generators are very low output generators that fail very often. There is a reason they are so cheap. They do not work well. When using a chlorine generator, it is important to test manually for salts and free available chlorine on a daily basis. Just adding salt because you have a generator will not make your pool manage itself. In order to get the most basic chemistry under control, you need to test for alkalinity, calcium, pH, and free available chlorine.
If you do not have the ability to test these things, spend $10 on a 7 in one test strip that will give you this information.
Note: Chlorine generators have more negative aspects to them than positive. There is not a cost savings as advertised with these units. It actually costs more money, and takes more time to care for. The salt is very corrosive to the pump and filter system as well as the pool itself. The long-time cost would be cheaper to run a chlorine or bromine pool.
May 02, 2011 | Intex Automatic Salt Water System for ...
I have a Intex Pool that is 18 ft by 52 in. I have a Salt water chlorinator unit and I am tryiong to start up my pool. I added 80 kg of salt which is the recommended amount for my pool and then I ran my...
I have a krystal Clear deluxe Satlwater system recently the water went green(lots of rain) I added more salt and have run the pump extra time. It is better but not back to normal. Do I have to shock it and how do I do that? What and how much do I put in for an soft set pool 18 x 48.
thank you
Jun 17, 2010 | Intex Automatic Salt Water System for ...
Just added an Intex salt water Gernerator to my existing above ground pool. Water is green, can I add chlorine shock to speed up the process. And Ph is low. Can i add PH increaser or should I just wait and...
Yes, you can add chlorine. Liquid chlorine will raise the ph a bit. Don't know what kind of shock you are adding, but wait a day, recheck ph level, than adjust.
Apr 18, 2010 | Intex Automatic Salt Water System for ...
Salt water intex pool
Salt chlorine generators cause your pH to raise over time. You will need to add acid as needed to keep it within the ideal range. When adding acid, shoot for the low end (about 7.2) so you have room for the pH to creep up again before needing more acid.
As for green water, what is your chlorine reading, if any? Probably need to shock it not only again but an even bigger dose than the first. Shock treatments are not cumulative. If the first doesn't do the job, adding just a little more will not either.
Oct 08, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
631 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
