I have a DLP Television, Model HLS4666WX...periodically it will shut off and the standby / temp light will be lit up....it might do it several times in a row, then stay on....or it might not do it at all...there doesn't seem to be a pattern.
  • mbosworth May 21, 2008
    How do you clean or replace the air filter?
  • Anonymous Aug 25, 2008
    i have a sony 50" dlp that won't come on and i don't hear the fan running. I called sony and they said that the red light indicated overheating. How do I clean the filter on this tv or is the fan out or the lamp. There is not a tech. close by.
  • 8,617 Answers
Try cleaning the air filter this will cause the temp light to come on at random times.
Posted on Apr 08, 2008
I have a samsung dlp 61 inch tv...older model...just replaced the lamp but the temp light remained lit....then two weeks later the tv will only turn on after several attempts and ever since it has been off...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
LG DLP TV temp problem
A temp problem? First check all the fans and make sure they are free from debris or check to see if they are spinning.
Dec 17, 2009 | LG RU-52SZ51D 52" Rear Projection...
No picture, display reads- green lamp, timer, standby, temp samsung 50" dlp
hi your tele light tube has expired or your light which is located at the rear of television
Oct 22, 2009 | Samsung SP50L6HX 50" DLP HDTV
Samsung DLP HL-P5063W
you have the same problem I have. The problem is fixed by changing the new light bulb. The problem appears again after 1500 hours of use. You can keep buying new light bulbs or avoid it by not buying another Samsung TV.
Sep 23, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
324 people viewed this question
Top Televison & Video Experts
