Question about Asko 1385 Dishwasher
Dishwasher isn't dispensing soap or rinsing well.
My dishwasher isn't adequately dispensing the soap. I found a dishwasher tab half-broken at the bottom of the dishwasher. It also isn't adequately rinsing the dishes that get soap on them. Most things are covered in a film. What should I do to fix this?
  • Joseph Odell
    Joseph Odell Jun 08, 2010
    Priming didn't work. Any other suggestions?
  • 523 Answers
Prime the sink before starting the dw yo make sure hot water is getting there
Posted on Jun 01, 2010
Why does it keep dispensing soap?
What do you mean "keep dispensing soap"? Is this a GE dishwasher with an automatic soap dispenser? Or do you mean that the soap lid won't latch or stay closed? Or are you talking about the rinse-aid dispenser leaking rinse-aid (which is fairly common)?
May 11, 2015 | Dishwashers
Tip
The #6part is attached and not broken so I went to the second idea and tighten...
The soap dispenser drawer is supposed to open during the cycle. Try first to understand if the drawer is opening or not during cycle.
If the drawer is not opening, then check if the opening mechanism is stuck, if it is blocked by dirt and soap, if it is broken, or if something, for examble a basket too close to dispenser drawer is preventing the drawer from opening.
Some dishwasher works only with powder, in that case indications are given on the owners manual.
If the drawer opens and the table, or powder is still staying stuck in the drawer, then that means that the spray does not have enough power to solve the tablet.
In that case check spray arms and impeller pump.Also check water temperature.
If the problem is also happening with powder, then it is probably a drawer not opening on cycle.
on Mar 02, 2011 | Stoves 27 in. DW60 Built-in Dishwasher
Dishwasher suds up and leaks during wash
Suds in a dishwasher usually come from using too much soap or the wrong kind. Soap can build up over times causing problems. First start a cycle.Do not add detergent or any dishes.When it starts washing, pour a cup of vegetable oil directly into the tub. This will cut the existing soap suds. You may need to try this a couple time before the dishwasher will drain. After all suds have been removed, load you dishwasher and start a cycle filling the detergent cup up half way. If it goes through the cycle with no problems, you should be all set. Still have the problem? A rinse aid dispenser that dispenses too much rinse aid will also cause the dishwasher to suds up. You can remove the dispenser from the door, flush it out and reinstall. Make sure you turn the circuit breaker off before taking the door apart. After rinsing it out, do not add rinse aid. Try the dishwasher and see if the problem goes away. I've seen people accidentally put liquid dish detergent in dispensers too. A dishwasher that has suds is apt to leak. Fix your suds issue and you most likely will fix you leak
Dec 27, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Soap is not dispensing. Sometimes the soap dispensing door isn't opening and other times it is but the soap is not dissolved
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 13, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
The soap isn't emptying out of the compartment during the wash cycle. 1. We didn't load any items too close to the dispenser. 2. We didn't use the Rinse program, just main wash cycle. 3....
heatman101
Aug 01, 2011 | Asko 24 in. D3112 Free-Standing Dishwasher
The some dispenser and the rinse aid dispenser seem to be "stuck", soap door doesnt open and dishes appear streaky from no rinse aid. this happened after I cleaned the deposits from under the screen in the...
There is a solenoid which pops open the soap lid after the initial rinse.
If the solenoid or soap lid latch is faulty, you will need to replace it. In the interim just poar your soap in the bottom of the dishwasher tray before cycle starts.
Only use a little amount as per normal. Dishwashing tablets are best as it is a measured amount and has the rinse aid built in.
Good luck.
Ash
Oct 21, 2009 | Bosch Dishwashers
Dishwasher does not rinse clean
run the dishwasher empty: use 1/2 the amount of soap you usually use in the soap dispenser close it then put white vinegar in the open dispenser and, run the dishwasher
Apr 22, 2009 | Dishwashers
Filled the rinse dispenser with liquid soap. how do I rinse this out? So I can use the washer without it sudsing up everywhere?
Hello chystalsbrr
Welcome,
You said you, filled the rinse dispenser with liquid soap. how do I rinse this out? So I can use the washer without it sudsing up everywhere?
You can try by turning off the breaker in the electric box that feeds the dishwasher for 5 minutes and see if when you turn it back on and the washer resets itself, and the soap door opens.
Or push cancel and then rinse and after it is done and goes to the dry cycle stop it and it should be open.
In the use of liquid soap in both a dishwasher and or washing machine you must use less soap. Half that of powder soap.
Or the suds will roll out of your dishwasher on to your floor. And this is not a malfunction on the dishwashers part. NO bad seal or anything!
In a clothes washer it will destroy the seal and bearing in less than 5 years!
Let me know how it goes!
Huuum
Please remember to leave a rating
Oct 19, 2008 | Whirlpool Dishwashers
Soap dispenser
There is a screw cap on the back wall of the dishwasher,unscrew the cap and place your rinse agent in there.I groove on the door is for your dishwasher powder
Apr 09, 2008 | Equator 20 in. CD 400 Compact Dishwasher
Dishwasher soap dispenser sticks
Your soap is clotting because there isn't enough water being sprayed around inside.  The water spray washes the soap out of the dish, if all is working well.  My machine had the same problem.  I had sufficient water level, but the spray head wasn't spinning very well.  I found the end-most hole in the spray bar to be plugged.  It is the end hole that provides a jet that makes the head spin.  I cleaned a bunch of debris out of the hole and the mchine started working and cleaning like it was new.  That was quite an axccomplishment since the machine is 15 years old.
Dec 28, 2007 | GE Nautilus 24" Built-in Dishwasher
Asko 1385 Dishwasher Logo
299 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
