Question about Bose Companion III Computer Speakers
Left Speaker Jack only produces static
Both speakers are functioning properly however whenever one is plugged into the Left speaker jack, a static noise comes from the speaker plugged into the Left jack.
    President:
  • 995 Answers
Hi!
That is probably happened to an aging speaker.
Consider buying a new one or try to rewire the coil inside the speaker magnet.
Posted on Jun 01, 2010
Not receiving
Hello
I understand this ICON 802 marine radio will not receive.
There are two things to check for. First check the speaker jack on the back side of the receiver also check the speaker plug and the connections. Make sure that the wires are soldered properly. If you have access to an ohm meter connect it to the plug leading to the speaker, it should measure 4-8 ohms. If the speaker checks ok then check the headphone jack on the front panel. The jack has a contact switch internality to disconnect the external speaker whenever a headset is plugged in. You can clean it by using a electronic contact cleaner spray a little into the jack and plug in a headset and turn the plug back and fourth. If this doesn't work, it would be inside the unit itself.
Hope this helps
Bruce
Dec 21, 2013 | Icom Radio Communications
Can i connect juster speakers 675 to my dell laptop?
Plug the power transformer into the bottom jack on the back of the right-channel speaker. This is the speaker with the on/off knob on the front. 2 Plug the audio cable attached to the left-channel speaker into the audio jack on the back of the right-channel speaker. The jack is immediately above the jack for the power cord. 3 Plug the audio jack attached to the back of the right-channel speaker into the headphone jack on a laptop computer (usually located along the left edge), or to the audio output jack on the back of a desktop PC. 4 Plug the speaker transformer into a surge protector and the surge protector into a wall outlet. 5 Turn the on-off and volume control knob clockwise on the front of the right-channel Inspiron speaker to activate the stereo speakers and adjust the volume.
Aug 07, 2012 | Juster : SP-801 Twintower Speakers...
Loose jack connection to speaker
It sounds like you need to get a new jack socket and replace it. It could be just a soldering problem. Especially if you have removed the plug a lot in the past.
Jan 06, 2018 | Edifier Audio Players & Recorders
Our speakers were accidently disconnected and we are unable to determine where the plug from the sony speaker needs reinserted. we have one jack and we cannot determine where it needs to be oinserted. We...
well usually speakers jack if it is 1 jack its colored green or lightr green.you connect it to your back of your PC when you can seen same 3 size sockets with three different colors.green,pink and blue.insert your speaker jack to green socket..
i hope it helps..
Jul 19, 2011 | Office Equipment & Supplies
On my Logitech z-2300, the left speaker does not work. I have swapped the speakers and the one plugged into the left speaker jack does not work. Where can I get a schematic in order to diagnois the...
Since nether speaker works in the left jack it is one of two problems.
1) the jack is bad, which can be replaced with a spare purchased from a vendor like Mauser Electronics or DigiKey.
2) The amp is damaged, in which case you are likely flat out of luck because they use SMD style circuitry which is near impossible to repair without very expensive specialized equipment.
Jul 03, 2011 | Logitech Z-2300 Computer Speakers
How do I connect external speakers
    Connecting Full-Size Speakers
  1. Step 1 Insert the red and white plugs on a set of RCA audio cables into the right and left audio "OUT" jacks on the back of the TV.
  2. Step 2 Connect the other ends of the cables to a free pair of audio "IN" jacks on the amplifier.
  3. Step 3 Strip 1/2 inch of insulation from the speaker wires, and connect a pair of wires to the left and right terminals on the back of each speaker using the red wire for the right audio connection and the other wire for the left.
  4. Step 4 Connect the other ends of the speaker wires to a pair of stereo speaker terminals on the back of the amplifier. The wires attach by raising spring-loaded clips on the back of the amp to reveal a hole for inserting each wire.
  5. Step 5 Set the amplifier selector to the set of audio jacks connected to the TV to enjoy stereo sound from the television.
  6. Connecting Self-Powered Speakers
  7. Step 1 Insert the RCA plugs on the Y adapter into the TV's Audio "OUT" jacks.
  8. Step 2 Connect the mini-plug on the wire attached to the right-hand self-powered speaker to the mini-plug jack on the Y adapter.
  9. Step 3 Plug in the audio cable and mini-plug from the left-hand speaker into the Audio "OUT" jack on the back of the right-hand speaker.
  10. Step 4 Connect the AC adapter to the power jack on the back of the right-hand speaker, then plug the adapter into an electrical outlet.
  11. Step 5 Switch on the external speakers and adjust the volume.
Jun 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
How do I use altec lansing acs40 with a laptop?
Fairly easy really. You'll need to buy a jack to jack AUX cable. Single point for stereo needed and a headphone jack on the laptop.
The left hand and right hand speakers are slightly different. The right hand speaker only has a cord coming out the back of it and no AUX points.
The right hand speakers has a series of small jack points.
The first hole is the adaptor plug that has to be plugged into mains socket, then the 1st hole marked SPKR has to have a jack to jack cord going from that speaker to the other one. The last two holes marked "A" and "B" give you the option to put two jack to jack AUX sound cables in.
To get it into your laptop, you'll need ONE AUX jack to jack cable and fit it into the point at the back marked "B" and then through the headphone socket on your laptop. You will then have sound.
Make sure to remember to put the system on by the push button switch on the back of the left hand speaker. The speaker system also has another rotary switch on at the front of the speaker.
I've had these speakers for well over 10 years - brilliant sound quality and very durable. Hope it has helped you!
May 04, 2010 | Altec Lansing Multimedia Computer Speakers
Left speaker gives no sound
There could already be a problem with the speaker jack, if only one channel is consistently giving no sound on your system.
Try turning the male (connected to speaker wire) jack and you might hear a static crackle while doing this. If you get both channels to produce sound this way, you already have a failing audio jack, and may need replacement later on.
Hope this helps.
Jun 07, 2009 | MSI PM8M2-V Motherboard
Right speaker doesnt have sound
1ST.-The right jack could be damaged!!
Usually, there is a [+} posaitve & [-] negative input\output to speaker connections. Not all [-]neg. is ground.Sometimes the [+] pos. is grounded. [The exception to the rule is that u SEE the black wire going to ground] the reason I am letting u know this is that u can test the INSIDES of the sound system.
If u can get inside of the unit. Cut the left speaker output [+] posative from both outputs. criss\cross wires.Place left speaker output to right speaker jack[ that does not work!!] & visa versa.If the [LEFT Output] stops working after u plug in the speakers,the internal RIGHT output is damaged. NEEDS TO BE TESTED
If nothing nothing changes.The left still works & the right still does not work, then it is the jack (shorted ?, opened internally ?)
Jun 11, 2008 | Logitech Z-2300 Computer Speakers
Right speaker output jack does not work
you must plug it in to the right slot,
Nov 04, 2007 | GPX HM3817DT Shelf System
Bose Companion  III Computer Speakers Logo
668 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
