Question about Cell Phones
I am having trouble pairing my Omnitech bluetooth to my Blackberry 8310 mobile phone. I can not get them to connect or recognize each other and I do not have the manual. Can you help?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 53 Answers
1. make sure the bluetooth is off
2. press down the on key n hold until the light is keep blinking
3. use your 8310 search for it n pair
4. if got code then key in 0000
Posted on Jun 04, 2010
  • linthe Nov 30, 2010
    also check out www.product-support-omnitechnology.com
My bb 8310 AT&T device won't pair with a headset or with my ford fusion
Make sure you have the correct password for your phone. Also look in your fusion manual as to the correct steps needed.
  • Press the Power Button. // This is on a 2010 Ford Fusion.
  • Then you hit the Phone Button.
  • It should say “No Phone Paired” that means that no phone has been paired with this.
You now have a choice of options:
  1. Add Bluetooth device
  2. Connect Bluetooth device
  3. Set Primary Phone
  4. Set Bluetooth On/Off
  5. Delete Device
  6. Delete all Devices
You want to choose Add Bluetooth Device, press OK
  • Then on your mobile, turn your Bluetooth On.
  • Setup Bluetooth – Search
  • Now it’s searching for it, when that gets full, Click Sync.
  • Then you’ll want to enter the PIN number that’s on the screen.
  • Say YES to connect to Sync.
  • Now screen on dash will say your mobile phone
Mar 26, 2010 | RIM BlackBerry Curve 8310 Smartphone
Blackberry 8310 will not sink with computer. plug in to USB port and get Device Not Recognized. BlackBerry said it must be bad USP connector on the phone it's self. Trouble started after setting up...
Try a different usb port even another computer to see if its your phone or the computer. if you have no luck you can try the jl commander option to wipe your phone and then try to reconnect it but this will lose any un backed up data. Also look in the usb port and see if any of the prongs look bent pushed out of place or missing. if this is the case the phones only chance to connect is via bluetooth
If desktop manager will not recognize your phone then download JL commander (google search it) and select the wipe option then try again.
Feb 18, 2010 | RIM BlackBerry Curve 8310 Smartphone
When trying to connect my mobile via bluetooth to my car phone it says sim rejected why ?
We suggest you to reinsert the sim once again and check for the same. And try to perform the following steps: Apply the Bluetooth Pairing Helper application to your BlackBerry smartphone. Download the Bluetooth Pairing Helper application file using your BlackBerry smartphone browser Note: The Bluetooth Pairing Helper is available for BlackBerry smartphones running BlackBerry Device Software 4.2 and later. Complete the following steps for the Bluetooth Pairing Helper software. The following steps use the Land Rover as an example. Place the vehicle into pairing mode. For instructions, see the vehicle user manual. Start the Bluetooth Pairing Helper application. See links above. The following message appears on the BlackBerry smartphone: Please initiate the pairing process on your car. Click ?Done? when pairing is complete On the vehicle, press the Dial button. The following message appears on the Land Rover, and the progress bar on the Bluetooth Pairing Helper Application begins to advance: Searching The Land Rover display lists the name of the BlackBerry smartphone (and any other Bluetooth devices found within range). This may take one or two minutes. On the vehicle display, use the dial to highlight and then select the BlackBerry smartphone. The vehicle displays a random personal identification number (PIN) to pair. When the BlackBerry smartphone prompts for a PIN, type the PIN shown on the vehicle display in step 8 and press Enter. The BlackBerry smartphone displays Pairing complete. Connect to and press Yes. Pairing completes and an Connection to vehicle succeeded should appear on the BlackBerry smartphone. If the Bluetooth Pairing Helper application does not close, click Done to close the application. If you find the same error as sim rejected even after performing the steps, you need to check with the service provider relavent to the sim problem.
Oct 18, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Built in bluetooth carkit but my BB Bold won't connect
Sir you have to just on bluetooth visiblety from your phone settings
Jun 01, 2009 | RIM BlackBerry Curve 8310 Smartphone
Connecting problem
Try downloading the driver for the other phone your computer may not be able to detect it
May 14, 2009 | Samsung WEP500 Wireless Headset
Can send mp3 from laptop to blackberry 8310
go to your menu and then to media then to music hit the menu button select recieve using bluetooth then have pc connect to blackberry
Apr 23, 2009 | RIM BlackBerry Curve 8310 Smartphone
BlackBerry won't pair with device anymore via Bluetooth
1. Go to Options/Bluetooth
2. Select device found
3. Select device properties
4. At Trusted select yes
It'll never ask again
Dec 30, 2008 | RIM BlackBerry Curve 8310 Smartphone
Plantronics 330 no longer pairs with Blackberry 8310.
I believe that the bluetooth symbol that you see indicates that bluetooth is enabled on your Blackberry, not that you are connected to a device (at least that's how mine works).
Here are some suggestions:
First, if you are on BES, check with IT to make sure no changes were made (they can block bluetooth).
Next, make sure you are using the most current software. It should be: v4.5.0.108. If you are using an older version, definitely update your software because the 8310 is known to have bluetooth issues.
Do you see your headset listed on "paired devices"? If so, I suggest that you delete it before upgrading the software.
Once your headset is no longer listed (or if it wasn't in the first place), re-connect it to your Blackberry as follows (apologies if you already know this part):
1. Re-set your headset:
Turn the headset off.
Press and hold down the control button.
After 6-10 seconds, the light will flash blue, then it will flash red, then blue.
Release the button when you see the red/blue.
2. On your Blackberry:
Open "Options"
Open "Bluetooth"
Open menu within Bluetooth
If not already on, click "Enable Bluetooth"
Open Bluetooth menu again.
Open "Options".
Turn "Discoverable" to "Yes"
Open the Bluetooth menu a 3rd time.
Click on "Add Device".
Your Blackberry will search for your headset.
If you are prompted for a Passkey, use 0000 (that's 4 zeros).
After a short time, your headset will appear on your Blackberry.
It should appear as Plantronics 3xxx.
Make sure you go back into Bluetooth Options and change "Discoverable" back to "No".
Once you have established a new connection with upgraded software, you should have no trouble with "Transfer Address Book".
Hope this solves your problem.
Dec 28, 2008 | Plantronics Explorer 340 Wireless Headset
Blackberry 8310 Bluetooth device no services
I just experieiced this for the second time on my 8320 using a plantronics 510 bluetooth. The solution was to take the battery adn SIM card out of the phoine and leave it out for a full minute. It appears that the phone needs to be rebooted once in a while. I suspect Bill Gates designed some of the internal code.
Oct 15, 2008 | RIM BlackBerry Curve 8310 Smartphone
Pairing Motorola HS820 with Blackberry 8310
there is really no fail safe method to pairing a bluetooth device.
The main thing is recognition. i,d suggest trying to press the different buttons on the transmitting bluetooth device, whilst attempting to pair. i.e volume up/down or on/off et,c. to enable the device-blackberry to find and sync. i,d think the device that needs to be configured or setup correctly is the blackberry rather than the bluetooth device.
try changing the phone settings. to accept all incoming signals on bluetooth, or disable encryption.
hope this helps.
Mike @ Compurepair.
Oct 06, 2008 | Motorola Mobility HS820 Consumer Headset
Cell Phones Logo
585 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
