Buzzing sound.......Otherwise they are in excellent conditions
  • 17,129 Answers
You amplifier is having a noise amplification from one of its preamplifiers.The buzzing could be from the power section , the DC supply having lost the filter capacitor. Check this out and add a sam value capacitor in parallel . if the buzz stops the fault is comfirmed. Usually the a/c transcient noise coming into the DC can cause this buzz. If not check if the filter has failed in the preamp. Isolating the section can get to the fault. Howeverr I still hope that the DC power filter capacitor can be faulty. Hope this helps Good day
Posted on Jul 24, 2010
I have a Fender Precision Bass Guitar serial #503122. I'm curious about its age and value? It is in excellent condition.
this should be a 1960 bass and there was 18,000 of them made so it is not rare but the questions that must be asked to put it in the rare category is the bass 100% original = this means everything /pots /pickups /tuners /frets /finish and then the overall functioning of the parts EX. bent tuner that turns restricted causing tuning problems / pots that cut out / input jack that's screwed up / buzzing or severely worn frets /and or fret board wear /worn finish on the body/neck so you must go down the list of everything to come to the overall condition of your bass then you can grade it by it's condition and then see where the basses category is (PRISTINE) =never used still tags & case (fine) = slightly used tags & case (excellent)= used but no finish chips scratches everything original & working so you get the picture I am curious about this because most players know there basses very well so this tells me that you have acquired this bass recently or that it belonged to a family member? and was passed down to you post back with more info/pictures of the bass I'd like to see it Stephen
Sep 30, 2014 | Fender American Precision Bass
98 mitsubishi chariot grandis gdi, making funny buzzing noise then engine stalls
Sounds like a high voltage ark through either through a crack in the distributor, or through a crack in the wires to it or near one of the spark plug boots. It probably will be visible as a blue spark at night. Otherwise you might just replace the cap and wires!
Jan 01, 2013 | Mitsubishi Cars & Trucks
Excel file corrupt how to recover
Better Stellar Phoenix Excel Recovery which can fix corrupt Excel (.XLS/.XLSX) files and restore everything (including charts, chartsheets, cell comments, worksheet properties etc.
Aug 20, 2009 | Microsoft Windows XP Home Edition with...
Hobart N50 stator assembly replacement
You can go to www.hobartservice.com. select parts and type the machine ML number from the data plate. here are 5 different ML options, otherwise I would have given you the part number.
It will open an exploded view of YOUR machine's build, complete with part numbers.
You can then call your nearest Hobart dealer for a cost and availability. They are still a current model, and for their size, an excellent mixer worth repairing.
Aug 18, 2009 | Hobart N50 Stand Mixer
Air Conditioner Compressor Fan Quit
Check the start capacitor. You may be able to see visual deformaty, otherwise, use a meter. The buzzing is most likely the contactors closing which uses a seperate 24v supply..
Jun 26, 2009 | Kenmore Heating & Cooling
Samsung 7178 buzz noise
Is this buzz from the speakers?
Is this buzz from the set itself when the sound is turned down?
Is this buzz a low pitch sound?
Is this buzz a high pich sound?
Does this buzz vary in loudness with the volume control?
Does this buzz change in level from time to time?
You should post the details and the circumstances of use in order to give some idea of the conditions.
Jerry G.
Apr 16, 2008 | Televison & Video
Loud Buzzing Sound - Rear of TV
It is probably the color wheel that needs replacing.
Oct 05, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Camera won't accept tape
tape senors is bad or have a bad tape
Jul 31, 2007 | Sony Handycam CCD-TRV308 Camcorder
143 people viewed this question
 Grubhead
Grubhead
