Question about Dishwashers
My hoover dt999 dishwasher shows E3 error code, I've cleaned out all the filters, spray arms etc. I know the heater element is OK so has anyone got any suggestions
  • dave9 Apr 09, 2008
    Hi Noffie
    I hope this gets to you. Thanks for the advice. I know the heater is OK because I got a new one and replaced it, which has made no difference apart from to my pocket!
    At the moment I'm looking to check the thermostat as I've noticed that the machine seems to think that water is hot immediately, i.e. no time taken up trying to get water to right temperature. Might be a red herring but at the moment it's all I can think of to try.
    It may well end up that I have to get another control board but if I do I'll have spent about £150 + with the unnecessary heater and I'll have to make the decision whether it wouldn't be better to get a new one. Any other suggestions gratefully accepted
    thanx
    Dave
    Problem Solver:
  • 10 Answers
Hi there dave 2 things i have for you first you cant always go by earthloop reading on heaters you have to do a insulition test to that can afect (PCB) power control board if that is ok you are looking at a new board £100 plus unless you can find one on ebay or maybe i can find 1 for you. i hope this is of sevis to you noffie.........
Posted on Apr 08, 2008
I would like to get a manual/guidefor dishwasher DW009H from B&Q . Drying does not seem to be very thorough at the end of the cycle. Also the code E3 is showing when finished.
E3 Error Code
Cause: The water heater element does not work properly or the filter mesh is blocked.
Remedy: Clean the filter mesh and if the problem continues please contact service
As far as a manual is concerned, I believe Hobart manufacturers your model and not B&Q. B&Q just sells the unit. You may want to locate a Hobart dealer in your location to try to get the manual. You will probably need one to fix the heater element any how.
Jun 05, 2011 | Dishwashers
Hoover Whisper dishwasher has not been cleaning very well for a while. Had 2 technicians in, but still not working. The latest I got an e3 error on the screen. Would like to know if I can fix it or not....
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
May 17, 2011 | Hoover 24 in. HD98E Built-in Dishwasher
Hoover DT 999 shows E3. No hot water & no drying. Do I need a heater element or could it be some other problem?
is your dishwasher connected to the hot water lead? is the heated dry on? or is there a control issue
Mar 06, 2011 | Hoover 24 in. DT999 Free-Standing...
Check your heating element..
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 19, 2011 | Hoover 24 in. DT999 Free-Standing...
Whilpool dishwasher is not cleaning dishes
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
dtj
Apr 13, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishes dirty
your chopper is the culprite.you have to take the insides out of the dishwasher to locate the chopper.
Jan 22, 2009 | Hoover 24 in. DT999 Free-Standing...
Arms not rotating
pull out washer disconnect lines unplug it open the door pull out the racks(room to work) look for any stray parts laying at the bottom(small black belt,srews any metal debris)if you find any of that try to find where it came off of.it sounds like a pump problem easy fix connect hoses to pump and mount the pump.check all hoses and spray tips thoroughly
Nov 08, 2008 | Hoover 24 in. HD98E Built-in Dishwasher
What does E3 mean?
E3 not hot enough. This defect can be caused by, but not only, a defective element or clogged spray arms.
Sep 29, 2017 | Dishwashers
Hoover dishwasher error codes
Hi we have a Hoover DT999 and according to the manual for that machine error E1 is water inlet tap turned off
Dec 18, 2007 | Dishwashers
Heater element problems
Why did you decided that it is an heating element problem,it could be a thermostat issue as well. Check with a multi-meter whether you have power on the heating element tags. In case you have power on its tags, the heating element should be replaced.But in case you can't read any power on its tags, it's probably a thermostat issue. Good luck!
Sep 10, 2007 | Hoover 24 in. DT999 Free-Standing...
Dishwashers Logo
247 people viewed this question
Top Dishwashers Experts
