I brough a hp printer long time ago to send to my country but i only open on monday to find no power cord please i know warranty up but where could i find one to but my printer is no good with it
    Guru:
  • 1,463 Answers
Hi go to HP cables and see if you printer is list and select the cables you need .
riz.
Posted on Apr 08, 2008
How to reset printer HP deskjet D2660 all lights are blinking
Follow these solutions in the order presented to resolve the issue.
Solution one: Reset the printer
  1. Press the Power button to turn on the product.
  2. With the product turned on, disconnect the power cord from the rear of the product.
  • Unplug the power cord from the wall outlet.
  • Wait at least 15 seconds.
  • Plug the power cord back into the wall outlet.
  • Reconnect the power cord to the rear of the product.
  • If the product does not turn on by itself, press the Power button to turn it on.
  • Solution two: Service the printer Contacting HP for service in all countries/regions except Asia Pacific.
    If you have completed all the preceding steps and are still experiencing a problem, service the product.
    Determine if your product is in warranty or out of warranty. If you need help determining your product's warranty status, go to HP's Warranty Check Tool .
    • If your product is in warranty, Contact HP to obtain service.
    • If your product is out of warranty, Contact HP to find an authorized service provider or to setup service (fees might apply).
    Nov 25, 2014 | HP Deskjet D2660 All-In-One InkJet Color...
    HP Photosmart C3183 All-in-One Printer I bought the printer in Saudi Arabia. I have now moved to canada, and the printer cartridges that i purchase in canad do not work, How can i reset the country...
    Hi
    The printer will use same cartridges that it uses in Saudi Arabia, and those cartridges are available even in Canada, you can buy it from this link. I mean there is no need for region code etc. Hope this helps...please post back for further assistance.
    Daniel
    Aug 20, 2011 | HP Photosmart C3180 All-In-One InkJet...
    The electricity went off to my printer and it hasn't worked since. I have tried turning it on and off. I have tried resetting the ing cartriges . I have tried unplugging , waiting and replugging. Nothing...
    Which brand/model of printer do you have? Check the warranty for the printer and contacting the manufacturer, if it is under warranty.
    First though what type of power cord does the printer have? If there is a power module (brick), disconnect the cord from both the printer, the wall outlet and separate the cord from the module. Wait a minute and then plug the cord into the module and then into the wall outlet. If it has an LED, is that LED lit? (Check the printer itself or the module and find out what power should be getting to the printer. If you have a multi-meter, check if the cord is getting the correct power level.) Try another power cord if you have one that matches the connection and the voltage output (for a power module).
    Some printers have a soldered-in fuse and it should be handled as a warranty repair when the printer is under a year old.
    I hope this helps.
    (I'm currently waiting for a return shipping label for a similar printer issue. HP gave a credit for a new printer instead of sending a refurbished unit. I didn't have a spare power cord but did have 30 V at the printer side of the power module's cord. This was at the specifications for the unit. This is the first HP printer I've ever had fail within a year. Previously the ink jet failed after 9 years of use.)
    Apr 02, 2011 | Office Equipment & Supplies
    I have HP Officejet 6500 E709a with an error message 0x60000F6 its just out of warranty so need advice. thankyou in advance x
    Hi
    Please click on the following link to get the issue resolved, the pictures might not appear the same but the steps to troubleshoot are exactly the same...
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01949676&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
    If the issue still does not gets resolved please follow the step given below
    Take out all the ink cartridges and the printheads out of the printer
    If you don't know how to take the ink and the printheads out please refer to the link given below
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01643079&cc=us&lc=en&dlc=en&product=3795314&tmp_track_link=ot_search
    Unplug the power cord from the back of the printer
    While the printer is unplugged, press and hold # & 6 together on the printer
    Hold them for 30 seconds and then plug the power cord in the printer while holding the buttons
    Release the buttons after 6 secs of plugging the power cord
    Then the printer would as you to select the language and location
    Then it would ask you to insert the printheads and the cartridges, so please insert it
    Then printer would do it normal procedure like it does when you use the printer for the first time
    This particular step would reset the printer back to the factory settings
    Hope it would resolve the issue
    All the best!!
    Oct 29, 2010 | HP Officejet 6500 Wireless All-in-One...
    HP 9670 printer head not moving
    See my advice would be that if your printer is in warranty then call up HP Total care as u will get a replacement if the issue is not fixed over the phone. But if the machine is Out of warranty, then you can try the following: Make sure the printer is connected directly to the wall socket(No Porwe Surge or anything). 1) Power Drain: Unplug the power cord from the back of the printer, then press & ho;d the power key for 30 seconds, then release the key & plug in the power cable back. Check if the problem is resolved. If Not
    2) Partial reset: Unplug the power cord from the back of the printer again. Press and hold the # and 3 keys together and while holding them plug the power cord back in. Check if the problem is resolved. If Not
    3) Semifull reset: Unplug the power cord from the back of the printer again. Press and hold the # and 6 keys together and while holding them plug the power cord back in. Check if the problem is resolved. hope fully the problem will be fixed by this. Please let me know
    If still the same problem arises then ur printer may just need a replacement
    Aug 07, 2009 | HP DeskJet 9670 InkJet Printer
    I need a power cord for my HP officejet all in one 7210 series
    You can buy them from HP by calling 1-800-227-8164, Monday-Friday, 8:30am to 6:00pm EST. You only need to do this if you need the adapter. If it is only the power cord running from your electrical outlet to the adapter that you need, you can get that at any local computer shop for a couple of bucks.
    Jun 07, 2009 | HP Officejet 7210 All-In-One InkJet...
    Power cord
    Sir,
    U can buy at HP authorized service centre. Click this link to find the HP location in your country.
    http://welcome.hp.com/country/us/en/wwwelcome.html
    Thanks
    Good luck111
    Don't forget to rate the solution
    Jul 12, 2008 | HP Officejet 5610 All-In-One InkJet...
    HP office jet 7310
    Please goto the HP website and see if there is a firmware update for this machine. Download and you can also download the procedure.
    It seems to be that it's a controller issue and reinstalling the firmware will usually resolve the problem.
    Hope can be some help
    J
    Dec 11, 2007 | HP OfficeJet 7310 All-In-One InkJet...
    Power failure
    Please follow the below given instructions to resolve the issue.
    Please remove the All-in-One Printer from the Power Surge Protector and plug it directly into a wall Power outlet, as the surge protector may not provide enough power to printer.
    Please perform the step given below to power cycle the unit after removing the print cartridges from the printer:
    1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the USB cable from the computer.
    2. Wait 30 seconds.
    3. Plug in the power only
    4. Repeat steps 2-3 two more times.
    5. On the third time after plugging the unit into power, reconnect the USB cable from the all-in-one to your computer.
    Reset the All-in-One to the factory default settings by using these instructions:
    1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
    2. Then, press and hold # and 6 while plugging in the power cord.
    Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
    Note:
    A semi-full reset will do the following:
    The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
    Please install the below firmware update to resolve the issue.
    Here is the weblink to download the firmware update:
    http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-14700-3&lc=en&cc=us&dlc=en&product=79480&os=228&lang=en
    Just copy and paste the entire link into the Internet browser's address bar and press enter.
    Instructions to install:
    1. Please scroll down the web page and click on "Download only" button in that page.
    2. Click on " Save " and choose desktop on the left side of the new window (which is opened when you click on Save).
    3. Click on OK.Now Double click on the file that you have just downloaded.
    4. Then click on " Run ".
    Regards,
    Lawrence
    Nov 24, 2007 | HP OfficeJet 6110 All-In-One InkJet...
    Ink says empty but cartridge is new
    On the phone for an hour with those idiots in India, same exact problem. Here is what you do: 1: Unplug AC cord from back 2: Hold down the # and 6 key, plug in the powe cord and continue to hold the kes for 1 minute. 3. Printer will power off durning this time. Release the keys and plug in the power cord. 4. You may need to press the power button on. This will hard reset the printer. It will go throught the initialaztion process and suck your cartridges but should solve the problem. HP SUCKS!
    Jan 05, 2007 | HP Photosmart 3310 Printer
    44 people viewed this question
    jasbo
    jasbo
