Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
In the agitator, how do i remove the clear plastic cam holder so i can replace those little cams so the agitator works again
  • 5,911 Answers
If the clear plastic piece you are referring to is the center post cap, it simply lifts up. If the model number is correct, the cap is listed as item 23 in this parts drawing:
http://pcappliancerepair.com/model-display.php
Sometimes it can become gunked up with detergent and/or softener residue which can make it a little difficult get off. If it is on too tight, you can try reaching it with a pair of pliers and gently pull straight up on the handle portion. Make sure you do not damage the cap is it is required to provide and air gap to keep water from entering into the gearcase (transmission) shaft.
If you need further guidance, the following link explains how to access and replace the agitator dogs:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
The part number for the agitator dogs is included in the instructions I provided. For a little more, you purchase the entire cam assembly (which includes the dogs, the cam and the bearing) for about $8 to $10. It is listed as item 9 in the drawing I provided and the part number is 285809.
Replacement parts can be found at any of the following websites:
searspartsdirect.com
appliancepartspros.com
repairclinic.com
All these sites are reputable, offer great service and have competitive pricing, so shop and compare. The first three sites have helpful exploded view parts diagrams to assist you with locating and properly identifying the parts you may need.
If you have questions, please post back and let me know. I hope this helps you.
Posted on Jun 01, 2010
How do I remove the agitator from my Kenmore Washer model number 110.24962300 to clean under it as clothes are coming out with flakes of dirt and soap-scum pieces etc. on them?
Follow these detailed step-by-step instructions to help you locate and replace your Kenmore worn agitator cogs:
  1. Before you begin this or any other repair, disconnect the power supply to your washing machine. Either unplug the unit from the wall outlet, trip the appropriate switch in your fuse panel, or remove the correct fuse from your home's fuse box.
  2. Raise the lid of your washing machine, and if your model uses a fabric softener dispenser, remove it from the top of the agitator by pulling it straight up and off.
  3. Pry off the agitator's cap (if there is one) by wedging a small flat head screwdriver into the slot between the agitator and the cap.
  4. Reach into the agitator top and pull up on the barrier cap and its seal (also called a gasket) to remove them.
  5. Use a socket wrench with an extension or a nut driver to remove the stud and the seal that hold the agitator top to the shaft of the agitator base.
  6. Remove the agitator top by pulling it up off the agitator base. Turn the agitator top over, enabling the cam and the worn directional cogs to slide out. Examine the cam for wear, it also may need replacing.
  7. Attach each of the new directional cogs to the cam. The small round piece at the base of each 'ear' is fitted into one of the cam's four slots. Your model may or may not make use of a black plastic agitator cam bearing. This cam bearing is used to help hold the cogs in place. If your model uses one, make sure you put it back on during the reassembly process.
  8. Carefully insert the cam and new directional cogs into the agitator top the same way they came out. Place the agitator top over the agitator base. There are tabs on the top of the agitator base that line up with, and fit into, the slots of the cam.
  9. If the cogs fall out of place during re-assembly, you will have to take the cam out of the agitator top again and re-insert the cogs.
  10. Push down on the cam until its slots and the base's tabs snap together.
  11. Insert the stud and seal into the shaft and use your wrench or nut driver to tighten.
  12. Make sure the black rubber gasket (seal) is situated properly in the groove of the barrier cap. Then push the barrier cap and seal down into the agitator past the holes.
  13. Replace the agitator's cap or fabric dispenser, whichever your model uses.
  14. Close the lid of your washing machine. Reconnect the power supply and test the machine to make sure it is working properly.
That should do the job for You. Hope this was helpful
Jan 14, 2011 | Washing Machines
The agitator is not moving as well as it should. It turns very little. Should it not be agitating aggressively?
You have (agitating dogs) in the bottom of your washing machine. These little plastic pieces tend to wear out over time or from overloading. These can be replaced, cost about $5 for for 4 of these (dogs). Take the very top piece of the agitator off, it spins off. There's a bolt in the bottom of the agitator that will have to be removed. After it's removed, you can pull the agitator out. You will see the little (dogs). It's a very simple task, and takes about 10 min to do this. Look up (picture of agitator dogs) this will give you a better view at what you are looking at.
Mar 04, 2010 | Roper RAX4232KQ Top Load Washer
The agitator is loose and "clunks" as it is washing. How to fix?
You may have a worn agitator cam assembly, worn agitator dogs, or a loose agitator bolt.
Whirlpool uses a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by either worn agitator dogs, a worn agitator cam assembly, or a loose agitator bolt. The following link explains what the dogs are and how to access and/or replace them. It also explains how to access the bolt and tighten (if necessary):
The part number for the dogs are included in the link provided. You can purchase replacements at pcappliancerepair.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs for about $11 or $12.
NOTE: You can refer to the excellent exploded view parts diagrams the web site has to offer for assistance. Whirlpool also recommends the application of a little grease on the thrust washer. The part number for their recommended grease is AP3098553.
If you aren't sure, or have additional questions about this repair, please post back with your complete model number (located on a nameplate along the wash tub opening under the lid) and let me know. I hope this helps you.
NOTE: DO NOT overtighten the agitator bolt. This can cause damage to the plastic, or restrict the agitator movement. Tighten until snug only.
Feb 03, 2010 | Roper RAS6233KQ Top Load Washer
Hi, I have a Kenmore Washing machine that I have had for the last 12 years that I know of. The Oscilator is no longer doing its job this morning. I removed the cap and looked down in the center of the...
If you are referring to the AGITATOR, Whirlpool manufactured washers (such as Kenmore), use a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly.
Since you mentioned that the agitator appeared to be working, this problem may be caused by either worn agitator dogs, a worn agitator cam assembly, or a loose agitator bolt. The following link explains what the dogs are and how to replace them:
The part number is included in the link provided. You can purchase replacements at pcappliancerepair.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs for about $11 or $12.
If you have any questions about this repair, please post back with your complete model number (located on a nameplate along the wash tub opening under the lid) and let me know. I hope this helps you.
Jan 10, 2010 | Washing Machines
Top of agitator does not turn but the bottom does
If this is a Whirlpool manufactured washer, the problem is very simple, inexpensive and easy to repair.
Whirlpool has a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by worn agitator dogs or the agitator cam assembly. The following link explains what the dogs are and how to replace them:
Dec 23, 2009 | Washing Machines
I have a Kenmore 90 series Model # 110.28902790, during the spin cycle the agitator start to spin and then hangs up for a moment then tries to spin again.It keeps repeating this process while making a...
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.28902790
Please see the Whirlpool Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Also see the Whirlpool Parts list for their commercial washers although the consumer models use the same parts.
The problem points to a worn Agitate Cam.
Whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
The cam is a two piece plastic part that lifts a gear above the main agitate assembly in the transmission so that the agitator doesn't turn during the spin cycle.
We had the same problem. The cams had worn enough that they weren't lifting the gear (less than 1/16").
They aren't expensive at all but do require pulling the transmission.
See the following for a description of how to remove the transmission.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to remove the tub!!
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
It may seem like a difficult job but it really isn't. It is a bet messy but it's a lot less expensive than a $170 transmission.
Nov 06, 2009 | Kenmore Washing Machines
How to remove agitator cam from the upper part of the agitator?
Had same problem with my washer. Check to see if there are little plastic tags holding top/bottom of agitator. after replacing dogs just ensure that you realign with tags so they do not break off.
Oct 10, 2009 | Whirlpool LSN1000LW Top Load Washer
Washer makes loud metalic clicking/grinding sound when washing and spinning Model number (110.15942401)
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.15942401
There are a few places to check in the washer.
1. The Clutch
2. The Brake system
3. The splines on the agitate shaft and / or agitator
4. The agitate cam and / or gear in the transmission.
Please see the following :
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
Following is the Whirlpool / Kenmore operations and maintenance manual describing how the washer works and in particular how the neutral drain assembly works.
You'll be able to see on the Sears site, the internal construction of the transmission. The Agitate Cams and Neutral Drain assembly cogs are plastic and can wear / break over time.
When ours had a major noise / grinding problem when spinning, we tracked the problem to the agitate cams not lifting the agitate gear high enough (less than 1/16" above the gear on the agitate shaft. Replacing it cost less that $15 vs. $170 for a transmission.
If the Drive Brake, Clutch, agitator splines and agitator shaft seem OK, the problem points to the transmission.
If it appears to be the agitate cams, following is a description of how we replaced them.
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
I had the same problem with gear grinding and this solved it.
Pull the transmission.
Remove the 8 transmission screws carefully, the transmission is full (16 oz.) of 80-90 weight oil.
Oct 07, 2009 | Kenmore Washing Machines
This Kenmore Elite Top Load Washing machine has
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
This gets a little tricky.
It sounds as if, based upon the weight in the tub being reduced, the noise gets less. Something is pressing on something else due to the weight.
If you look at the gearcase parts section of the Sears site, you'll see parts called the agitate gear and agitate cam.
If the agitate cam wears (it's two plastic pieces) when the transmission moves to the spin cycle, the cam is supposed to lift the gear above it.
If it doesn't lift the gear high enough, you'll hear loud gear noise. This may lessen as the washer pumps water out and there is less weight on the spring.
We had the same problem with a washer and found that by replacing the cams, the noise went away.
Please see GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Sep 26, 2009 | Kenmore Washing Machines
I need to replace the cam agit for this sear kenmore washer. is it a serviceable piece and if so, what tools do i need?
remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Sep 15, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
128 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
