Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Ice dispenser flap in door will not close and stays open causing the ice maker to frost up and the unit to run all the time
    Problem Solver:
  • 14 Answers
You will have to open the cover on the door. W D-40 is the best lube to use. Do NOT use W D-40 where it makes contact with the ice chute!
Posted on Jun 01, 2010
Ice sticing in ice dispenser chute
only use ice from the ice maker, some frost is normal, but , lower temp in freezer
May 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Shoot door (flap) for ice maker wont stay closed causing frost
the gear that pulls it closed is bad. some have small plungers instead of gears
Oct 28, 2009 | Refrigerators
Hotpoint ice dispenser door not sealing
clean with white vinegar to remove lime deposit.
flapper may have got bent, bend back or replace flapper.
Sep 24, 2009 | Hotpoint HSS25GFP Side by Side...
Frost builds up in dispenser area .hard to open because of frost buildup.
The ice dispensor flap is not closing completely , causing the frost in the inside shoot and on the bottom of the dispensor . Sometimes caused by a broken ice guide ( clear piece attached to the arm that activates the dispensor on the door ) it hits against the flap , not letting it close . Model number would have helped more .
Aug 25, 2009 | Whirlpool Refrigerators
Flap on ice dispenser door won't close
clean it again and make sure when you use it that all the ice falls out if not and its open a little it will cause it to freeze open
Jun 26, 2009 | Whirlpool GS6NBEXR Side by Side...
Whirlpool side by side ice maker
its possible that ice is jamed in the ice crusher compartment this happens to me as well the ice drops down to fast causing it to clog and then stays open until it all of a sudden you pick it up on the floor thanks from gilles
Mar 15, 2009 | Refrigerators
Ice maker chute icing up
The flap is probably not closing properly. Dispense some ice, then open the freezer door and look to see if the flap is still slightly open. If so, you will have to take the front cover off of the control panel and clean the muck off of the flap mechanism and also clean the solenoid. I have to do this about 2X year. Not a big job, but be careful.
Nov 13, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice dispenser chute
most flaps have a solinard that opens and closes the flap,if you can replace or get in there to lube it you should me ok,let me know more-mike
Sep 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Bottom of ice maker/dispenser frosting over
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced or something is wrong with the mechanism. The problem you describe is almost always air leakage around that flap.
Post back if you need more help.
Nov 17, 2007 | Whirlpool GC5SHEXNS Side by Side...
Frost buildup on ice/water dispenser
Is the trap door flap closing properly where the ice comes through the door? If open, warm air would be coming in frosting and maybe iceing things up
Aug 27, 2007 | GE GSS25QGPBB / GSS25QGPCC / GSS25QGPWW...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
419 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
