Question about Apple iPhone (16 GB) Smartphone
How to disconnect
How can i disconnect from a wifi network
    Problem Solver:
  • 5 Answers
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 151 Answers
First you need to go to the wifi network which is in SETTINGS and then hit the small arrow next to the network name and then hit FORGET NETWORK and you will be disconnected.
Posted on Jun 01, 2010
Wifi conection
This is a computer issue, not a camera one
Apr 01, 2017 | Cameras
My wifi keeps disconnecting and have to restart phone to reconnect, but only lasts for maybe an hour
Samsung Galaxy S 4G Smartphone: WiFi disconnects (have to restart phone to reconnect, does not scan for WiFi connections):
Hello. It could be that your "Auto Network Switch" setting is on..
What Auto Network Switch does: when the WiFi gets too low the phone automatically switches to cellular, and when cellular connection gets too low, the phone will switch to WiFi
All Samsung Galaxy's are not alike for it's menu settings.. but you can try:
for S4 and up:
Settings>hold down on WiFi settings for a second then let go > un-check box at top for "Smart Network Switch"
for other Samsung Smartphones see the attached video below:
If your device is having issues trying to scan for your router.. try turning off your router for 2 minutes, then turn it back on.. make sure you wait a few minutes for your router to properly boot back up before you try scanning for your WiFi network again
Jan 31, 2016 | Samsung Galaxy S 4G Cell Phone
My wifi connection is good, but why is the wifi signal by the power button orange now previously it was blue? is this somthing i can manually fix? help
Orange indication means that the wifi is off or disabled. This will occur if:
1. You manually disable the wifi driver
2. You disable the wifi using the keyboard function key
3. You plug the PC into a wired network connection.
Check the keyboard hotkey for wifi and cycle it to see if for some reason the wifi was accidentally disconnected. If that is not the case, check the device manager to see of the wireless network driver is installed and working properly.
Dec 10, 2015 | Acer Aspire Computers & Internet
How do i get my wifi internet back
It sounds as if you simply need to reconnect to your wifi network. If you have already connected to it, but still have no access, then disconnect from your network, remove the network from your settings (Forget The Network) and then try reconnecting to it.
Aug 27, 2014 | Irulu 7" 4gb Mid Google Android 2.3...
Why has my mobile phone WiFi stopped working at home?
Open your wifi on the phone and press and hold the wifi network that you want to connect to then click (modify) re-enter the security code for the wifi network again and then connect. If that does not work then the wifi signal is weak and you'll need to get closer to your router.
Another thing is to choose United States for your Wifi Region in the wifi advanced settings menu.
-- uncheck (avoid poor connections)
-- check scanning always available
-- Wifi Region Code (select United States)
I hope that helps
Jun 11, 2014 | HTC Cell Phones
I have installed connectify on my windows 7 toshiba laptop. when i start it, the connection work well on my ipad for about 5 minutes and after it s get disconnected. each time i just close the wifi access...
1- I don't know what connectify is or even why you would use it. Your router can or should be able to handle wireless communications in your WiFi network. Once you have your wifi network setup under the router then go into settings on your ipad and point it to the right network and it should connect.
2- On your toshiba it should connect on it's own as well, get the wifi connection setup the go into network connection and point it to your wireless network in the house.
Like i said i don't know why or what this other program is or even for but see no good reason to even use it.
Hope this helps
Feb 21, 2014 | Computers & Internet
My Craig notebook CPL281x disconnects whenever I get into a video or try to do any online work. Is the processor inadequate for the product?
The built-in WiFi network adapter can be defective or of very poor quality. If you have an USB port on your notebook try to connect a supported USB WiFi network adapter and establish connection via this device.
Dec 28, 2012 | Computers & Internet
When i connect to the internet how do i disconnect? Internet is on all the time.
You may go to settings and tap again Wifi or Mobile Network depending on which one you are using. It's just like a toggle switch, that is, if you are connected it will disconnect you, and vice versa. It would also be easy if you add to home a Widget for Wifi or Mobile Networks (At home, click "+" menu->Widget->Settings->Mobile Network).
Lastly, before you turn-off your phone, disconnect the internet connection or else it will just connect automatically after turning it on (unless that is what you desired).
Hope this helps.
Mar 24, 2011 | HTC Wildfire Cell Phone
Wifi disconnect on vista business
Try resetting your wireless router frm the reset button on your router....After that goto -control panel-network connections-right click on wireless connection-click on repair
May 02, 2009 | Microsoft Windows Vista Business DVD...
Wifi connection lost when power cord is connected / disconnected
in the battery management you must have selected a power plan other than maximum performance... so it would do this to reduce power consumed... put your powerplan in maximum performance to resolve this...
Nov 13, 2008 | IBM ThinkPad T40 2373 Notebook
Apple iPhone (16 GB) Smartphone Logo
80 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
