Question about Sony KP-46WT510 46" Rear Projection HDTV
Green convergence, bad IC?
Recently my TV developed the problem where the green will no longer respond to vertical convergence. Even in the service mode, i can adjust the green horizontally but not vertically. This condition results in the green projection having a significant bow-tie or pin-cushion affect, depending on how one looks at it. Everything else appears to operate normally.
Based on the numerous solutions here that mention the replacement of the STK ICs, i have pulled by D board and planned on replacing the ICs. However, when i looked closely at the connection around the ICs, i saw this...
Now every other C#### component is white, while C8011 appears to be fragmented (sorry i can't zoom in better\clearer) and possibly damaged.
Does anyone know if the failure of this component would be associated with the condition of my TV, or should i proceed to replace the STK ICs?
The red marks across this STK IC was made suring manufacutring, and this IC appears to be the one associated with red and green (furtherst from the high voltage component and the power G board).
  • Sony Master
  • 8,617 Answers
C8011 could definately cause the problem you are indicating as one side of that capacitor is tied to the postive feed for Red horizontal in IC8001 ( STK392-560) and the other is tied to the Green vertical return . I would replace that along with the IC as the IC is sure to be weakend if that capacitor has shorted. Let me know if you need further assistance.
Posted on Apr 08, 2008
SOURCE:
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
Wavy green lines and offset during convergence calibration
There is whats called a convergence IC that is going bad inside this TV set. There is only one for all three tubes and the IC number is STK 393-11- and can be purchased here http://www.electronic-repair-kits.com/STK393-110.html You will only need to order one. If you are handy and can solder this should correct your problem. One very important thing is, before you reinstall the new convergence IC, make sure you use a good coating of heat sink compound on the back of the new IC. If you do not, the IC will fail within a short time frames. Only if you are good with a soldering gun should you attempt the repair. If you are not, this repair should run you about 300 bucks or so. Also if you are handy, there are seven capacitors that go bad inside a board called the DM board. These will go bad very soon so while your in there these should be changed as well. If you need info on how to change these capacitors, let me know and leave an e-mail and I will send you the pictorial on how this is done. the IC change you will need to find that, but I do have a service manual if you need one also to help you along if you can follow the schematic. Good Luck
Nov 01, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Can't control red convergence on VS-45607
The STKs are three channel ICs they each control horizontal and vertical of one color the third channel controls part of green and the other half of green is controled by the other ICs third channel. Its customary for the Ics to fail and only have one channel bad in the IC. However its recomended to change both because of the bad Ic having green it can actually weaken the other IC and that one will fail shortly.
Aug 03, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Convergence
If the red isnt responding via the remote you will need to replace the STK392-110 Ics as the service menu adjustment will not correct it 100% due to the IC being faulty and the red and half the green is controlled by one IC and the blue and other half of green is controlled by the second IC so without changing both ICs the set will progressively get worse. Both ICs are stk392-110. You can get replacements at the following link along with instalation instructions
http://servicemanuals.vstore.ca/
Jul 13, 2008 | Toshiba 55H70 55" Rear Projection...
1080i connection has green hue
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 09, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Problem with green color
One of your convergence IC's has burned out and needs to be replaced. If the green color is sagging from the top or bottom then the IC that handles the Green Vertical (GV) is bad, and if the green has moved inward on the left or right sides then the IC that handles the Green Horizontal (GH) is bad. Toshiba projection TV's typically use the STK392-110, and it is a good idea to go ahead and replace both IC's with the updated STK392-150's. If you do not have experience replacing convergence IC's then have a qualified tech handle it for you.
Jul 02, 2007 | Toshiba 40H80 40" Rear Projection...
Convergence Problem inSamsung HC-P4752W 47" Rear Projection
One of the convergence output IC's has burned out and needs to be replaced. If the IC opens up inside then it stops working without blowing any fuses or resistors. The IC should be replaced and the set realigned by someone with experience in convergence circuits.
Jun 22, 2007 | Samsung HC-P4752W 47" Rear Projection...
Sylvania 27" TV
This problem sounds like the vertical output circuit is bad. it could be a vertical output IC, a bad resistor in the sweep supply, a bad capacitor, or a bad solder connections. Sorry to say this is a solid state set, so if you know how to solder and know how to service solid state devices, you should have No problem finfing the bad part. if you have no experience, please be safe and call in a trainede tech to assist you. Good Luck PS please dont forget to rate this thread>
Oct 18, 2006 | Sylvania SRT4127P TV
Vertical Red/Green lines
You have bad connections on the board and need to be resoldered or the convergence IC's are bad. If you know how to solder on solid state elctronics then you can change the IC's or find a bad connection on the board if you know the High Voltage issues when working on a TV set. If you have to training on TV sets I highly recommend that you call a service person to assist you in this repair.
Sep 25, 2006 | Toshiba 43H71 43" Rear Projection...
No Picture after it's been on a while. Audio OK.
ok you have a vert sweep problem and yes its probably connected to in a way to the "tap and fix" problem! Seems to be n intermittant connection on the vertical out put Ic or maybe even on the rgb convergence ic?? The total loss of sweep though tells me that theres two differant problems! Maybe and intemittant connection on the vert output Ic as well as bad connections on the convergence ic??.
Apr 16, 2006 | Mitsubishi VS-5043 50" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
43 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
