Question about RTO Case W14 1570 2090 2290 2294 2590 3594 4490 Water Pump
2090 case trasmission problems
2090 case tractor runs hydraulic remotes work pto works but the tractor will not move?
  • 66 Answers
That's because you have two separate pumps controlling each. My best advice is to get a farm mechanic to take a look...it may be a simple seal to a need for a rebuilt pump. www.nyagparts.com
Posted on Jun 01, 2010
Ive got a john deere 4055. Has a new clutch and pto release bearings and piston. The pto will not ingage and there is no pto pressure.
did the mechanic that installed the new parts pre prime the hydraulic pump on install , ive had limited luck using another tractors pump on remote circuit to back feed on the return line to "externally) prime the pump , but it has worked a few times , worth a try if you have the means
Mar 28, 2015 | John Deere Garden
My 1976 allis Chalmers three point won't lift up and the PTO won't stay engaged. Everything on this tractor is run by hydraulic pumps. There are 3 pumps on this tractor. A piston pump, a gear pump, and a...
I would try checking the remote valves, maybe undo the line at each one and see where your pressure is stopped and maybe you can work down to where whitch with valve is not working..
Jan 29, 2015 | Garden
1979 case 2090 does not move , no hydraulics, no steering nothing
Yeh I think your on the right track with the hydraulic pump, if it's power shift as well it stands to reason that the pump has failed, you can fit a guage to the coupling on the rear of the tractor and it will tell you if the hydraulics are working to pressure, hope this helps
Jan 21, 2015 | Cars & Trucks
Does the pto have anything to do with the lift on a tractor?
Sometime around 1950 Ford tractors started using "live PTO". Prior to that the power lift for equipment required that the PTO be on and running (turned on by a lever on left side of chassis below the driver's seat). So 'yes' the older tractors (many in use today) require the PTO to be running in order for the lift arms to lift equipment. I find this very annoying when trying to run a mower, especially when the hydraulics don't hold very well.
Jun 27, 2014 | Ford 8N Tractor
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
PtO will not engage on cub cadet 1000
It would be helpful if I knew whether it was working and quit or has never worked. At any rate it has of course a live PTO on it (not dependent on the clutch to engage-disengage it). Check your linkage, make sure nothing has come loose and not moving the travel rod. Secondly some models have a hydraulic fluid compartment that is used for the PTO alone, check to see if this is the case and if so check fluid levels. Back to linkage, the engage mechanism is usually a lever of some type that moves a valve body and lets hydraulic flow under extreme and engage s set of input and output clutches together. If your engage mechanism is a magnetic clutch, check for bad wiring and burnt fuses. If it is a fuse replace with the same value as already in the harness. If the new fuse flows don't do like me and put a larger fuse in it, though that will show what wires are involved with the clutch engagement it also shows the wires to be replaced. Check wiring for ***** wires or wires worn and touching metal parts and grounding out.Back to Hydraulics again, unless you've loaded the PTO hard enough to burn the clutches out (which I doubt very much) it can only be that fluid is not getting to the clutches. Chances that there is a problem inside the tractor with the valve body are slim but possible. Most PTO that just quit are caused by linkage problems or low Hydraulic fluid. Check all the above, I believe you will find your problem lies somewhere in what I have explained. I farmed for 30 years and we ran from 140 -250 HP tractors and if a PTO went out it was usually linkage or low Hydraulic Fluid. Hope this helps, don't want to miss a crop over a PTO!Col. Dana Gillespie TSM
Apr 15, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I have a 1982 Case 2290 that stopped moving forward. No hydrolics nothing. 2 lights came on, hydrol pressures. Thanks in advance, Garnet
It may be that the main hydraulic valve body (right side of tactor behind battery box) has grit in one of the valves. This happened to my 2290 a number of times, so I now carry a wrench in the tractor so I can remove the valves (six of them) one at a time, clean them and reinsert, and be on my way.
May 13, 2009 | RTO Case W14 1570 2090 2290 2294 2590 3594...
RTO Case W14 1570 2090 2290 2294 2590 3594 4490 Water Pump Logo
2,314 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
