Question about Texas Instruments TI-89 Calculator
How to enter 7th root of 45,235? - Texas Instruments TI-89 Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
You've got several different ways of doing this.
45235 ^ ( 1 / 7 ) ENTER
root(45235,7) ENTER
And, of course, you could always take the logarithm of 45235, divide it by 7, then take the antilog:
diamond e^x 2nd LN 45235 ) / 7 ) ENTER
If you get a symbolic result rather than a numeric one, press diamond ENTER.
Both LN and e^x are on the X key, just below HOME. You can access the root function through the catalog, the MATH menu, or simply spell it out.
Posted on Jun 01, 2010
Hi, how do i use casio fx82ms to raise a figure eg. to the power of 4?There's no xto the power of y button....
There should be key marked [Y to the x] or [^]. If exponent is negative use the change sign key (-) not the MINUS sign.You will have to use the [^] key if you calculate roots of order higher than 3. Example 7th root of 353 =(353)[^](1/7)
Sep 04, 2011 | Casio FX82MS Scientific Calculator
I can't find the universal power key or the universal root key on my TI-84 plus. Can someone tell me where it is?
The power key is marked ^ and is located just above the divide key. For example, to calculate 2 raised to the 7th power, press 2 ^ 7 ENTER
There is no key for the universal root. The operation is available in the MATH MATH menu. For example, to calculate the 7th root of 128, press 7 MATH 5 1 2 8 ENTER
Aug 04, 2011 | Texas Instruments TI-84 Plus Calculator
I need to use the square root sign but I need to square root with 3, 4, and so on.
If you would like to a root other than a square root, first enter the root value (3, 4, 5, etc.) then press MATH. Then Press 5 and enter the value you want to take that root of. Press ENTER.
Jun 05, 2009 | Texas Instruments TI-84 Plus Calculator
EUROVOX NOT SHOWING PIC
**UPDATED 7th May 2009*
These are what I've been told are the latest codes.
C/W 5c-01 May 7th 2009
key 00 = A7 B2 EE 5F 9D D8 69 0E
key 01 = 3D 82 E6 58 8E 0D B3 62
T/W 5a-01 May 7th 2009
key 00 = AA B7 D1 D9 CE 8E 83 AF
key 01 = 8E 80 D7 EF 44 93 02 2B
PURE (UK) NTL 54-01 May 7th 2009
key 00 = 5C 2C 26 36 CF 81 AB 66
key 01 = 2C 10 35 AC 06 57 BE 6F
IRELAND NTL 54-01
KEY 00 =B0 B8 4F 04 E6 5F 87 80
KEY 01 =A3 EB EC 07 D6 49 D2 EB
IRELAND CHORUS 5E-01
KEY 00 =CE 19 2E 87 80 61 74 90
KEY 01 =62 FA D9 F3 CE 05 FA 79
May 20, 2009 | StarTech.com StarView SV211K 2-port KVM...
I need to take nth (8,5,4,etc) root on the TI30XA
7th root of 3.4 x10 (exp) 23
Solution:
Try it.
Have I solve your problem?
Thanks,
-engrkoiled-
Mar 27, 2009 | Texas Instruments TI-30XA Calculator
Please help me solve for g
You want to isolate g, Ok. Start stripping it of all extraneous factors, by doing the inverse of each operation.
1. There is a 1355 multiplying the term with g: I divide by 1355 to get
(1+g)^7=20000/1355 = 14.7601476
2 The expression containing g is raised to the 7th power. So I do the inverse operation which is to extract the 7th root. If my previous result is still in [Ans] memory I write on my
(1+g) =[Ans][^](1/7) that gives 1.468970104
3. Now g is an expression that involves and addition. I perform a subtraction: I subtract the number 1. Assuming that my last result is still in [Ans] memory (I did not perform any other operation)
g=[Ans]-1 that gives 0.468970104
Hope you find this more instructive than just giving you the answer.
Mar 08, 2009 | Casio FX-300MS Calculator
I need help with square root functions
The square root has a dedicated key sequence [2nd][V square root symbol]
Square root of 21.2846 is entered [2nd][V square root] 21.2846 [ENTER] .
The result is`4.614.
I suspect you want to calculate the 4th root of 21.2846. If it is the case you enter that as
21.2846 [^](1/4) =2.148
Square root can be also entered as [^](1/2)
Cube root is entered as [^] (1/3)
nth root is entered as [^](1/n)
Hope it helps.
Nov 19, 2008 | Texas Instruments TI-86 Calculator
Basic Q's
The LOG and LN keys do what you have done.
To get 9 to the 16th power, enter 9, "y to the power x" (under the OFF key) then 16, then =
3 to the 12th power is the same, enter 3, y to the power x, 12, =, result 531,441
The inverse key sequence: value 1, 2nd, y to the power x, value 2, returns the xth root of y, e.g. 531,441, 2nd, y to the power x, 12, =, gives you 3 back
Sep 07, 2008 | Texas Instruments TI-30XA Calculator
Entering a cubed root into a ti-83 plus
You can enter any root by typing the number, then hitting MATH and 5, which brings up the root symbol with the x in front of it: x√. So the fifth-root would be 5 -> MATH -> 5 and then whatever number you want to get the fifth-root for: 5x√10 for example. As someone else had mentioned, you can also raise it to a rational power: 3^(1/3) which would be the same as the cubed root of 3, but you could also type: 3 -> MATH -> 5 -> 3 and get the same answer, but looking like this in your calculator: 3x√3. The option for 4 actually is a predefined cubed-root, and the one for option 5 there is the root symbol that can be used with any number before it to get any root you want. There are no parenthesis as you get when using the predefined square-root and cubed-root functions, though, so you may want to type them in yourself if entering a long string of operations in the calculator at one time to make sure the calculator doesn't include numbers under the root that you don't want it to. But I guess it depends on preference in terms of what method you choose between the rational exponents or the root symbol (and most would go with whichever seems easiest and quickest to enter), but you asked specifically how to get the cubed-root on the TI-83 Plus, so there's my best attempt at answering your question.
Aug 22, 2008 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-89 Calculator Logo
598 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
