Question about Rv Motorhome Dual Co & Lp Gas Alarm Detector
2006 Sandpiper travel trailer - The LP gas detector keeps going off and we didn't even have the gas turned on.
  • 6,674 Answers
May be faulty and need to be replaced but check for proper voltage to it first. Some of those detectors can go off from hairspray, deodorant spray, perfume, high humidity, etc (aerosols)
Even a dog laying close to it with a little gas can do it sometimes. (lol) seriously. Do you have a battery hooked up to your trailer as well, may help.
Posted on Jun 17, 2010
LP gas detector alarm goes off whenever there is power!
CHECK THE BATTERY POST FOR CORROSION. YOU MAY JUST NEED TO CLEAN THE POST AND SECOND CHECK THE GROUND ON THE ALARM MAY BE LOSE
Apr 22, 2016 | Vehicle Parts & Accessories
Why is the protechtor alarm going off 2010 springdale travel trailer?
Have you checked all gas line fitting, to ensure that you do not have a true leak? Some spray cans , like deodorants, can cause the alarm to sound.
May 13, 2014 | Safe T Alert Lp Propane Gas Alarm Rv ...
Electric and battery working fine but gas will not come on. It keeps clicking and then the red light comes on
Assuming this is on a travel trailer / RV, correct?
The red "check" light indicates that the fridge was not able to detect the presence of a flame from the burner area. This could be due to low LP gas pressure (causes different flame size), no LP gas (tanks are exhausted / turned off), damaged wiring going to the igniter / sense electrodes, defective gas valve, or damaged igniter / control board.
Aug 18, 2010 | Refrigerators
The LP gas detector alarm is going off and I can't stop it.
Unfortunately, it may have to be replaced. Not uncommon for those to be affected by humidity, condensation etc, hair spray, aerosols, moth balls too close, etc. and begin to malfunction. Just be sure propane is off. They can be bench tested,(out of the unit) with a battery, just to be sure it's time to replace it.
Jan 01, 2010 | Rv Motorhome Dual Co & Lp Gas Alarm...
I have a 2004 sandpiper toyhauler, i pull it with my 06 powerstroke, the last two times i hooked up my trailer it fried my alternator.I think there must be a short somewhere, any ideas?
How are the batteries on the sandpiper? If they are dry and/or shorted the alternator on the F250 will overwork trying to charge them thus overheating and burning out the alternator. If the batteries on the sandpiper are okay, you have a shorted wire either in the connection on the truck for the trailer wiring or the trailer wiring itself.
Nov 05, 2009 | 2006 Ford F-250 Super Duty
Gas detector fuse keeps blowing as soon as the thermostat clicks for the heat to come on why. the water heater and stove work fine this happens when plugged up or running on battery power this is on the...
ANOTHER FACTORY BLUNDER. UR RV SERVICE TECH SHOULD HAVE CAUGHT THIS WHEN THEY SOLD THE TRAILER TO YOU. UR GOING TO HAVE TO FIND ANOTHER POWER SOURCE FOR THE LP DETECTOR. NORMALLY IT CONNECTS TO THE WATER PUMP WIRE OR THE HOT WIRE TO THE MONITOR PANEL.
Oct 27, 2009 | RTO Atwood Water Heater - 6 Gal LP
Alarm in Camper keeps going off
New trailer giving off fumes from chemicals and glues used in building process, various aerosol sprays, humid weather, are just a few things that will cause them to go off , as well as a faulty detector. Even too many people sleeping in a small area where detector is located, with windows closed, will cause it due to excess breathing causing high level of co2. Double check fumes not entering from Fridge, water heater, or any other source of open flame. Pay attention to when it goes off, and what is happening and running at the time. Low voltage to detector as well, can cause it to go off.
May 17, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
I have a Weber Gas Go-Anywhere Grill that I want to connect to a propane tap on my travel trailer. The problem is that the tap is low pressure, it's located after the regulator. the Go-Anywhere has a...
You can buy a "T" fitting that connects to the LP tank with a valve allowing you to pull LP gas off for your BBQ before the RV regulator
Most any RV shop can get them from NTP Distirbution
Jul 08, 2008 | Weber Gas Go-Anywhere Grill
Rv Motorhome  Dual Co & Lp Gas Alarm Detector Logo
594 people viewed this question
Top Camper Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a Camper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
