Repair tv where is the fan motor located on my 52in rca hdtv 3 years old
  • 81 Answers
Should be in the rear, must be experienced to replace it though.
Posted on Apr 09, 2008
SOURCE:
My 56 inch rca tv has 3 difrent colors on it turns on ok but show s it like their is 3 of everything on the tv
This is a common problem and is known as a convergenc failure. You can get parts and instructions from sites such as www.TVRepairKits.com
Aug 18, 2011 | RCA HD56W66 56" HDTV
We have a 3 year old RCA 52in projection tv, One day it went blurry for just a moment and then went blue. We turned it off, because we didn't want to fry it. And then turned it back on, the picture was...
you eather have a bad solder connection or a part overheating...this unit has a processor that generate error codes that technician with a special computer interface can read....this is where the troubleshooting begins...first thing a tech can do is check make sure all cables are securely plug in
Jun 11, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I've got a Toshiba 52HM95 that's several years old. It's been making a grinding noise for a while. A few months ago I took the back off to investigate. The problem went away. But, now it's back. I have a...
The grinding noise sounds like it could be the fan blade hitting the housing. Have your verified that it is the fan that is making the noise? Does the fan feel loose or rub the housing when turned? Well you have already purchased another fan and have gone this far so I say continue dis-assembly if it is the fan. If you were looking to get a new TV then get one but don't trash this one. If you repair it you could sell it or give it to a friend/family member. A new 52in HDTV is not that cheap.
Jan 09, 2010 | Toshiba 52HM95 52" HDTV Projection...
I have a RCA D52W19 52in Rear Projection HDTV and the light flick
Deflection board , its bottom board to the left has FBT flyback transfomer CK capacitors cp 150 2200uf 16v use 25v and two more cp114 cp120 220uf 35v if cp 150 is puffed up on top it is bad replace All 3 capacitors for parts call Mats Electronics 1-800-628-1118, also For Deflection replacement board Call Encompass Electronics Parts 1-800-638-3328
Nov 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W23 52in HDTV red and green ghost and bowing lines
Ur convergence it dead,need convergence kit,use what in that kit,U know to solder? Tries websites Tv Repair World.com,Ebay.com
Oct 06, 2009 | RCA D52W23 52" HDTV CRT TV
Rca 52in rear projection hdtv red, blue, and green lines n double
tHIS is a convergence problem.. first question if you go into the customer setup menu. is the convergence option listed? If you have not got that option i suggest you read "the fl231 problem in the tips and trick section of this website. this can be a simple inexpensive repair..if you do have the convergence option then it can be one of three diffrent boards convergence power, convergence amp or small signal board. and will need further trouble shooting
Apr 04, 2009 | RCA Televison & Video
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
RCA 52in HDTV will not stay on
I would turn the circuit board over and check for clod solder joints and cracked solder, you will have to look close, my other sugestion would be to get a can of freeze and spay the different IC's and see if it stays on longer.
Dec 05, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52in Projector
Most likely the issue in on the large signal board. The TV is going in to shutdown. Repair might run $200.00 or so.
Jun 08, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
Top Televison & Video Experts
Ekse
