Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Code 88 i just need to know how to set the time .Dont have manual .thanks.
  • 2,841 Answers
Plug the pump in. You will see code 88 which is normal. Press and hold the down button for 2 seconds until you hear a short beep.Then press and hold the up button for anohter 2 seconds until you hear a short beep and the LED flashes 00. Using the up button set the time to run based on the size of the pool which you did not list. Tell me the size and I will tell you how many hours to set on the timer. You can download an owner's manual here: http://pr-rp.pmra-arla.gc.ca/PR_SOL/pr_web.ve1?p_ukid=5143
Posted on Jun 01, 2010
Testimonial: "thks very helpful awesome."
    Problem Solver:
We have an Intex saltwater system model 8110 and cannot set to code 00. I've unplugged the unit fot 10 - 15 mins. After that I powered the unit back on. Now when I depress the left button, I get
one beep, and nothing when I depress the right button. Any hints on what to try next.
Posted on Jul 22, 2011
I have a 88 Dodge caravan, I need to know what the code means when you turn the key on and off three times.1-2,2-55,55-55.I useto have a manual.
Well there are no single digit codes.
Code 12 means the battery power has been lost within the past 50 key starts.
Code 55 means you have reached the end of the code test.
Apr 12, 2013 | Cars & Trucks
Error code 88 88
The 88 88 code indicates a modem communication error in the refrigerator. This error is not applicable in the U.S. It should be ignored. The control will conduct a self diagnostic check when it is powered up. When this code is encountered it will just need to be cleared and the refrigerator will resume normal operation. To clear the code, press and hold the POWER FREEZE and POWER COOL buttons simultaneously. NOTE: Be sure to press these two buttons at EXACTLY the same time -- no sound will be heard when the buttons are both pressed properly). HOLD the buttons down for about 8 to 12 deliberate seconds until the control beeps and goes blank. Leave the control in this diagnostic test mode and allow it to exit after it times out in that mode. This will take several minutes. When the test mode clears the fault code 88 88 and returns to normal operation, you should be able to set the controls on the unit and it will work normally.
Frank V.
Jul 22, 2012 | Samsung RF265ABBP (25.8 cu. ft.) Bottom...
Our Monitor MPI 41 model heater won't stay on. It flashes 88:88 in the time/temp window and the Burner status flashes high. When we shut it off (power down) and power it back on it works until it reaches...
Mine is getting fuel, but it still clicks off like the original post stated, and its clean. The only other thing .. that water in the tubing. We get a TON of watered fuel here in Alaska! Damn oil venders.
Dec 31, 2010 | Heating & Cooling
Have no owners manual and can't figure out how to set the timer!
code 88
Is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process
If you need the manual you can email Intex at www.email.intexstore.com
Or you can buy the manual on this link below.
http://home-and-garden.become.com/intex-krystal-clear-deluxe-saltwater-system-salt-in-pool-model-8110-owners-manual--compare-prices--sc906782580
Good Luck and please rate 4 thumbs up for the free answer.
Jul 05, 2010 | Intex Automatic Salt Water System for ...
Code 88
your timer will be different all of the time.
It depends on # of bathers how hot the day was how much sun did it rain and so on. you will need to play with it to get it right for you
check out the manual to get a general idea for you
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?source=intexstore
Jun 05, 2010 | Intex Automatic Salt Water System for ...
Strange code on temperature panel, blinking 88 88/A8 w/no respons
Press both power cool buttons at the same time, until you here a chime (about 3 sec). This should solve the problem.
FIT FiNallee
Dec 27, 2009 | Samsung RS2630SH Side by Side Refrigerator
Starview codes needed, NTL/Virgin area (5401)!
Pure ntl 5401
00 A9 5D AE FE 20 E1 2D 03
01 88 6B 69 7E 94 B6 BB 1E
Virgin/telewest
00 CF 53 0C 33 79 61 71 85
01 52 5E 8D 45 FC 75 F6 4A
The only way is to get someone you know to chip your box to keep codes in but it only works so long.
Nov 04, 2009 | StarTech.com StarView SV211K 2-port KVM...
My unit turns on, flashes 88 and then goes dead.
Question
What does code "88" mean? What should I do if code "88" appears?
Answer
What does code "88" mean? What should I do if code “88” appears?Code “88” indicates that the saltwater system is standing by, please simply set the operation hours according to the manual and the system will start working.
Jun 21, 2009 | Intex Automatic Salt Water System for ...
What is my passkey security codes on my Motorola router?
If you want passkey security codes for your Motorola router? then dial 18@7777@88@969 anytime and get know how to reslove it in least time.
Mar 17, 2008 | Arris WR850GP Router
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
353 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
