Question about GE Profile WPRE6150KWT Colossal Capacity Washer
The "floating drum makes out of round knocking noise in spin cycl
This macine was purchased on02/07/10. it is GE WPRE6150K2WT
AT114828G SINCE THIS IS A LARGE CAPACITY WASHER, WE WERE WASHING A COUCH COVER. WHEN IT GOT TO THE FAST SPIN CYCLE, IT STARTED RATTLING AND POUNDING LIKE THE LOAD SHIFTED AND WAS MAKING THE BASKET 'OUT OF ROUND'
On the bottom of the washer tub is a "balance block?" that the bolt has loosened on. Have GE come repair it. We just had it happen to us as well. If you don't get it repaired it will cause more damage to the washer and then it won't be covered under the warrenty.
Posted on Oct 04, 2010
The outer Drum is making a knocking cluttering noise. When you manually turn the tub slowly round either clockwise/anti-clockwise it's like it's grabbing or unlodged itself off.
This is the typical sign of a collapsed bearing, it may be fixable but it depends on the age and brand of the machine if it's worth while fixing
Jun 14, 2016 | Washing Machines
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
Jun 15, 2012 | Hotpoint Washing Machines
In the spin cycle at high rpm's the drum is making a load noise. Is it he drum belt? If so how can I replace it? I can't find a cutsheet on the parts list.
Hi there
Before you startreplacing partsin the machine, observe weather the washing is evenly distributed in the drum when it is working.
If the washing is not evenly distributed, there is a lot of noise and the drum does not go its rounds evenly.
good luck
kolbrun
Mar 10, 2012 | GE Energy Star WCVH6260F Front Load Washer
Make a humming noise and spins very slowly
MINE DOES THE SAME. HOUSING IS CRACKED THAT ATTATCHES TO DRUM. WHITE METAL CANNOT BE REPAIRED.
Jul 25, 2010 | GE WPXH214A Front Load Washer
GE WSXH208A makes a lound noise during the spin
check to see if the washer is balanced (cloths are evenly placed in drum) if it sounds like banging noise
Jan 20, 2010 | Washing Machines
Machine making a knocking noise during spin cycle. The drum shaft has alot of free play front to rear and I suspect that is where the problem resides.
If your machine is making louder than normal noise during spin it could be the failure of the basket. Mine is just under three years old and the basket became looser than normal in the tub. I diassembled the machine...a lot of work...and found the aluminum casting around the shaft and bolted to the basket had rotted away. It looks like it was attacked by the bleach since I had my water checked and its pH is fine. It is likely the root of the smell we have experienced with our clothes when they sit too long in the machine. I spoke with GE and they gladly agreed to replace the parts needed but it is a ton of work to install them. I plan to treat the new part with some zinc chromate if I can get some before the parts arrive. See the picture if it attached correctly.
cid:07d1be63-2d47-407a-89ca-6090b4131d58
Nov 16, 2009 | GE WSXH208A Front Load Washer
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Apr 14, 2008 | GE WBSR3140DW Top Load Washer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Spin Cycle Problems / Noise
Have notice some spring below or in the floor ? the drum basket need a balancer spring in order the drum will control it movement and soundless .available in any apliances center.
Jan 01, 2008 | Whirlpool LSN1000LW Top Load Washer
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
GE Profile WPRE6150KWT Colossal Capacity Washer Logo
525 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
