Question about Eclipse AVN2210p MK II CD Receiver w/ Port. Nav and Travel Kit (73549006284) Navigation Kit
Does not work
Unit is getting power, checked main fuse and in-line fuse all good. Checked wiring harns getting power to unit, yet it will not power up? Can you help. Oh, the unit is only been used for very little and is a year and half old, came with me RV.
  • 503 Answers
Usual problem with most gps units that will not turn on is generally the battery. Don't ask me why but a lot of these units have a kill switch in them if the battery is no good. Test it out. If the battery fails you need to get another one battery that is. If the battery is good then most likely you need a new gps unit since the problem will be internal and i have no idea on which micro circuit to repair. Hope this helps
Posted on Jun 01, 2010
Rudd model ukab-030jaz
You most likely have a small 3 or 5 amp fuse on the circuit board on the indoor unit that has blown. You should turn the power off at the main breaker panel and open the cover and very carefully look for a small blown fuse. It will look like one that you use in your car. Then if it is blown, replace it with the exact same size and rating.
Aug 17, 2017 | Heating & Cooling
Frigidaire AC Window, Model # FAC107P1A2
please leave the unit unplugged from the main power for few hours and check if it works
Jun 29, 2008 | Frigidaire Heating & Cooling
Kenmore microwave 911 41479791 no power?
see this causes and fix it. God bless you
No Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
Sep 24, 2012 | Microwave Ovens
My M4155sp stopped working. No power at all (yes, I checked the power source). Replaced the fuse behind the keypad, - still nothing. Any suggestions?
please see the next step: God bless you
see the diagram attached.
Jul 26, 2012 | Whirlpool MT4155SP Microwave Oven
Unit will not start up. Push on button. Just dead. Appears to be connected correctly to a good battery. What could be the problem.? Are there fuses involved? Thank you for your help. Larry
There should be an in-line fusible link on the power supply wire and it should be checked for a blown fuse. If there is no fuse protecting the head unit, it may have received a voltage spike internally and caused internal circuit damage, requiring replacement. What can be done is remove the head display unit and wire it (with a fuse link) to battery posts and see if it powers up. If the unit does not come on, then the head unit will need to be replaced.
Dec 04, 2010 | Humminbird Piranhamax 220 Fishfinder
Fan works but light does not
Check the continutiy of the wire to the lamp holder and you will be able to find if there is a wire break, a fused lamp or a bad lamp holder. If the holder is not receiving power , the check if the switch is working fine, if the remote is faulty, in which case the pads must be checked cleaned or replaced. It will not be difficult but all you need is to trace the line voltage. Before the unit is pulled out manually switch the lamp from the main circuit and only if it does not work do you need to check on the combination unit. I hope you try this out. Good day
Aug 16, 2010 | Hampton Bay 24013 Ceiling Fan
Trailer Wiring Harness
The trailer fuses should be located out in the engine compartment inside of the fuse/relay junction box.
That is unless the trailer connector on the vehicle and the wiring were installed by someone who used an after-market trailer connector, and if that is the case then you might find the fuses up under the dash or around the fuse/relay junction box, and the fuses will most likely be inside of in-line fuse holders that are part of the after-market wiring. Here are some diagrams that might help you out.
Jun 04, 2010 | 1999 Dodge Durango
Cigarette lighter does not work
first check the fuse, next, get a light tester and see if you getting power to the lighter unit. two wires to your cigarette lighter one black for - and red for +, if you getting power, your line is good that mean your cigarette lighter unit does does not have a good contact to what ever is plugging in. replace the unit; if no power to the unit, test the cigarette fuse and see if the wire is hot. if not you have a short to the fuse. hope that help some..good luck
Jul 07, 2009 | 2000 Ford Taurus
Main door and window switch. I replaced the unit but there is no power to the unit. Is there a relay or a fuse? I believe I checked all the fuses. Before I purcased a new part that I had to order the...
WINDOWS MOTORS R PROTECTED BY CIRCUIT BREAKERS, GRAY METAL BOXES LOCATED IN THE INTERIOR FUSES BOX, WINDOWS R ACCESSORIES SO THEY R POWERED WHEN THE KEY IS TURNED ON-CHECK THE WIRES FOR DAMAGE OR WATER DAMAGE WHICH COULD HAVE DEADEN THE WIRE NOT ALLOWING POWER TO THE SWITCH
Aug 12, 2008 | Nissan Quest Cars & Trucks
No Indication...Dead Unit?
Firstly, try plugging the unit into another mains socket just to make sure it's not the socket that's faulty, or try another appliance in the socket you are using. Next, make sure the fuse in the plug hasn't blown. If you don't have a fuse tester, you can try the fuse in another similar appliance to see if it works. If it has blown and your spare lead is the same, there will be an internal problem. Inside the unit is an in-line 2 amp fuse. If this has blown you almost certainly have a power board problem. Always switch the mains off before plugging in or removing the mains lead from the rear of the unit. Back EMF can damage the appliance if you don't do this.
Dec 26, 2007 | Panasonic DMR-E55 DVD Recorder
Eclipse AVN2210p MK II CD Receiver w/ Port. Nav and Travel Kit (73549006284) Navigation Kit Logo
113 people viewed this question
Top Eclipse GPS Experts
Michael Vincent Cruz
Are you an Eclipse GPS Expert? Answer questions, earn points and help others
