Question about 2-Way Remote Starter
My remote is stuck in autostart and my car will not shut off. What should i do?
  • mis_kisha Jun 01, 2010
    my crimestopper remote is stuck in auto start. I've tried removing the battery from the remote but that didn't work. How can i get the vehicle to shut off?
    My crimestopper remote is stuck in the autostart position and my car will not shut off. I have tried taking the battery out of the remote and it did nothing. Is there a way i can shut the vehicle off until i get to a professional. it has been running for 40 mins.
  • 2,427 Answers
Get a screw driver,, remove screws on remote,, remove battery,, now the remove circuit board,, see the place where the button fits to press the contacts on the circuit board,, remove it..and clean it,, put everything back together..
Posted on Jun 01, 2010
  • 3,037 Answers
You should be able to open the remote. Either there is a screw on the back side or you can just pry the two halves apart with a flat blade such as a screwdriver and remove the battery from the remote. You can then try putting the battery in and see if the remote is reset, if not, take the remote to a dealer or the installer to get it fixed.
Let me know how this works out for you.
Benjamin
    That did not work. Is there a way i can shut the vehicle off now?
  • 12,061 Answers
All you can do, for now, is to remove the battery, from the remote. This will at least allow for Non-remote operation. If that doesn't work, then the receiver is faulty, and you will have to bypass the unit, until it is repaired. Then you need to troubleshoot, your problem. Then you need to check, the button(s) aren't stuck, or some sort of contamination under the rubber buttons, and the switch "Fingers" on the board. They often get dirty and false trigger. Reset the master unit in the car, then code them again, and try it again. If it still will not work, then you will have to get it looked at by a professional, most likely you will need a new remote? But sometimes the receiver gets a spike from the cars power, and this causes it to go faulty.
    I took the battery from the remote but the truck is still running, so how can i cut the car off?
2000 toyota corolla autostart stopped working
place the remote on the start button to depress it,if it start,replace the remote battery.
Jan 28, 2014 | 2000 Toyota Corolla
My remote car starter from autostart on a grand am 03 won't start or locks won't work after it died for about a week then changed the batteries
Check to be sure the new battery is a good new one, they set on the shelves for some time ya know. Then make sure it goes in the correct direction.Then refer to your owners manual if it needs reprogrammed.
Feb 18, 2013 | Cars & Trucks
Autostart 05-A433 valet mode
when I hand the remote vehicle starter that turns on and goes out after 3 to 5 seconds autostart 05-a433 4 button
Dec 23, 2012 | Vehicle Parts & Accessories
Astrostart 2100 autostart will not work all the time
It would almost appear that your battery is weak. If the engine doesn't freely turn over the remote start will not work because it recognizes the problem. I would also hope that you plug in your block heater when it's really cold.
Feb 06, 2012 | Chrysler Town and Country Cars & Trucks
I´ve forgotten in what order I should connect my old (80´s) separate modul hifi system´s remote cables. It shuts down imadiatly when you try to start it with the remote. If I disconnect the...
I would have thought that it should go from the amp to the tuner,then the tape deck and finally the CD deck.
I'm suspecting that your tuner is faulty and thats whats causing the system to shut down
Aug 27, 2010 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
The Ignition and autostart
Sound like a reversal of wires on the autostart. Should only cut out if you don't have the key in ignition and apply brake. Did you have this installed or was it in when you bought the vehicle?
May 28, 2009 | 1999 Jeep Grand Cherokee
Auto start will not function
you will need to have the remote reprogrammed probably at the dealer
Feb 03, 2009 | 2005 Pontiac Vibe
2000 Chevy Astro Autostart installation
You can't disable it, you have to buy a bypass modual to bypass it during remote start, the wires are in the ignition harness I have them in stock if you need one
Sep 07, 2008 | 2000 Chevrolet Astro
2002 Cadillac Escalade
might have a stuck relay you could just pull it out and see if the heater turns off its on a diffarant line it the adjuster so the adjustment still works
Feb 14, 2008 | Baby Gear
2-Way Remote Starter Logo
79 people viewed this question
Top Crime Stopper Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
John
John
Steve
Steve
Are you a Crime Stopper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
