Question about Philips Magnavox 27MS343S 27" TV
We don't have a remote for the television. We have tried programming the channels manually but it won't set. What can we do?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Philips Master
  • 848 Answers
Philips Magnavox 27MS343S 27"? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
1942LGR3P 715G1813 1 Philips ADTV1942LGR3P Power Supply Backlight Inverter
Posted on Feb 28, 2015
WHAT IS THE CODE TO PROGRAM A J.V.C. DVD INTO A PHILLIP UNIVERSAL REMOTE?
Posted on Apr 08, 2008
SOURCE:
Please program channel memory and all channels are unavailable I have fios so I only need channel 3
U still have the tv original remote?Yes,must used it to get into chanel 3.Because the manual buttons channels up and down on the tv bazel frame will skip channel 3.Only able get into channel 3 by manual channel buttons up or down only if it was save in the tv memory.Try website like Remotes.com to buy the tv original remote.
Jun 07, 2011 | Philips Magnavox 27MS343S 27" TV
I need a remote for my television
This link will assist you with getting a remote that will work with this television.
http://www.replacementremotes.com/PHILIPS/Buy-996500015582-Remote-Control.html
Mar 29, 2011 | Philips Magnavox 27MS343S 27" TV
I have 3 different RCA universal remotes and I cannot program any of them to my Phillis magnavox tv 27ms343s. I have tried multiple codes, auto search, and ways to initiate the code programer. Please help.
You really need to purchase a philips universal remote. Your RCA remote may not contain the option you seek. Some of these TVs are unique and will require the same name brand. Thanks for asking and show a few hands of support!
Oct 02, 2010 | Philips Magnavox 27MS343S 27" TV
Channel tuning 1994 Magnavox 27'' TV
U the remote to turn to the channel 3.
Nov 18, 2009 | Philips Magnavox 27MS343S 27" TV
Lost remote
use an universal remote, it comes with manufacturers codes for your TV
Aug 14, 2009 | Philips Magnavox 27MS343S 27" TV
Channel display
Here's a link to your owners manual if you need it. I'm sorry but I didn't see anything other than pressing the display button to see what channel your on.
http://www.m4c.magnavox.com/files/2/27ms343s/27ms343s_dfu_aen.pdf
Oct 16, 2008 | Philips Magnavox 27MS343S 27" TV
Cannot get 27" magnavox closed caption
I called the Magnavox tech support - put the TV on channel 2,
hit the cc button repeatedly and problem solved.
thanks for contacting me.
Jun 25, 2008 | Philips Magnavox 27MS343S 27" TV
Magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Jun 14, 2008 | Philips Magnavox 27MS343S 27" TV
Remote No Longer Works
It appears the remote sensor in the Television itself has stopped working. If the TV is still under warranty I would try to contact the manufacturer to see what they can do for you. Can you still change channels manually? If so, this is most likely the case.
Dec 29, 2007 | Philips Magnavox 27MS343S 27" TV
Need to find manual for remot
I tryed to look this up for you and I did find the remote on the web site but when I tryed to view the documentation on the remote a note came up and said that there was no on-line documetation for this remote, but I could contact Phililps for it at: 1-888-PHILIPS (1-888-744-5477) Good Luck
Apr 26, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 27MS343S 27" TV Logo
197 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
