Question about Cycling
Front wheel woobles as it turns. How do I adjust the spokes?
  • 10,319 Answers
At bicycles shops they have a wheel mount that holds the wheel in place while the spokes are tighten. The wheel holder has a arm that adjust to the height of the wheel. That way as the wheel is turned the closest high spot of the wheel gets its respective spokes tighten to true up the wheel
Posted on Jun 01, 2010
Fron end not stable on 1998 flhtuci
Hi Anonymous, and the usual suspects are:
1. Improperly loaded motorcycle. Non standard equipment on the front end such asheavy radio receivers, extra lightning equipment or luggage tends to cause unstable handling.
2. Incorrect air suspension pressure.
3. Damaged tire(s) or improper front-rear tire combination
4. Irregular or peaked front tire tread wear.
5. Incorrect tire pressure.
6. Shock absorber not functioning normally.
7. Loose wheel axle nuts.
8. Excessive wheel hub bearing play.
9. Improper vehicle alignment.
10.Steering head bearings improperly adjusted.
11. Tire and wheel unbalanced.
12. Rims and tires out of round or eccentric with hub.
13. Rims and tires out-of-true sideways.
14. Shock absorber improperly adjusted.
15. Worn engine stabilizer links.
16. Damaged rear engine isolation mounts.
17. Swing arm pivot shaft nut improperly tightened or assembled.
Good luck and have nice day
Jan 09, 2014 | Harley Davidson Motorcycles
Front wheel woobles
Loose suspension part? Control arm, ball joints, struts? Wheel bearings gave out?
Sounds like too much for a steering part-like a loose tie rod.
Have a garage check it out. Unsafe to drive-might fall off anytime.
Nov 16, 2012 | 1997 Chevrolet Lumina
My rim is bent is there a way for me to straighten it. I have a sun cr18 rim.
If you have a kink in it, then you might be able to improve it, but it won't be like new. If it is a wobble, then you need to true up the wheel by selectively tightening spokes. This takes some practice, but the only tool you need is a good spoke wrench. Google "how to adjust spokes" and you will see videos like this:
www.youtube.com/watch?v=TcoSgl3qiHU
Good luck.
Oct 15, 2012 | Shimano Sun CR18 32H Deore Qr 26 X 1.75"...
Front wheel woobles
Is the axle loose in the frame (quick release improperly installed); the axle loose in the wheel (hub bearings shot); or the spokes all loose or the rim untrue?
We have limitations to diagose physical problems.
Web searches for any or all of those malfunctions will lead to answers. Bike Shops will find/fix the latter two for you.
Aug 07, 2011 | Huffy 26 in. Cranbrook Cruiser Bike
Front driver tire wobbling and very unstable lug nuts are tight
Is there and kind of squeling or grinding noise when the vehicle is driven?
The wheel bearings could have failed and are allowing the tire to wobble.
Is there a lot of play or a clonking noise when the steering is turned from side to side?
You could have a bad steering joint and this is allowing the wheel to wooble.
Mar 11, 2011 | Toyota Camry Cars & Trucks
Can you teach me how to tiet the spokes to the rim?
If you are meaning how do you tighten the spokes, you'll first need a spoke spanner.(you can get one from a bike shop if you havn't got one).
Next raise the wheel you want to adjust off the ground.
Next, if they are all a little loose,mark one spoke with some tape.Starting at that spoke you marked tighten each one an eighth of a turn till you get back to the tape marked spoke.
Next, tape a small piece of plastic(I use a zip-tie) to the L/H fork leg(for a front wheel) or the L/H side of the swing arm(for a rear wheel) so its nearly touching the rim.
Now slowly rotate the wheel & watch the gap between the rim & the zip-tie to see that the wheel is true.
If the gap gets bigger stop there & loosen the spokes(one quarter of a turn) on the rim that are on the R/H side at that spot & thghten the spokes that are next to the zip-tie. This effectivly pulls the rim across
& reduces the gap. This is called trueing the rim.
The gap(run-out) can be 2 to 3 mm and that is ok.
Hope this helps.
If you ment how do you replace the spokes then this is much more tricky. I suggest you go to an expert but if you really must do it yourself you'll have to tell me what sort of bike, which weel(front or rear) it is plus the year/model & i'll try & talk you through it.(but it WONT BE EASY)
Regards Andrew Porrelli
Dec 06, 2009 | 2004 kawasaki KX 250 F
Front wheel rubs
What is it rubbing? the fork? Is the wheel true? Are the forks equally extended. Pull the font wheel and have suzuki ck. If it is a spoke wheel then it just might need to be trued through adjustment of the spokes.
Jun 08, 2009 | 1995 Suzuki VS 800 Intruder
Front left side axle needs replaced, 2000 Jimmy..need approx cost
When you turn and get the wooble, which way are you turning, right or left.
When you say wooble, does the steering wheel move left and right or is it a sensation you feel in the "seat of your pants".
Let me know.
Regards,
Apr 16, 2009 | 1999 GMC Jimmy
Front wheel wobbles
More than likely the wheel is out of true. There are 2 choices,
1 Buy a spoke wrench and attemp to true the wheel. You can do this by spinning the wheel to locate the spot where the wheel goes furthest to one side then tighten the spoke coming from the opposite side. Do this slowly 1/2 turn at a time. Do not over tighten the spoke. It may be necessary to loosen the other side slightly.
Alternate spokes between both sides of wobble.
2 Take bike to a good local bike shop to be tuned and have the wheels trued. Most shops offer a tune up at low cost. A well tuned bike will last a long time.
http://www.sansaworld.com/
http://www.sansaworldmp3.com/
Apr 06, 2009 | Freestyle Mongoose Bmx & Owners Manual -...
Cycling Logo
150 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
