Question about GE Profile PSS26NGS Side by Side Refrigerator
Power is on, heating up
The power is on, and the temp is heating up, can I reset it somehow?
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerPower is on, heating up - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jun 01, 2010
I just changed the heating element and thermal cutoff fuse. after putting everything back and turning power on, the clean light blinks 7 times. i am not able to reset control board using the reset...
the thermostat is shorted out, You need to change that and the run diagnostic to clear the code which is high temp ,heated dry, high temp ,heated dry, high temp heated dry key dance and let it do its thing. When it is done you should have no more problems. If you change the thermostat. Usually locate near the front under the near the electrical box but not always.
Mar 14, 2015 | Kenmore Dishwashers
My KUDS011JBSO undercounter dishwasher is blinking the normal wash light. What do I need to look for to fix this?
Hi
If light is blinking then it may be an issue with heater circuit, door switch or the thermal fuse, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the thermal fuse located on the control or the door switch that is bad and should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 31, 2011 | KitchenAid Dishwashers
Maytag dishwasher MDB6160AWB "Clean" indicator
Hi
It may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 16, 2011 | Maytag Dishwasher
Washer will not start. "Clean"
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 20, 2011 | Dishwashers
How to heating. it's always cooling
Keep heat mode and temp setting+5 degree than your room temp.Still no heat check power to heating element. No power replace heating temp senor. If it's with RV, check power to RV and also warm in suction pipe(higher size pipeline near compressor).
Jan 27, 2011 | LG LS-K2430HL Heat Cool Mini Split Air...
My heater just stop working by himself. HWhat can I do to fix it ?
Check temp setting, mode and then power to heat. Please follow the tips:
To get proper heat, keep your temp setting at +5 degree than your temp and also mode in "heat "position. If still noheat, check your heating sensor for closed circuit by an OHMs metre.It it'swith RV, check power to RV.Ifit's with heating element check power to element. If power is there but stillno heat means element defective. Replace new heating element. And also check heat temp sensor. Thanks.Helpful?
Jan 20, 2011 | DeLonghi Heating & Cooling
Clean light flashes seven, shut power off will not reset
Clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Dec 12, 2010 | Dishwashers
The printer has stopped functioning all together.
C3851: Abnormal Low Temp. (Heater)
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Mar 31, 2009 | Konica Minolta bizhub C250 All-In-One...
Deep Frier power indicator light is on but will
Most fryers have what is called a hi limit. When the oil temp reaches a certain Max temp this switch opens the circuit and will not allow the unit to heat. On commercial fryers, the hi limit has a really small red plunger button. Push it in to reset.
Mar 28, 2009 | Kitchen Appliances - Others
The drier spins but no heat
There is typically not a reset for heat.
Some MAY have a t-stat that has a small red button in the center that can be reset, but doubtful. If so, you need to find why it over-heated.
That said, there are many causes for not heating when it still runs.
1) Power. Motor runs on 115 V, heat on 230 V. If you have partial voltage to the dryer, this will cause your problem.
2) Heating system has many components in series, any one of which will cause the problem.
  • Motor start switch
  • Thermostats, high temp, run temp, etc.
  • Timer
  • Heating element, (most likely)
  • Wiring to all compontents
These are a few ideas.
Gary
Nov 30, 2008 | Hotpoint Dryers
GE Profile PSS26NGS Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
