Question about Broan-NuTone Best By Broan BER02IS 48" Island Hood Central Housing w/ Internal Blower, 500 CFM & Electronic Contr...
How do i remove an broan lr 3161 bathroom fan
2 Suggested Answers
  • 7 Answers
SOURCE: broan fan cat h 500 housing 115v 60 c 1.5a lr 31619
Customer Service: 800-558-1711
Technical Support: 800-637-1453
Posted on Aug 24, 2009
Tip
Broan Bathroom Fan Care and Cleaning
<p>One of the most common <b>bathroom fans</b> is the <b>Broan brand ventilation fan</b>. These fans come in many configurations and variations. Because of the environment that these fans are in and the placement of these fans they will get very dirty over a period of time and will need to be cleaned from time to time. <b>Cleaning bathroom fans </b>can be fairly easy if you have a few tips about how to do it.<br /> <p> <br> <p>To clean the fan the inside of the fan must be accessed first. To get to the inside of the fan the cover must be removed. Most of the covers simply will pull downward and away from the ceiling. There are a couple of springs, one on each side the snap the cover up and hold it in place. On some models there can be a screw that holds the cover. It will be visible right in the center of the cover. If no screw is visible then you can assume that it is a spring type cover. If there is a light in the cover you can remove the plug and the light will come right with the cover.<br> <p> <br> <p>After pulling the cover down simply squeeze the springs together slightly and the cover will come completely out and you can take it to your sink to wash it. Then take a vacuum or a damp rag and clean the inside of the fan compartment. If you look closely you will see that the fan assembly has a plug that can be pulled and the fan assembly can be removed by either removing a couple of screws or by placing a screw driver between the fan assembly and the side of the box and snapping out the fan assembly.<br> <p> <br> <p>Once you have the fan assembly out you can then use compressed air, like you use on your computer keyboard, or a damp cloth to clean the fan assembly. The compressed air works the best on the blower wheel and in some cases a small screw driver may be needed to remove caked on dust inside the fins of the fan.<br> <p> <br> <p>With you vacuum, you can now clean out the rest of the box and even into the vent hose a little bit. Be careful not to destroy the flapper, as that is what stops cold air from being pulled back into your home while the fan is off. Wipe down the box to complete the cleaning.<br> <p> <br> <p>The fan can now be reassembled by reversing everything and placing it all back as it was before you removed it. Be sure to remember to plug the fan motor back into the socket. The light may also need to be plugged in if you have a light in the cover.<br> <p> <br> <p>You will now have a nice clean fan again. <br> <p> <br> <p>If you want to <b>replace the fan</B> because it is broken worn out or noisy you can often <b>buy replacement bathroom fan parts</B> or even a new fan that will fit in the same box. Upgrades are available to fit existing boxes also. To find <b>bathroom fan upgrades</B> and replacements go to <a href="http://www.broan.com/">www.broan.com</A><br> <p> <br> <p>At <a href="http://www.broan.com/">www.broan.com</A> you can also <b>order <span> </SPAN>broan replacement parts</B>, <b>download broan manuals</B>, and get <b>installation tips for your broan fan</B>.
on Nov 17, 2010 | Home
My bathroom exhaust fan has a dial timer. Sometimes lately the fan does not come on for a couple of minutes after starting the dial timer. Is that likely to be a problem with the dial timer, or with the...
This could be the timer or the motor. The timer could be going out or not starting up in the right position. Has anyone worked or removed the timer knob, it could have been put on just a little off causing the switch to be off just a bit. Again the motor could be going out,such as the bearings inside. I would see what type of warranty is on this fan. I know these exhaust fans can get a little pricey, so I would see what warranty options I have.
Mar 06, 2011 | Broan-NuTone Fan,Bathroom Exhaust Broan...
I need help hooking up my bathroom fan and light i have three wires going to the bathroom fan and light white black and ground i want a swith to turn off the bathroom light one to run the light to the fan...
Right now a single switch turns on both light and fan.
You want to put in a double switch to control light and fan separately.
But the problem is there is not a separate wire to each the light and fan.
You need a separate wire to each, but the circuit wasn't wired that way.
Usually when the circuit is wired for separate control, there is a red wire that also goes to ceiling box.
Unless you run another wire to the ceiling box, it won't be possible to control light and fan separately.
Electrician can do this pretty easily if there is attic space above bathroom.
Oct 17, 2010 | Broan-NuTone Broan 68W White Decorator...
How to oil a broan bathroom fan motor
The fan motor is pre-oiled and sealed so it can not be oiled if fan motor is squeeling then motor replacement is the only option. You can get replacement motors which is usually cheaper than buying a whole new fan. Will need to know the model # of broan fan. I hope this information was helpful. Please rate the information given. Good Luck and have a great day. Jeff
Apr 02, 2010 | Home
I need an exploded picturial view of the BROAN fan and light kit. Thanks
go to www.broan.com from there you can look up that fan/light combo and download the installation manual which will give you the exploded view.
heatman101
Jul 02, 2009 | Broan-NuTone N-8663RP Combination Light...
Bathroom fan
You'll be able to access the motor to service it and the wiring junction box from inside the bathroom. Please rate this answer if it was at all helpful.
Jan 31, 2009 | Broan-NuTone Designer 721 Ceiling Fan
Broan fan cat h 500 housing 115v 60 c 1.5a lr 31619
Oct 13, 2007 | Broan-NuTone Best By Broan BER02IS 48"...
Kitchen Ranges Logo
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
