Question about Whirlpool GHW9400 Duet Washer
Cycle stops after 25 seconds and time light start blinking
Six year old unit. Problem with F6 code about two months ago but reset after unplugging and had been working well.
Today the wash cycle stops after about 25 seconds and time light starts blinking. Pushed end of cycle button over 3 seconds - sometimes it worked but then same problem. Unplugged washer and after waiting up to 15 minutes and plugging back in then same problem - did several times waiting a shorter duration. Unplugged then disconnected and reconnected wire connections after removing top of washer. Control unit? Timer? Help
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F6 is drive motor tachometer error, which means that the control is unable to detect the motor speed properly and so the machine will shut down. If this happens at high speed spin the door will get unlocked after 3 minutes. To resolve the issue you’ll need to:
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
However, from what you have described the issue seems to be with the control unit that should be replaced, but still check all the above things. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 01, 2010
  • his3012 Jun 01, 2010
    Rylee:
    Just to confirm your recommendations. Even though there has been no error code and the time is blinking when the cycle stops, this is an indication that the controller needs to be replaced if the fixes you suggested do not work. Correct?
    Thanks,
    Mike
  • Rylee Smith
    Rylee Smith Jun 01, 2010
    Yes, you are right Mike. Please post back if you need further assistance or accept the solution if the issue is resolved.
    Thanks
    Rylee
All the lights light up, but washer won't fill when I push the start button. It is barely 3 years old. This happened before and then after I left it a while, when I pushed start it filled. I tried...
Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds. You may need to do it several times before it resets. After resetting the inverter board, put the machine in a spin cycle and see if it runs. If not, check for a green blinking light on the inverter board. It will flash failure codes according to the picture above. If no light you probably have a blown fuse built into the neutral side of the harness on the white/red wire.
GE Hydrowave notes
Feb 10, 2011 | GE WWSE5240G
The washer is only 1.5 years old and has been working fine until a recent power outage. After the poer was restored, the spin cycle quit working. Any suggestions?
Reset the motor is what you must do.
To Reset the Inverter Board: Push the timer knob in so the washer is idle. Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds.
Hydrowave Repair Notes
Nov 15, 2010 | GE WBSR3140DW Top Load Washer
Same problem
It sounds like the classic "timer problem" that requires a "kit" (mostly capacitors) to repair it. To have someone do it (such as your service person) for you can be expensive and time consuming. Sets that are 5 or more years old usually have other problems too which, simply put, is a complete cleaning of all mirrors, fans, and filters.
Jun 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
TV shut off while watching and won't come back on
It seems this is a self diagnostic function. the official sony codes are as follows
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
It sounds like you have a video input problem. Have you unhooked all inputs from the TV and tried to power it back on by itself? Hope this helps
Mar 18, 2009 | Sony Televison & Video
Blinking green light and clicking noise AFTER bulb replacement
do this. press and hold device and menu button on set for 5 seconds. this will retrieve a 2 digit error code .. the led will flash the first digit and pause the flash second digit. This unit is known to have capacitor problems on the power board. getting to these capacitors involves taking alot apart. let me know error codes and we can continue troubleshooting
Jan 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Kenmore Elite won't start
First of all, make sure haven't inadvertently locked your control panel. Press and hold the DRAIN/SPIN button for 3 seconds to see if it clears. How long did you unplug the washer for? The manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. Try this first and let me know what you have. It could be you only have a minor glitch.
If these preliminary checks prove unsuccessful, you may have a control panel problem. Do you have any error codes deisplayed? Please reply and let me know what you have.
Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore dishwasher 587.15159400
to whom it may conern:
about six month ago I purchese the dishwasher, But It just stopped working, the green clean light just blinks all day and night, but wont start it's, when I push the red start button comes on but turns off about 5 seconds later turns of, and wont run and clean my dishes. Could you please help me get strat the dishwasher to start up and run again. Thank you patrick c smith
patrick c smtih
phon 951 805 5187
19050 rockman street
lake elsinore, ca., 92530
actt, 5049 9485 2176 1660
Aug 13, 2008 | Kenmore 15769 Built-in Dishwasher
Buick Skylark won't start. intermittant problem
Had similar problem Does the 'theft system' light come on or blink? If so, get it checked out by a good electronic troubleshooter. If it doesn't start, try locking and unlocking driver door twice, and it should reset and start.
Jul 21, 2008 | 1997 Buick Skylark
Washing Machines Logo
41 people viewed this question
Dan Webster
Dan Webster
Sal De
