Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Water in inside bottom
I have the 19 cu ft model with an ice maker, Water collects under the bins in the bottom. I cannot tell from where the water comes.
    Problem Solver:
  • 14 Answers
I would try vasoline petrolium jelly on the door gasket. If the gasket is not sealing correctly, air will get in and condensate. Also check the gasket for any cuts or tears too. This old trick, My boss would charge $30.00 for when I worked on appliances.
Posted on Jun 01, 2010
The arm in the ice maker is stuck in the "up" position
unplug the unit and check if the icemaker timer is working alright. replace with a new one if it is messed up. thanks .
Mar 12, 2015 | LG LFC25770ST (250 cu ft) Bottom Freezer...
Ge refrigeration model 20-25 icemaker not making ice
Fill ice maker with tap water and allow the water to freeze. If when the ice maker cycles and drops ice into ice bin it chooses not to refill with water at end of the cycle. That would point to the dual water control valve. If ice maker does nothing when filled with tap water that will indicate a defective ice maker. The model number you listed does not appear to be correct. Look around the fresh food section door frame and see what you have. This could be the ice maker or the dual water control valve causing this problem. Thanks Sea Breeze
Nov 16, 2012 | GE 20.3 cu. ft. Bottom Freezer...
Ice dispenser will not dispens ice . light dims when pushed. ice maker works fine
It may be a good Idea to remove the ice bin, clean and dry ant the same time with bin removed see if while pushing the door light switch and the dispense ice control if the auger fork in the rear of the ice bin that normally turns the auger will rotate. Sometimes ice or water collects in the bin and locks the motor from turning and sometimes the motors go bad. Tell me your results, Thanks, Sea Breeze
Apr 23, 2010 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Ice Maker leaks water inside the freezer
I see you said you looked and the water valve is off but the only that I know of this happening is a defective water control valve. Like a dripping faucet that when off slowly drips until the ice forms and then one the ice maker dumps ice and tries to refill the water goes in every direction. Unplug water valve to confirm what I am saying, Tell me if it continues to leak. Sea Breeze
Apr 19, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
Ice Maker stopped making ice - the unit is only 4 months old
Lets try this because I need the model nuber first befor giving the complete solution. Pour water into Ice maker tray turn on and let freeze. If Ice drops into ice bin and water does not come on the the dual water cotrol valve. If ice maker does nothing it wil be you ice maker or the grees F. See around door for model number, Thanks Sea Breeze
Apr 09, 2010 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Whirlpool Refrigerator ET21GM LEAKING water ALL OVER INSIDE
there is a drain under the coils in the freezer. it is frozen and the water has no place to go. hairdryer and a lot of patience. a hairdryer can melt a freezer /warning.
Jun 09, 2009 | Whirlpool ET1MTKXKQ White 20.9 Cu. Ft....
Water collects in bottom of refrigerator and gets in bins
there is a cup in the back wall of the fridge that is the drain pull it out gently and clean it plus take a small hose and blow through the small hole if there is no cup check under the crisper to see if the drain hole is there
Apr 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
136 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
