EVERYTHING RUNS... NOT COOLING.. CAN'T LOCATE COILS
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jun 01, 2010
Why is my lg portable ac leaking water from bottom of unit
There should be a drain pipe at the side or bottom of unit to run a drain line. Locate drain and clean it out .
Feb 26, 2018 | LG Heating & Cooling
Frigidaire Gallery FRS24XGCW Regrigerator is not cooling. The freezer side is about the temp of the normal refrigerator side.
Remove the grill along the bottom of your refrigerator. Locate the drip pan, using a flashlight if necessary. The pan should be sitting on a set of black condenser coils.
Remove the pan and wash it. Use a mixture of warm, soapy water and bleach to kill the mold.
Reinstall the pan and the grill.
Locate the coils. They look like thin, black radiators and may be underneath the fridge or attached to the back.
If the coils are on the back, pull the refrigerator away from the wall, then vacuum the dusty coils, using the brush and crevice attachments. Reinstall the refrigerator grill.
If the coils are underneath, pull off the grill and remove the drip pan. Vacuum the dusty coils, using the crevice attachment to get between them. Take care not to damage the delicate coils. Reinstall the refrigerator grill.
Mar 01, 2011 | Frigidaire Refrigerators
My ice maker does not work but the freezer is only cooling to 20 degrees. I do have water at the door and do not seem to have an over frost issue. The control is nearly as cold as it will go and the...
evap fan runs when the compressor runs / so the unit is running most of the time . you may have dirty cond coils under neath or the fan by the compressor is not running . this cool the coils and promote cooling . ck them and clean them . mm hope this helps .. feed back pls ..
Dec 11, 2010 | Refrigerators
Freezer runs ok. refrigerator is not cooling. coils are clean, light comes on
If everything is running and no frost is builtup in the freezer. The You would need to check the seal system. For that you should call a service tech. You can make sure the condensor fan is running.
Sep 08, 2009 | Kenmore Refrigerators
If the compressor runs continually will it burn itself out?
how hot is the top of the compressor head?is unit cooling/freezing o.k? if not cleal both coils(cond&evap)dirty coils or poor cooling could be coils or low on freon(refrigerant)
Aug 15, 2009 | GE Profile¿ 26.5 Cu. Ft. Stainless...
Upright freezer quit cooling, interior fan runs, compressor runs
The coils are most certainly there probably located under your unit. Clean them thoroughly. Look under and to the very top of that space.
Jul 08, 2009 | Kenmore 50522 / 50524 Side by Side...
Refrigerator not cooling, frosting up
You might try GE customer service and ask where to locate the defrost timer,since that sounds like your problem.
Nov 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Not cooling
Possible loss of refrigerant charge from a leak in the evaporator area. The cooling coils on these unit are exposed to acidic moisture from products stored such as tomatoes, pickles and other high acid foods. Thes Evaporator coils are replaceable.
Jun 08, 2008 | True 598-TSSU608ADA SandwichSalad Unit 155...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
