Question about Honeywell Programmable Thermostat Heater
I have a honeywell nonprogramable thermostat focuspro5000 i dont know how to change the reading from ferenheit to celsius.. thanks phil
    Guru:
  • Honeywell Master
  • 588 Answers
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Posted on Jun 01, 2010
How do I switch the honeywell RTH4300B thermostat from reading in Fahrenheit to Celsius?
To start you have to push and hold the up and down buttons simultaneously until the screen displays "setup" across the top. There will be a number on the left, and a number in the right. Press the UP arrow until the number on the left reads 14, The number on the right should read 0. Press the DOWN arrow to change it to 1. Once this has been done you can press the RUN button to save the changes, and exit the setup screen. Your display will now read Celsius,
Apr 18, 2013 | Honeywell Programmable Thermostat Heater
Temp dispayed in celsius.
Inside the thermostat (behind) are 3 tiny DIP switches.Switch #3 should be set to OFF or click it to the left to display *F.You can use a tiny scerwdriver
Nov 07, 2011 | Honeywell Electronic Programmable...
How do I change my Honeywell FocusPRO6000 TH6110D1005 thermostat to from Fahrenheit to Celsius?
Press and hold the up arrow and fan buttons until the display changes. Then press Next until you see 14 in the display. Change this value to 1 (with the up and down arrows) to get Celsius. (O is Fahrenheit.) Press Done to exit and save the setting.
The manual is available here: http://customer.honeywell.com/Honeywell/ProductInfo.aspx/TH6110D1005 . Scroll to the bottom and choose a manual then press Download. This particular section is in the Installer's Guide.
I hope this helps.
Jan 30, 2011 | Honeywell Programmable Thermostat Heater
How to you change ferenheit to celcius?
Tc = (5/9) x (Tf-32); Tc = temperature in degrees Celsius, Tf = temperature in degreesFahrenheit.
Example: 40 deg. F minus 32 = 8, 8 x 5 = 40, 40 divided by 9 = 4.44 deg. Centigrade.
To go the other way:
Tf = [(9/5) x Tc]+32; Tc = temperature in degrees Celsius, Tf = temperature in degrees Fahrenheit
Example: -10 deg. C x 9/5 = -18; -18 + 32 = 14 deg. F
See also: http://www.csgnetwork.com/tempconvjava.html
Jan 29, 2011 | White Rodgers White-Rodgers 1F85RF-275...
How do I switch the honeywell pro4000 thermostat from reading in Fahrenheit to Celsius?
Hi, The procedure is fairly simple.... the easiest way is for you to look up the manual and have the proper steps right in front of you...
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Nov 07, 2010 | Honeywell Programmable Thermostat Heater
I have a honeywell non prog thermostat and dont know how to change the redaing from fareheit to celsiuc focuspro5000 thanks phil
in your manal it shows what to do .if no mamal call honeywell and they will walk you through it or go on line honeywell ,com
Jun 12, 2010 | Honeywell Programmable Thermostat Heater
I have a Honeywell RTH6400B thermostat that reads in farenheit.How do I switch it to Celsius?
go to myhome.honeywell.com and search for a manual for your model number thermostat on the right hand side of the page
Oct 01, 2009 | Honeywell Programmable Thermostat Heater
Can't change my thermostat from fahrenheit to celsius.
When you do your system setup, Function 320 controls your temp. format. Set Function 320 to 1(celsius); Then press DONE. This will solve your problem.( Function 320 is defaulted to 0-Farenheit).
Feb 15, 2009 | Honeywell Programmable Thermostat Heater
Switching thermostat from farenheit to celsius
My thermostat was set on celsius and couldn't get it to change back to fahrenheit. My son suggested pressing both up and down arrow buttons at the same time and it worked. It changed back to fahrenheit.
Feb 16, 2008 | Honeywell Programmable Thermostat Heater
Asap help
if you still ahve the manual it should tell you how to get a reset back to factory defaults. you can go from there. if nothing else, unhook the stat, pull the batterys and let it sit a while. it should forget everything. if you tell us the stat model we might be able to better help
saskcat :)
Jan 20, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
93 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
