Question about Ingersoll Rand SS5L5 Ir Electric Stationary Air Compressor 5HP. 60 Gallon Single Stage Vertical
My SS5 won't make any pressure. I drained the tank to around 10 psi to drain moisture out of the tank and it built the pressue back up to around 120 psi but won't build any higher. The shut-off point is 135 psi. Any ideas?
    President:
  • 1,902 Answers
Sounds like the pressure regulator has gone bad. That controls how much PSI your system is aloud to have. If this fails it will not fill to max capacity. I would replace that and all will work just fine.
Please rate
Posted on Jun 01, 2010
How do I take apart a dewalt d5141 compr3ssor?
This number is for the D20114 its the safety valve that can not be set to a max basic pressure .
its strange but its not adjustable it can be defect i have one time the same the experience there is not a adjustable Pressure Switch on this model , the moast compressors have a 8 to12 bar adjustable.pressure switch.
Very important This safety valve gives an electronic brake between the pump and to a end of top about 10 bar . if its not switching off then a drain valve opened . and blows all the air out. (but only over 10 bar ) the max pressure on the tank , the moast tools are working on a pressure from 6 to 8 bar.
Checking Safety Valve
WARNING: Risk of bursting. If the safety valve does not work
properly, over-pressurization may occur, causing air tank rupture or
an explosion.
Before starting compressor, pull the ring on the safety valve to
make sure that the safety valve operates freely. If the valve is
stuck or does not operate smoothly, it must be replaced with the
same type of valve.
Draining Air Tank (Fig. 1)
WARNING: Risk of unsafe operation. Risk from noise. Air tanks
contain high pressure air. Keep face and other body parts away from
outlet of drain. Use safety glasses when draining as debris can be
kicked up into face. Use ANSI S12.6 (S3.19) ear protection as air flow
noise is loud when draining.
NOTE: All compressed air systems generate condensate that
accumulates in any drain point (e.g., tanks, filter, aftercoolers,
dryers). This condensate contains lubricating oil and/or substances
which may be regulated and must be disposed of in accordance with
local, state, and federal laws and regulations.
1. Ensure On/Off switch (A) is in the OFF position.
2. Move compressor into an inclined position so drain valve (H) is
at the lowest point (this will assist in removing moisture, dirt, etc.
from air tanks)
3. Place a suitable container under the drain valve to catch
discharge.
4. Grasp black lever on drain valve.
5. Slowly rotate lever to gradually bleed air from air tank.
6. When air tank pressure gauge reads 10 PSI (275.1 kPa), rotate
valve to the fully open position.
7. Close drain valve when finished
Apr 19, 2015 | Dewalt Air Tools & Compressors
Pump not holding presure
If you have a bladder - type water pressure tank, it probably needs to be purged of air and then pre-charged to 18 psi. There may be directions on the side of the tank. Turn the water Pump off. Drain the tank of water. Check the pressure of the tank at the air valve on top of the tank. The pre-charged pressure of the bladder is set to 2 psi below the lower pressure set by the pressure switch, so in your case, the low end pressure is 20 psi. Therefore, the pre-charge pressure of the tank is 18 psi. If you set the pressure switch to operate at 30 -50 psi, then the pre-charge pressure would be 28psi., etc. Once the pre-charge pressure is set, turn the pump back on. ( don't forget to close the drain valve). The system should cycle normally. A tire gauge works to check the tank pressure. An air compressor may be used to charge the tank, but be careful not to over- inflate the bladder. A tire air pump may also be used. Hope this helps....
Apr 06, 2014 | Utilitech Plumbing
My campbell 0.33 runs but won't built a pressure
Check that the drain cock on bottom of tank is shut off,or leaking.?
Jan 28, 2013 | Campbell Hausfeld 0.33 HP 2-Gallon 100 PSI...
When turned on ,pump runs for about 8 to 10 sec. stops,then starts back up then repeats as long as water is on
You have a waterlogged pressure tank. To fix this problem, follow these steps:
1. Determine your cut in pressure by looking at the pressure gauge and seeing when the pump turns on.
2. Shut off the electric to the pump and shut off the main water to the house.
3. Drain the water from the pressure tank completely. You can do this by opening the drain at the bottom the the pressure tank.
4. With a air compressor and tire gauge (don't use pressure gauge on the pump) put enough pressure in the tank so that it is two psi less than the cut in pressure. So if your pump turns on at 30 psi, put 28 psi in the tank.
5. Turn the power back on to the pump and let it run till it shuts off.
6. Turn the water back on to the house.
7. This should fix the problem. If it does not, the bladder in the pressure tank is bad and the whole tank needs to be replaced.
This is a general fix without knowing your make and model of pump or pressure tank. This is a universal way of fixing this problem.
May 23, 2011 | Plumbing
I have a compressor that will run but if it gets up to pressure the tank will bleed all the air out. I turn the compressor off around 90 psi and I can use it then I have to turn it on then off before 120...
If I understand correctly the safety valve, item #64 on the parts diagram, is opening at 120lbs and not shutting until the tank is drained. If that is the case you most likely have a bad safety valve, part #881-493 which is available from http://www.ereplacementparts.com. The non-return valve is basically a check valve that prohibits the flow of air from the tank back to the cylinder. I hope this helps!
May 21, 2010 | Hitachi EC12 Portable Electric 2hp Air...
2 hp 120 v motor on compressor. motor will not start under load
bleeder valve is bad or dirty drain air unplug machine pull the back up plate control plate and make it shinny with emmeory cloth then clen it and try again, if it still does the same thing your going to nedd to replace unloader valve.
Apr 14, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Should air compressor tanks be drained daily and if so why should they not be left under pressure from day to day? Will the air under pressure in the tank cause additional water vapor to accumulate?
No additional moisture will accumulate over time. Some existing moisture may condense as the unit cools down, though. If you drain off the water at the end of the day, I see no good reason to completely drain the air.
Oct 24, 2009 | Porter Cable Cable 135 PSI, 60 Gal. Oil -...
Comperssor losses pressure after 50psi
Locate the moisture drain valve, open and drainn any and all water fron the air tank and then run it and watch the psi it should build as normal. if this does not help feel free to contact me at davenormandeau@hotmail.com
May 02, 2009 | Air Tools & Compressors
Hard to start
U are right about the gas draining back to the tank, the electric fuel pump in the fuel tank has a check valve built into it to prevent drain back, the system should always have pressure, to check this u will need to hook up a fuel press test guage at the test valve on the top of the eng near the injectors, run the engine and shut it down, the pressure should not drop more than 5 PSI overnight.
Jan 17, 2009 | 2008 Volvo S40
Ingersoll Rand  SS5L5 Ir Electric Stationary Air Compressor 5HP. 60 Gallon Single Stage Vertical  Logo
313 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
