Question about Amana AMV1162 Microwave Oven
Oven won't heat food.
Oven wil not heat food.
I have shut power off,
then reconnected.
Still not working.
  • cliff469 Jun 01, 2010
    Please reveiw,
    Thanks
    Cliff
  • 1,284 Answers
Hi, Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Some brands also have a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
Take care
Posted on Jun 01, 2010
    Genius:
  • 1,417 Answers
were the problem of your oven it from the heater what will call element in the technical field
what you are to do to fix up your oven back to life is to unscrew your oven and then trace the wire down to the element you will see the wire that was disconnect from the element fix up to the element and put on your oven back to light
if after this the problem remain then you will have to change the element it self meaning that it bad
please not before you can do this work you will have to put off all source of power supply .
thank you and thanks for using fixya .
  • 1 more comment
    THIS MICROWAVE QUIT HEATING OVER NIGHT.
    ARE YOU SAYING THE MAGNETRON IS BAD?
    THIS OVEN IS 9-10 YEARS OLD.
    EVERYTHING WORKS BUT NOT HEATING.
  • Oloyede Monsuru Jun 01, 2010
    hello,
    i mean if the element is not providing heat then you will have to
    change the element (heat provider)it is then major problem of your oven
    thank you.
    hello,
    you will need to understand what am saying
    what this means is that the element(MAGNETRON)
    has over heat it self you will have to replace it with a better one
    thanks you once again.
Microwave won't heat
you have a power diode defective, high capacitor or Magnetron, test it for open with DVOM OR VOM , or better consult the qualified tech, Because this involve high voltage.
God bless you
Jul 10, 2012 | Frigidaire GLMV168K Microwave Oven
Microwave oven is not heating food power level can;t be changed at this time
That shows triac semiconductor is working fine, the problem is the magnetron, "heats food" cracked high voltage diode or a shorted high voltage capacitor.
Mar 21, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Food not getting heated
There are three common issues, magnetron "heats food" cracked high voltage diode, or a shorted high voltage capacitor. In order to find out you will need a professional to assess, it will be probably cheaper to replace the microwave oven.
Mar 16, 2012 | Electrolux Microwave Ovens
Oven won't shut off
One of the door switches is defective, caused by a build up of food particles or normal ware, to correct this a professional will need to identify the problem and replace it.
Mar 07, 2012 | GE Advantium 120 Convection/Microwave Oven
We have a sunbeam microwave. it starts but the light doesn't work and it won't heat the food. what should we do?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;'
Sep 01, 2011 | Sunbeam SMW750 Microwave Oven
Problem with the GE Spacemaker (JVM1640SJ) Microwave Oven GE Spacemaker XL1800 won't heat food anymore....It worked this morning, now won't heat. What should I do?
GE Will replace the magnetron for 9 years! Mine is a 2004 model with a one year warrently according to manual. HOWEVER they did say the magnatron was covered for nine years: call 888-239-6832. When I called they said thats all they get calls for and would send out in 3-5 days. NO CHARGE. I had to ask if there was coverage longer than a year on major parts and that's when they offered the info and I eventually was transferred to the right office. Saved $120 bucks on parts alone.
Jun 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave heating for 20-30 minutes with no food. Does not work.
heatman101
hgj
Jun 02, 2010 | GE JVM1630 Microwave Oven
Viking 1100 watt Microwave will not heat food
heatman101
fjj
Jan 05, 2010 | Viking VMOC205SS Microwave Oven
Convection oven problem
Most of the time the magnetron is defective if the food is not heating up.
In some cases there is a defective low power transformer or other componenents associated with the magnetron.
I would suggest to check the owners manual under the warranty section. Sometimes the magnetron has 5 years warranty.
Good Luck.
Feb 15, 2008 | GE JVM1490 Convection/Microwave Oven
Amana AMV1162 Microwave Oven Logo
42 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Steven Clarke
Steven Clarke
foster_mommy
Level 1 Expert
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
