Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Can the front screen be removed for cleaning? we just bought a used one and it has cobwebs in it
  • Philips Master
  • 3,459 Answers
Yes - it cab be popped off from the front.
Posted on Jun 06, 2010
Cobwebs inside screen
you need to take the top back off the tv. and mind the glass at the top of the rear part top it is very fragile, most of the projection tv have a side cover on each side so you can clean the rear of the screen, as you not said what type screen you have i cannot tell you further.
Feb 25, 2014 | RCA Televison & Video
Cobwebs proscan ps56700 inside screen
It can be done from the front but from the rear is actually more easy and safe--removing front screen and frame entails some danger of damage to the screens.
I have over many years of outside/home service calls encountered this.
As a outside technician I want the quickest and safest way to do this.
With set unplugged simply remove rear cover:
Use a swiffer type duster to reach up and inside and gently get all the webs out(do not use force when against the inside of the screens) and if the handle is long enough you will be able to remove all of the webs.
Also when doing this you will see with cover off 3 large black lens at the top of the chassis above the circuit boards.
They are the light source for your picture--clean them with a lens cloth or a paper towel with Glass cleaner sprayed on it---Do not attempt to clean the mirror in the rear as it is a film material and is easily scratched.
If the lens were dusty/dirty and then cleaned the picture will be brighter and sharper looking----that should be done about one time a year.
If you have questions make a comment here on this page(make a comment button).
Apr 21, 2012 | Proscan PS56700 56" Rear Projection...
Can the front cover be removed for cleaning?
yes normally its just small clips that are resealable used to hold it on as for maintenance it requires exposing the light bulbs
hope this helps
Robb
Apr 23, 2010 | Panasonic PT-51HX41 51" Rear Projection...
How doI take the cover off to clean the inside of the protective screen? sony KP-53v80
I removed about 6 or so screws took back cover off and used a duster to clean the inside screen it cured my cobweb problem.
Sep 12, 2009 | Sony KP-53V80 53" Rear Projection...
Cleaning cobwebs from philips rear projection tv model 51PW9363/1
I had the exact same problem and the fix is easy to do. Unplug the TV first of all and wheel it out so you can easily get to all of the rear screws.
  1. Remove the screws from the ventilated back panel (the piece of wood with a bunch of holes in it surrounding the AV connection panel.
  2. Remove the wood panel you just unscrewed.
  3. Remove all screws from the upper plastic case on the back.
  4. Remove the back plastic case carefully. This is a little tricky due to two metal pins that it hangs on. Lift it upwards and you should be able to free it from these pins
  5. At this point you should be able to see the entire workings of the TV, and consequently the massive amount of dust that has accumulated.
  6. Carefully take a vacuum and remove all the cobwebs, taking care not to bump the mirror or the lenses.
  7. First, I used some compressed air to clean off the lenses and then used a clean microfiber towel to remove all the dust from the lenses, the mirror, and the screen on the inside. Make sure the part you are wiping the mirror and lenses off with is free from any dust or dirt or you will risk scratching them.
  8. Reverse the dissasembly process to put the case back together.
  9. I went through the convergance settings at this point and found that they were all out of calibration and as such recalibrated them. Use the mulitpoint calibration for best results.
  10. Enjoy a much cleaner brighter TV!
Jan 25, 2009 | Philips 51PW9363 51" Rear Projection...
Cobweb inside of TV
i did mention this in my problem post incase it can help you but in the event where you overlooked it try some dust-off it may help you better than it did me
Jul 05, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
How do i clean my screen
You can clean the screen from the back - take off the access panel. I clean mine once a year whether it needs it or not.
Apr 23, 2008 | Sony KP-53V80 53" Rear Projection...
Clean behind the screen.
hey,
to packerfan. yesterday i did some thinking. i had the same problem w/ my toshiba 57". cobwebs in the viewing screen. i found the solution to be simple. take the front panel off. it's just held on by some clips. remove the black cardboard cover that protects the wiring. it's simple just w/ a screwdriver. attach a feather duster w/ duct tape to a 2 ft. dowel or longer if your arms are short.there are several places you can go up to dust. i found that if you clean 1/2 of the screen then the other 1/2 you should be done all tolled in about 10 mins. presto! my screen has never looked so good.too bad it's taken me 3 yrs. to figure it out. hope this solution works for you as great as it worked for me!!!
Nov 24, 2007 | Toshiba 57HDX82 57" Rear Projection HDTV
Cobwebs in the screen
pop the front grill off and you will see some screws onthe bottom of the screen. pull these out and the grey trim peice should pull right off.
Oct 14, 2007 | Philips 60PP9202 60" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
53 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
